Toymods » Tech & Conversions » Air Bypass Valve
86tt
Air Bypass Valve Sun, 23 January 2005 17:42 Go to next message
http://toymods.org.au/Repository/TechDocs/Air%20Bypass%20Valve.jpg
just saw this thing on the toymods site, near the centre, it looks like there's 2 hose nipple right? It's for the coolant line right? How do I tap into the coolant lines? I must tap into the flow inside the thermostat (hotter part) right? And where can I find one of these? How expensive are they?
86tt
Re: Air Bypass Valve Fri, 11 February 2005 02:52 Go to previous messageGo to next message
bump
Re: Air Bypass Valve Fri, 11 February 2005 03:14 Go to previous messageGo to next message
Yes, coolant lines.
Doesnt matter where you tap into them, its all hot coolant.
The question is, why?
86tt
Re: Air Bypass Valve Fri, 11 February 2005 03:21 Go to previous messageGo to next message
CrUZsida wrote on Fri, 11 February 2005 14:14
Yes, coolant lines.
why tap into the coolant? or why I need a air valve?
Re: Air Bypass Valve Fri, 11 February 2005 03:22 Go to previous messageGo to next message
Why do you need an air valve?
By the looks of that photo, its also ECU controlled.
86tt
Re: Air Bypass Valve Fri, 11 February 2005 03:29 Go to previous messageGo to next message
coz my idle is too low when the engine is cold... Sad
Re: Air Bypass Valve Fri, 11 February 2005 03:34 Go to previous messageGo to next message
Are you running the factory ECU?
Should you actually have one of these?
86tt
Re: Air Bypass Valve Fri, 11 February 2005 03:38 Go to previous messageGo to next message
nah, running microtech, 4age with turbo
Re: Air Bypass Valve Fri, 11 February 2005 03:43 Go to previous messageGo to next message
Get a 20Valve ISCV.
Get the microtech programmed to suit (if it isnt already)
Wire it up.
Quick play around with laptop.
Blammo, done.
I'm using a 20valve ISCV on my 1uzfe, running microtech.
Works a treat.
86tt
Re: Air Bypass Valve Fri, 11 February 2005 03:53 Go to previous messageGo to next message
how does a 20v iscv work? how does it look like and how to connect it up? Very Happy
Re: Air Bypass Valve Fri, 11 February 2005 03:57 Go to previous messageGo to next message
Microtech has 2 wires coming out of it that can be programmed for ISCV.
Call whoever you ordered your ECU off, and find out whether it is currently set up for the 20valve one.
The 20valve one has 3 wires.
One for +12volts.
One for opening.
One for closing.
The two microtech wires control the opening and closing.
Looks like
http://www5e.biglobe.ne.jp/~GS_1/making_of_roadster/Engine/4_throtle/freedam_4_thro_kit/image007.jpg
One tube for in, one tube for out.
Providing you don't have quads, there should be an opening on the manifold for it.
Re: Air Bypass Valve Fri, 11 February 2005 03:58 Go to previous messageGo to next message
Another pic where you can see the 3 wires (and both pipes too)
http://homepage2.nifty.com/mas-i/engine/neweng12.JPG
86tt
Re: Air Bypass Valve Fri, 11 February 2005 04:11 Go to previous messageGo to next message
so which wires from the microtech controls the iscv? Coz I didn't think there was any wire from my microtech that's aren't connected
Re: Air Bypass Valve Fri, 11 February 2005 04:17 Go to previous messageGo to next message
I'm only running 2 of the 4 ignition drivers, so unless you have sequential ignition (ie, 4 coilpacks, NOT running wasted spark) then I don't think you can do it.
I'm guessing you are using an LTX8 or LT8S, I think you'll need to convert to waste spark if you have coil packs.
But if you already have wasted spark, or a convential dizzy, then you will have 2 extra outputs unused.
I'm pretty sure the ISCV used ignition drivers 3 and 4.
(I think 0 was tacho, 1 and 2 were for my coils)
86tt
Re: Air Bypass Valve Fri, 11 February 2005 04:25 Go to previous messageGo to next message
hmm.. I'm running 4 coil packs, does it mean it won't work for me?
Re: Air Bypass Valve Fri, 11 February 2005 04:31 Go to previous messageGo to next message
Do you have sequential ignition, or wasted spark.
