Toymods » Tech & Conversions » TA22: Electronically Assisted Ignition
floppy
Ipswich
TA22: Electronically Assisted Ignition Mon, 24 January 2005 03:14 Go to next message
Hey guys,
A friend of mine was saying that he made a kit to convert his old Escorts to Electronically Assisted Ingnition.
Now he had these in his escorts a few years ago, but I was considering doing this to my TA22.
So I guess my question is, has anyone here done that to one of their cars, and is it worth doing?
He mentioned that after doing the kit, he didnt burn out as many points, something about it being less voltage going into the distributor or something like that? He is looking for the book that the kit came out of so I can have a better look at the info in there.
Anyway enough of my ramblings.
Floppy
[Updated on: Mon, 24 January 2005 03:15]
Maurice c
Re: TA22: Electronically Assisted Ignition Mon, 24 January 2005 03:32 Go to previous messageGo to next message
I think hes talking about the Jaycar HEI conversion kit. I havent tried one personally but I mean to soon. They have been covered before in the forum so a jaycar search will yield results. They use the points as a switch instead running voltage straight from the coil stopping them arching over time. I still reckon that you need a hall sensor fitted to stop points bounce. Any takers??
Re: TA22: Electronically Assisted Ignition Mon, 24 January 2005 03:33 Go to previous messageGo to next message
dick smith used to make a simple HEI ignition system that used your points as a low voltage switch and then drove your coil to produce good/fat sparks, regardless of engine speed and (to a lesser degree) battery voltage.
it made points last for ages as they were only switching a few hundred miliamps and were no longer arcing (the cause of points wear and settings changing).
kit used to cost $20-30. i had one in my old RA23 and i never had to buy points or reset the points thereafter.
nowadays, DSE and jaycar sell more complicated HEI/CDI systems but they're able to deal with a variety of contactless points (Hall effect, optical, reluctor, etc).
you could also get the roter, switch, coil and igniter from a compatible toyota dizzi.
is worth it - easier starts regardless of weather, good sparks thru the whole rpm range, less maintenance.
Re: TA22: Electronically Assisted Ignition Mon, 24 January 2005 05:14 Go to previous messageGo to next message
yup, the Jaycar and Dick Smith HEI kits are nearly identical. i like the Jaycar kits better tho as they seem to use slightly better parts..
they work very well with points (just remember to ONLY INSTALL THE COMPONENTS FOR ONE SET OF POINTS... do NOT install the second set of components for a second set of points unless you actually use it Wink )
i've been running one on my 4K for maybe... 6 or 7 years..
also SO NOT USE THE BOSCH GT40 orange SPORT COILS.... they can and will die unexpectedly, possibly after 1 or 2 weeks.
very worthwhile upgrade if you don't want to splash out on an elec dizzy and ignitor.
current cost of kit at jaycar is $52.95, KC5247
http://www1.jaycar.com.au/productView.asp?ID=KC524 7&CATID=&keywords=high+energy+ignition& ;SPECIAL=&form=KEYWORD&ProdCodeOnly=&K eyword1=&Keyword2=&pageNumber=&priceMi n=&priceMax=&SUBCATID=
dick smith is $52.88, K3303
http://www.dse.com.au/cgi-bin/dse.storefront/41f48 492097d1994273fc0a87f9c0751/Product/View/K3303
greenta22
Dandenong Ranges, VIC
Re: TA22: Electronically Assisted Ignition Mon, 24 January 2005 06:26 Go to previous messageGo to next message
ive got a red bosch GT40, ive never seen an orange one but mine seems fine, had it for months...
drift86levin
brisvegas
Re: TA22: Electronically Assisted Ignition Mon, 24 January 2005 06:27 Go to previous messageGo to next message
he he..i actually today scored a JDM 18RGEU elec dizzy and ignighter from a wrecker..i simply said it was out of a piece of shit 18R and he gave it to me for $20!!! Very Happy Laughing
Re: TA22: Electronically Assisted Ignition Mon, 24 January 2005 07:16 Go to previous messageGo to next message
greenta22 wrote on Mon, 24 January 2005 17:26
i stand corrected then Smile.. is yours designed for electronic ignition? if so, it should be able to handle the increased dwell time.
both the compact and the oil filled orange GT40 coils i have had have died quick deaths...
the echlin points type oil filled coil i had lasted a number of years.. then it died suddenly with no warning.
now i have a toyota oil filled coil that is designed for electronic ignition (from US starlet?) and it seems fine also..
floppy
Ipswich
Re: TA22: Electronically Assisted Ignition Wed, 26 January 2005 22:36 Go to previous messageGo to next message
Thanks for the info guys.
I spoke with my mate yesteday and he still has the kit he made up for his escorts, I think I am going to try that, and then maybe look at the Jaycar kit you posted a link to.
I had thought of trying to do the transplant of an electronic distributor into the ta22 housing, but I don't know which car to get one from that has the bits I would need.
The kit will do for now though Smile
Floppy
alex_ta22
Newcastle, Hunter Valley
Re: TA22: Electronically Assisted Ignition Wed, 26 January 2005 23:39 Go to previous messageGo to next message
just need a 2tgeu dizzy (EFI 2tg) i sold mine for $170 not long ago
biohazard TA22
Re: TA22: Electronically Assisted Ignition Thu, 27 January 2005 00:17 Go to previous messageGo to next message
And I bought it, engine loves it, well worth $170.
floppy
Ipswich
Re: TA22: Electronically Assisted Ignition Fri, 28 January 2005 04:54 Go to previous messageGo to next message
Hey,
re: just need a 2tgeu dizzy (EFI 2tg)
So all I need to do is find one of those and it will go into the 2T block directly or do I take the guts of it and put it into the 2T dizzy?
(also need the 12v coil and that would be it right?)
Thanks.
Floppy
alex_ta22
Re: TA22: Electronically Assisted Ignition Fri, 28 January 2005 05:11 Go to previous messageGo to next message
direct bolt up, i think u can use the coil you already got
floppy
Ipswich
Re: TA22: Electronically Assisted Ignition Mon, 31 January 2005 03:27 Go to previous messageGo to next message
alex_ta22 wrote on Fri, 28 January 2005 16:11
Ahh ok, cool, I will keep an eye out for one.
Meanwhile I put the kit that my friend had made up for the escort into the TA22, seems quite good. the spark on cylinder 1 was visibly brighter when the kit was in the on position. (although i had just cleaned and set the points before I did this kit.) Previously I checked the spark with the points before I cleaned it, so It may have been that too.)
Anyway what I did do is check the voltage going to the points when the kit is set to On, around 7-8v (slight fluctuation), when the kit is off it was reading 12V.
It did seem to be a bit more responsive when driving, (less hesitation on putting the foot down), but then that could just be the placebo effect too, me wanting it to feel smoother Smile
Thanks for all the info guys, got some more ammunition to play around with now.
Floppy
Re: TA22: Electronically Assisted Ignition Mon, 31 January 2005 03:35 Go to previous message
becuase the points are no longer switching large amounts of current, you'll find they stay correctly adjusted for much longer time - you'll probably not have to buy another set in the life of the motor. The only earing thing is now the finger that follows the cam on the rotor shaft - as long as it gets grease occaisionally it'll remain intact for ages.
Previous Topic:Do you need another cat besides the primary?
Next Topic:1g-gte Unussual tacho behaviour
Current Time: Sat Oct 24 09:42:07 UTC 2026
Total time taken to generate the page: 0.0061149597167969 seconds
