Toymods » Tech & Conversions » easiest brake upgrade ke30
styler
easiest brake upgrade ke30 Sun, 23 January 2005 13:35 Go to next message
im lookin to do the easiest brake upgrade for
the rolla, so the more bolt in it is and less
modifying has to be done the better...
so what exactly has to be done for ta22, xt130,
ke70 and cressida brake conversions?
full strut seems the easiest option avaliable
yes i have researched this topic.
[Updated on: Sun, 23 January 2005 13:37]
gr8r-x
Vic, AU
Re: easiest brake upgrade ke30 Sun, 23 January 2005 21:18 Go to previous messageGo to next message
Well, I replaced the front struts on my KE50 with those from an XT130.. Was all pretty much bolt in, except for the obvious spring holder swap or chassis hack.
BradW
Bottom of the hill, Sydney
Re: easiest brake upgrade ke30 Mon, 24 January 2005 08:38 Go to previous messageGo to next message
I'm using RA40 struts and lower control arms. Need to swap spring holder as well and maybe adjustable strut tops. Will also require 14" rims to fit the brakes.
Brad
styler
Re: easiest brake upgrade ke30 Thu, 27 January 2005 01:55 Go to previous messageGo to next message
what brakes are the best out of the lot and does
the master cylinder need to be changed too?
gr8r-x
Vic, AU
Re: easiest brake upgrade ke30 Thu, 27 January 2005 08:06 Go to previous messageGo to next message
All a matter of what you need... Personally I put the XT130 struts on because you can then go down the Peugeot disc/Hilux calipers road. Very nice combo, apparently stops pretty well. =P
As for master cylinder. It all depends on what caliper you use. Best bet, match the master cylinder size to whatever you pulled it out of. If it's not far off, you should be able to get away with it. However, if the pedal goes to far (ie. to the floor) and you still ain't stopping, obviously you'll need to up the size.
BradW
Re: easiest brake upgrade ke30 Thu, 27 January 2005 08:56 Go to previous message
I used the RA40 gear because I got it for free.
I have only test fitted one strut at the moment so I can't comment on how good it works.
The RA40 master cylinder can't be used as one of the brake lines fouls on the strut tower.
The standard KE30 master cylinder is 11/16" bore and the RA40 master cylinder is 13/16" bore which is stuff all difference so you may get away with using the KE30 master cylinder. I am looking at master cylinders and boosters at the moment and just this afternoon I test fitted an AE71 booster. It fit nicely and is bigger than the KE30 one. I'm making a trip to pick'n'payless on saturday to look at master cylinders to see if I can find a suitable 13/16" unit to use.
If I had to buy struts and stuff I would probably go with the xt130 ones purely because as gr8r-x said you can then upgrade to the hilux/pug combo.
I have pictures of the strut fitted to my car here
Brad
Previous Topic:external fuel pump in mr2
Next Topic:Speed sensor 3tgte
Current Time: Tue Oct 27 10:05:27 UTC 2026
Total time taken to generate the page: 0.071654081344604 seconds