It depends how it was set up.
Talk to the person you bought your microtech off.
Or Email tim@microtechefi.com, he should be able to help.
86tt
Re: Air Bypass Valve Fri, 11 February 2005 04:34 Go to previous messageGo to next message
it's a 4age, which one would it be?
From memory it's sequential as that's what's displayed on the "Dash"
Re: Air Bypass Valve Fri, 11 February 2005 04:38 Go to previous messageGo to next message
Dunno man, 4age's aren't my strong point.
86tt
Re: Air Bypass Valve Fri, 11 February 2005 04:41 Go to previous messageGo to next message
so if it's sequential, does it mean the iscv will work? or won't work?
Re: Air Bypass Valve Fri, 11 February 2005 04:44 Go to previous messageGo to next message
I'm pretty sure it wont work, as you don't have enough outputs for it.
Call tim @ microtech, or get incontact with dale http://www.braidedlines.com
86tt
icon14.gif  Re: Air Bypass Valve Fri, 11 February 2005 04:50 Go to previous messageGo to next message
yeah, thanks, I'll get in touch with Tim @ Microtech later when I have more time, thanks for your help anyway...
Re: Air Bypass Valve Fri, 11 February 2005 04:53 Go to previous messageGo to next message
Only other option is to use a Nissan style one.
They are based purely on coolant temp.
Its just an open/close solanoid that is controlled by coolant temp.
When the coolant is below 70ish degrees, its wide open
Once it hits 70ish degrees (or whatever its designed at) it slams shut.
86tt
Re: Air Bypass Valve Fri, 11 February 2005 05:01 Go to previous messageGo to next message
so the valve in the pic of my first post aren't controlled by coolant temp?
I tried going to the pick & payless wrecker once to find the idle valve that people always talk about, but I don't know where to find it... Very Happy
but I'll still need to find a way to connect the water lines right? How do I tap into the lines? Do I have to get some adaptors welded? or just get the brass fittings?
Re: Air Bypass Valve Fri, 11 February 2005 05:07 Go to previous messageGo to next message
I'm not sure how the one in the pic at the top works.
It looks like it has a connector, but what controls it, I don't know
It could be ECU switched, it could simply be power.
You will find an external water jacket somewhere on the motor.
It usually runs under the throttle body, adding a bit of warmth to it in cold countries.
Have a look for it. And just tap into that.
86tt
Re: Air Bypass Valve Fri, 11 February 2005 05:21 Go to previous messageGo to next message
so that will have water flowing through there already? How does it look like?
Re: Air Bypass Valve Fri, 11 February 2005 05:31 Go to previous messageGo to next message
Just looks like a radiator hose, but only 10mm wide.
And will be hot to the touch.
Danish
Re: Air Bypass Valve Fri, 11 February 2005 05:37 Go to previous messageGo to next message
The top diagram of the bypass valve is what I'm using.
86tt
Re: Air Bypass Valve Fri, 11 February 2005 05:49 Go to previous messageGo to next message
thanks for the help CrUZsida, I'll have a look at the engine later, I have to go out now, thanks again..
wilbo666
Re: Air Bypass Valve Fri, 11 February 2005 08:48 Go to previous messageGo to next message
CrUZsida wrote on Fri, 11 February 2005 16:07
Bingo, its just 12v when the ignition/engine is on.
Its simple as anything.
I was under the impression that the water input was for REALLY cold climates...and I thought some cars/engines, RA65's with 22re's for example came with ABV's that weren't water cooled. I doubt it will get too hot if it doesn't have water going through it, so I'd try it without water first and see how you go...
Allan
Re: Air Bypass Valve Fri, 11 February 2005 10:19 Go to previous messageGo to next message
yes i think the water lines are to stop it icing up in cold climates!
Re: Air Bypass Valve Fri, 11 February 2005 10:26 Go to previous messageGo to next message
wilbo666 wrote on Fri, 11 February 2005 16:48
Ummm, isn't the water the thing that closes it?
Ie, no water = open all the time, thus completely removing its purpose in life
Allan
Re: Air Bypass Valve Fri, 11 February 2005 10:29 Go to previous messageGo to next message
typicly thay are bolted to the engine to better judge when it is "warmed up" i'd say... hello retired toyota engineer somewhere care to explain??
