Toymods » Tech & Conversions » quads on my 100kw 4age?
carsanactra
melbourne
quads on my 100kw 4age? Mon, 24 January 2005 13:58 Go to next message
just wondering what u guys rekon the advantage of quads will be? i know it will be more "responsive", but will i be gaing any real power?
arasta
brisvegas
Re: quads on my 100kw 4age? Mon, 24 January 2005 15:50 Go to previous messageGo to next message
it really depends on tuning.
coincidentally i was researching into this this evening actually...
from what i gather to do so will require an afterarket ECU and some buggerising around with getting vacuum sense...? and a manifold, or an adaptor. there are 16-to quad manifolds available, theres a japlish site about that has the kit - if you want the full kit bar the rerouted water pump it comes in at 58K yen, converted thats 733 bucks. no shipping. you can buy the converter manifold on its own for less but still..
Or you simply take your cutting tool of choice to an 86/100KW manifold and lop off the bits to fit to the 16V manifold, reweld the 16V pattern to the 20v tubes, then mount to 16v as desired..
provided th tuning is right tho, - well have a look at the forum links at the bottom but the quote i saw on gains was that it sounds filth with *up to* 20% extra in peak power and a fattening of the mid range torque. doesnt mean an 86KW will automatically jump to that but that was that guys experience. (the Bill thread)
thats a May 03 vintage thread btw and bills comment then as for "is it worth it?" .. "with a stock engine yes for power + sound no for cost..." for a modified engine he reckoned there was more value in it. hmmm bet the parts prices have dropped since then...
i did have a related que on this also for myself:... how different is the 20V ECU to the 16s? the wiring loom pins for wiring lights power etc will be different of course but i thought if the ecu is reading the afm/map sense, and controlling its injectors etc as standard... asides from the lack of VVT and the extra breathing of the 5th valve in the head , it should be possible to put on the Quad t/bs to a 100KW block (as suggested in original post) and use the 20v's original ecu to manage it?
every post ive dug up about bunging Quads on the 16v mentions using an aftermarket ECU and never using the stock ECU with non-engine functions patched in? i presume theres a good reason for that but as noone ever touched on the idea i dunno if im just thinking crazy or not hehe
(Digression: having an NA MR2 aw11 and thinking what would i like to do down th track? id prefer to keep it NA for insurance concerns. so either a 3sge upgrade or a gze upgrade or some NA toying... and as its currently an 86Kw red+blacktop theres been a lot of research! hehe.
from the sounds of it the best NA 4A combo short of going the 7age route is a 100Kw bottom end with smallport head and quads, with cams and ECU to suit.. id have to build mine with the 86 kw bits tho Neutral i did hear of using the bigport head on a 100KW block with big cams - that was an interesting route to take and extending that to quads would certainly be different too, id like to be a bit unusual Smile im prolly talking out my arse in actuality ).
(heres one thread, which last post mentions fixing that water piping problem - http://forums.toymods.org.au/index.php?t=msg&t h=44634&rid=8533&S=82c2e6c82a5dcdf413fcb0e 8fb263dc9&pl_view=&start=0#msg_403845
ECU thread (03) http://forums.toymods.org.au/index.php?t=msg&t h=19459&rid=8533&S=82c2e6c82a5dcdf413fcb0e 8fb263dc9&pl_view=&start=0#msg_159428
and the Bill quote thread (also 2003) http://forums.toymods.org.au/index.php?t=msg&t h=12563&rid=8533&S=82c2e6c82a5dcdf413fcb0e 8fb263dc9&pl_view=&start=0#msg_101717
Cheers! and thanks in advance for all answers flames and corrections heh
[Updated on: Mon, 24 January 2005 15:55]
takai
Re: quads on my 100kw 4age? Tue, 25 January 2005 13:09 Go to previous messageGo to next message
There will be very little gain in power for the effort put into it. Not unless you are already running serious power out of your 4AG. It is much easier to adapt a RWD engine because of the different water outlets and pipework, although its not impossible to do a FWD engine either, just more work and fiddly. It can get annoying to tune, especially when you are running GZE injectors so as not to lean out the top end. However, quads require very little gas at idle so you tend to run fairly rich (11:1ish) there.
SPRINTAH!
Re: quads on my 100kw 4age? Wed, 26 January 2005 08:11 Go to previous message
Power gain will be very minimal unless the engine is running big cams, aftermarket ecu, flowed/polished head, free flowing exhaust etc.
but the sound................. now THATS a different story
Previous Topic:AE92 gearbox alignment
Next Topic:change gze supercharge to turbo? help
Current Time: Fri Oct 23 01:06:47 UTC 2026
Total time taken to generate the page: 0.0077469348907471 seconds
