Toymods » Tech & Conversions » ignition coils keep getting blown ?
kayot1k
icon14.gif  ignition coils keep getting blown ? Tue, 25 January 2005 07:11 Go to next message
Shocked
has anyone had a problem with their ignition coils getting blown all the time ?
well i had my replaced three times on my ecu and had an external one blown also.
does anyone know what to do to correct this problem or single out the problem even ?
regards
towe_001
Somewhere on a dirt bowl ...
Re: ignition coils keep getting blown ? Tue, 25 January 2005 18:57 Go to previous messageGo to next message
I don't know about the one on the ECU but the external one sounds like it could be to do with a ballast resister which could be "dead". That is supplying the coil with a 12v load when it should only be seeing something like around 6v while the car is running.
Toobs
Re: ignition coils keep getting blown ? Tue, 25 January 2005 22:48 Go to previous messageGo to next message
Are you running a performance coil with an aftermarket ignition system?
Some coil and ignition system combinations can cause problems... esp. if you are running a HEI type ignition with a performance coil.
Joshstix
Toymods Vice President
Re: ignition coils keep getting blown ? Tue, 25 January 2005 23:04 Go to previous messageGo to next message
Are you blowing coils or ignitors? From the description where you say the one on the computer died I'd assume it's an ignitor.
Are you using an aftermarket computer? If so I'd be taking a look at the dwell times.
YelloRolla
On your mum!
Re: ignition coils keep getting blown ? Tue, 25 January 2005 23:09 Go to previous messageGo to next message
I had similar issues about 4 yrs ago.
Perhaps you are using the wrong type of coil?
I cannot rightly remember which is which (something about transistor type or some such thing) but I do recall that there are differences between coils for electronic ignition and coils for points type systems (bosch do the electronic ones black and the points type red).
Re: ignition coils keep getting blown ? Wed, 26 January 2005 00:30 Go to previous messageGo to next message
jason is spot on re. bosch coils.
the ones designed for points cannot handle the increased dwell time of an electronic ignition system, and blow up relatively quickly
Jorrs
Coffs Harbour
Re: ignition coils keep getting blown ? Wed, 26 January 2005 10:11 Go to previous messageGo to next message
hey buddy i had exact same probs and it turned out it was my ignitor that was doin it even though it tested fine so i say replace that and replace the coil at same time Smile
sideshow
Re: ignition coils keep getting blown ? Wed, 26 January 2005 10:46 Go to previous messageGo to next message
if your running aftermarket ignitors and coils
best to use
bosch 008 ignitors and bosch hec715 i think coils
at least they will be suited to the coils
bosch coils have low resistance between the + and -
so they tend to fry cheap ignitors
but when using all bosch parts i have never had probs
kayot1k
Re: ignition coils keep getting blown ? Wed, 26 January 2005 13:48 Go to previous messageGo to next message
ignitor plus coil ?
lol, looks like i got myself into a little trouble now.
okay, when were talking about coils are we talking about the actual coil pack in gze sense the twin coils ?
and aftermarket ignitiors is that the one in the aftermarket ecu that sends the pulses out to the leads ?
sorry, dont under stand the jargon all to well at this stage.
besides whatever came with the aftermarket ecu i.e just the ECU everything is just plain stock.
thanks for thee replies though.
its sorta making sense
sideshow are these coils/ignitor for the gze? and where can i get these?
regards
sideshow
Re: ignition coils keep getting blown ? Wed, 26 January 2005 22:06 Go to previous messageGo to next message
u still havnt told us what engine
what ecu
etc
if u dont understand some of the stuff we are talking about
maybe get a proffessional to see it
but basically
the ecu sends signal to ignitor
then the ignitor fires to coil
unless u have microtech with onboard ignitors
kayot1k
Re: ignition coils keep getting blown ? Thu, 27 January 2005 00:26 Go to previous messageGo to next message
i own a 4agze twin coil pack style.
EMS ecu.
im thinking of replacing both the coil pack and the ignitor.
and it does have an onboard ignitor because i replaced it in the ecu when i sent it back to ems.
sideshow
Re: ignition coils keep getting blown ? Thu, 27 January 2005 08:12 Go to previous messageGo to next message
well i have had this problem only with ems ecus
if i were you i would ring them up
what ignitors are you running
if you are runnin the 4agze ignitor the dwell time
in the ems program might be set incorrectly
best of writing down what setup you have
what nodel ems
what ignitor it might have onboard ignitors
what coils
then ringing them up
must be a common thing with ems
DiZ_
The Eastwood MASSIVE !
Re: ignition coils keep getting blown ? Thu, 27 January 2005 10:51 Go to previous messageGo to next message
I'm running with the external ignitor unit on my stock GZE coil packs with not a problem at all.
kayot1k
Re: ignition coils keep getting blown ? Thu, 27 January 2005 13:54 Go to previous messageGo to next message
well i got an external one just the otherday,
made by EMS but that failed to last me two starts.
i will have this " dwell time " looked into.
ems does not seem to be worthwhile as it first looked.
DiZ_
Re: ignition coils keep getting blown ? Fri, 28 January 2005 07:27 Go to previous message
Voted user problem.
Previous Topic:*Help Needed* 3SGTE pinging problem
Next Topic:tyre choices for ae86?
Current Time: Sat Oct 31 03:10:16 UTC 2026
Total time taken to generate the page: 0.005728006362915 seconds