Scorpion
Menai area of Sydney
Re: Air Bypass Valve Fri, 11 February 2005 11:47 Go to previous messageGo to next message
On the 4AG, the air valve is on the bottom of the throttle body. If you see where the accelerator cable connects to the cam (on the side of the intake plenum )that opens and closes the throttle butterfly, have a look underneath it. There should be two thin radiator hoses that carry hot water through the bottom of the air intake mouth. If you look inside the intake mouth, you'll see a hole in the bottom through which extra air is sucked when the engine is cold. As the water heats up, it passes through the idle valve on the bottom of the intake and heats a wax pellet (like a thermostat). As it heats up, the mechanism closes and cuts off the extra air going into the engine. If the mechanism is blocked up, when the engine is warm one hose will be hot and the other cold. If it's working, both will get hot as the water passes through. When the engine is cold and running, block the hole with your finger and the revs should drop. Do it when the engine is hot and the idle shouldn't drop - or only by 100rpm or so - if the idle drops then your idle valve isn't working properly.
86tt
Re: Air Bypass Valve Fri, 11 February 2005 12:55 Go to previous messageGo to next message
Scorpion wrote on Fri, 11 February 2005 22:47
yeah I know this one, but the problem is my throttle body's piping have all been welded shut... Very Happy so either I find a "bypass valve" or I find a RWD intake manifold, which I think the 1st item is easier to find... Very Happy
sideshow
Re: Air Bypass Valve Fri, 11 February 2005 13:40 Go to previous messageGo to next message
just get one from a nissan
u dont need one with hopt water thru it
nissan ones bolt to the block
they use heat from the block and also power 12v from the fuel pump wire and an earth to heat up a bimetal strip which in turn moves a small gate and starts to close the valve
dont do more work than is needed
and another thing microtech wont modify and old ecus anymore
everyone should know this by now
[Updated on: Fri, 11 February 2005 13:42]
Scorpion
Re: Air Bypass Valve Sat, 12 February 2005 06:12 Go to previous messageGo to next message
Do you have any litle tubes sticking out of the top of your throttle body ? If so, one of them should give you increased idle speed when opened and you can vary the restriction to vary the revs.
If you haven't got any tubes open, you may hve to drill a hole as there is no point having a valve if you have nowhere to feed the air into the the plenum after the throttle butterfly valve.
[Updated on: Sat, 12 February 2005 07:35]
wilbo666
Re: Air Bypass Valve Sat, 12 February 2005 09:10 Go to previous messageGo to next message
CrUZsida wrote on Fri, 11 February 2005 21:26
Its a bimetalic strip dude, the reason it opens and closes is due to the 12v that goes to it heats it and causes it to bend, when you take the 12v away it cools and closes the valve again.
I can't imagine 80+ deg water doing a real good job of cooling it?
Re: Air Bypass Valve Sat, 12 February 2005 09:50 Go to previous messageGo to next message
wilbo666 wrote on Sat, 12 February 2005 17:10
The way I see it, the water heats it up.
While the water it hot, there is no need for it to be open.
It opens once the water cools down again (ie, cold starts)
Once the water is warm, ie, engine is up to operating temps, the devices closes until the engine is cold again.
You said it yourself, its just ignition voltage and earth.
How can this control anything?
wilbo666
Re: Air Bypass Valve Sat, 12 February 2005 10:30 Go to previous messageGo to next message
CrUZsida wrote on Sat, 12 February 2005 20:50
I have had an ABV (of the same design as above, in fact I'm pretty sure it was me that sent that pic to nark to put in the techdocs!) operating out of the car off a 12v power supply (I was checking to make sure that it worked, because I had previously had two that didn't work!). It opened/heated up fine (I think you would be surprised at how quickly the valve closes from a cold start...much quicker than your car heating up fully) without water lines attached Smile
Edit: I guess it might idle a little high on warm starts, but I don't think you would notice it much, why not try it without the water lines and decide if they need to be hooked up (save some work...)
[Updated on: Sat, 12 February 2005 10:42]
Re: Air Bypass Valve Sat, 12 February 2005 10:37 Go to previous messageGo to next message
wilbo666 wrote on Sat, 12 February 2005 18:30
So, with what your suggesting, if I walked up to the cold car, and turned the key ON, and let it for 5-10mins accidently, then when to start it, that I now wouldnt have cold idle?
