Toymods » Tech & Conversions » does anyone know how to fit oil guages to a gz20?
indian
south east - melbourne
does anyone know how to fit oil guages to a gz20? Tue, 25 January 2005 04:49 Go to next message
hey guys anyone know how to fit an oil pressure and oil temperature gauge to a gz20 soarer is it hard or is there any adaptors that can be made the gauges have the sender units but im looking if theres any place that these sender units can be plugged into without drilling and destroying any oil lines
ADMIN - make the title at least remotely informative! No No No
[Updated on: Wed, 26 January 2005 01:30] by Moderator
fade-e
Re: does anyone know how to Tue, 25 January 2005 05:19 Go to previous messageGo to next message
with the oil pressure guage you should be able to use the existing oil pressure light wires to connect it up (you know when you turn the car on and the oil light comes on?)
with the oil temp if the car doesnt come stock with one then you have to drill and thread a part of the block to put a sensor in
Re: does anyone know how to Tue, 25 January 2005 05:46 Go to previous messageGo to next message
Incorrect on both counts.
The oil pressure light switch is just that, a switch - it's not going to provide any useful signal for a gauge. Remove the switch and replace it with the oil pressure sensor - you may need an adapter fitting if the thread is different, but that should be easy to source from Pirtek/Enzed/etc.
If you want to run an oil temp gauge as well there's no need to drill and tap a new hole (this would require pulling the engine apart first, a little excessive just to install a gauge) - you can run a T-piece off the the existing hole and connect both sensors to that. Once again a hydraulic fitting shop will be able to supply what you need, just take them the oil light switch and the sensors for your gauges and they'll work it out from there.
indian
Re: does anyone know how to Tue, 25 January 2005 05:50 Go to previous messageGo to next message
so where can i find this oil pressure light switch in the engine bay to remove it and take it to pirtek
cheers lads
dcving
newcastle nsw
Re: does anyone know how to Tue, 25 January 2005 06:03 Go to previous messageGo to next message
i put mine down near the oil filter there is a hole there somewhere where it fits in nicely Smile
indian
Re: does anyone know how to Tue, 25 January 2005 06:08 Go to previous messageGo to next message
where exactly near the oil filter is the spare hole visible or do i have to search for the damn thing , im also guessing it would be covered up with some sort of plug , was it easy to get the plug off as well
cheers mate
dcving
newcastle nsw
Re: does anyone know how to Tue, 25 January 2005 06:14 Go to previous messageGo to next message
its about inline with the oil filter but towards the front of the car, easier to jack the car up and reach it from underneath
EMP-2TG
Carlingford, Sydney
Re: does anyone know how to Tue, 25 January 2005 11:51 Go to previous messageGo to next message
its the standard hole that the oil pressure switch is in, just run a t-piece like norbie said
Re: does anyone know how to Wed, 26 January 2005 00:55 Go to previous messageGo to next message
If you can wait a while, I'll have a 1GGTE oil pressure gauge sender. I need a switch one.
Re: does anyone know how to Wed, 26 January 2005 01:02 Go to previous messageGo to next message
fark indian - use punctuation correctly & more frequently! Razz
Celica_John
Re: does anyone know how to fit oil guages to a gz20? Wed, 26 January 2005 08:31 Go to previous messageGo to next message
you could probably run the switch, pressure sender unit AND the temp
I figure if there's a monumental oil leak you'll notice a red light before you look at the oil pressure guage. but i suppose in both cases it'll probably be too late!
badboybubby
On Probation
Re: does anyone know how to fit oil guages to a gz20? Tue, 19 April 2005 06:04 Go to previous message
Does anyone know what type of thread it has ?
Previous Topic:Soarer 92 uzz31 help!
Next Topic:Jap sprinter brakes on KE70 struts
Current Time: Sun Oct 25 19:06:03 UTC 2026
Total time taken to generate the page: 0.07125186920166 seconds