Seems pretty dumb thing to Toyota to do to me...
wilbo666
Re: Air Bypass Valve Sat, 12 February 2005 11:04 Go to previous messageGo to next message
CrUZsida wrote on Sat, 12 February 2005 21:37
Good point, but I had two apart and they would both close up with 12v alone. Smile
86tt
Re: Air Bypass Valve Sat, 12 February 2005 14:51 Go to previous messageGo to next message
Scorpion: I can feed the cold air via the hole from the "cold start injector" coz I don't need that with after market computer right?
But as soon as the cold water circulates, it should open the valve for cold idle right?
but if there's hot water, the valve should still open a few seconds after the car starts...
Scorpion
Re: Air Bypass Valve Sun, 13 February 2005 04:12 Go to previous messageGo to next message
Haven't had much to do with after market ECUs but I know some 4AGEs don't have them anyway so sounds like a reasonable option.
Need to experiment though because I'm not sure how the airflow will work - may only feed extra air into cylinders 1 & 2.
You could possibly take the air control valve off the bottom of the throttle body and feed your idle valve into the hole the ACV uses just behind the butterfly valve.
86tt
Re: Air Bypass Valve Sun, 13 February 2005 06:39 Go to previous messageGo to next message
the cold start injector location is right in the middle of the intake manifold, would that be ok to feed bypass air into?
[Updated on: Sun, 13 February 2005 06:40]
Scorpion
Re: Air Bypass Valve Sun, 13 February 2005 11:53 Go to previous messageGo to next message
Correct. Shocked
... and where does the main air flow come from ... one side. So I can't see the air from the idle jet hole going into cylinders 3 & 4 against the direction of the general air flow.
I'm not saying it won't, just that I think it is unlikely and could therefore give different mixtures to different cylinders. I'd do something around the throttle body but then this is not for my car. Very Happy
feral4mr2
Bundaberg, Qld.
Re: Air Bypass Valve Sun, 13 February 2005 12:12 Go to previous messageGo to next message
wouldnt it just be easier to get another 4age TB and use the very simple cold start air bypass/idle down it uses?
86tt
Re: Air Bypass Valve Sun, 13 February 2005 15:01 Go to previous messageGo to next message
feral4mr2 wrote on Sun, 13 February 2005 23:12
it would, but my throttle body is welded together with the intake manifold and therefore the only simple way is get the replacement rwd intake manifold which can range from $150-250 depends on your luck and the greed of the seller... Very Happy And they're no always available... Very Happy
Quote:
Correct.
I wasn't expecting the air flow to be big enough to make any difference @ idle?
BansheeBuzz
Gold Coast
Re: Air Bypass Valve Sun, 13 February 2005 17:26 Go to previous messageGo to next message
Ok let me tell you about that bypass valve, you will require water to run through it for it to function properly. In the event you been for a run up the hwy, pull into servo go inside have a coffee come out 20mins later you car will still be hot but the bypass valve bimetal strip wont be so when you turn your car back on it will idle high until the bimetal warms up from the 12v wiring system.
If it has the water connected through it the bimetal strip stays warm and you will no experiance anything you shouldn't
Another way around your idle problem would be be to use an idle up solenoid system used in early toyota a/c systems. They are an adjustable air bypass. You could use your aux output from the microtech to switch it off at say 65 degress then you would be fine
Allan
Re: Air Bypass Valve Mon, 14 February 2005 00:23 Go to previous messageGo to next message
BansheeBuzz wrote on Mon, 14 February 2005 04:26
http://forums.toymods.org.au/index.php?t=getfile&id=9736
thats what i use, its nicely adjustable, looks factory and works well
86tt
Re: Air Bypass Valve Wed, 16 February 2005 05:00 Go to previous message
Allan wrote on Mon, 14 February 2005 11:23
How's that work? It's too blurry to see what's happening there... Very Happy
Previous Topic:Freshly rebuilt 2tg - Which oil?
Next Topic:Battery box question
Current Time: Sun Oct 18 20:04:18 UTC 2026
Total time taken to generate the page: 0.010661125183105 seconds
