Toymods » Tech & Conversions » What colour are 1JZGTE Chaser injectors??
Pete
gold coast
What colour are 1JZGTE Chaser injectors?? Thu, 24 October 2002 07:40 Go to next message
Just picked up another 1J, it is from a chaser(JZX90??), Traction control throttle body, front sump and a Gummy Hydraulic fan pump on the water pump.
It also has brown/Bone coloured injectors on the stock rail, the injectors have been out before as they are missing the top O rings.
Are they stock?
Re: What colour are 1JZGTE Chaser injectors?? Thu, 24 October 2002 10:22 Go to previous messageGo to next message
not an answer, but another question...
how much did you pick up that half cut for?
Pete
gold coast
Re: What colour are 1JZGTE Chaser injectors?? Thu, 24 October 2002 10:48 Go to previous messageGo to next message
Only bought the engine, it cost $300.
My stock JZA70 injectors are yellow, JDM 2J injectors are Olive/green.
WTF are brown ones?? They are Hi-impedance.
Soarer
Wollongong
Re: What colour are 1JZGTE Chaser injectors?? Thu, 24 October 2002 10:55 Go to previous messageGo to next message
[takes a peek under the bonnet]
Mine are yellow.
Standard Soarer 1JZ-GTE injectors.
Re: What colour are 1JZGTE Chaser injectors?? Thu, 24 October 2002 13:46 Go to previous messageGo to next message
$300?!?
that's damn cheap
considering I'm looking at $2500 for a front cut
Manny
Re: What colour are 1JZGTE Chaser injectors?? Thu, 24 October 2002 14:39 Go to previous messageGo to next message
Pete
Interesting find. What brand and part number are they? You getting them cleaned and flow tested? How many Ohms do they measure?
E30-323ti
Re: What colour are 1JZGTE Chaser injectors?? Thu, 24 October 2002 20:51 Go to previous messageGo to next message
Are they top fed ones or side feed?? As you mentioned they are missing the top O ring??
Pete
gold coast
Re: What colour are 1JZGTE Chaser injectors?? Thu, 24 October 2002 22:50 Go to previous messageGo to next message
They are side feed's.
When i say top O ring, i mean the o ring that sits on the top of the injector where that funny "Bone" shaped plate holds them into the rail.
Manny, If i find they are not Stock, i will get them flowed/cleaned.
As stated before, hi impedance = 15 Ohms
E30-323ti
Re: What colour are 1JZGTE Chaser injectors?? Thu, 24 October 2002 22:52 Go to previous messageGo to next message
Interesting.
Any other bits on the engine that make you think it's been played with??
Re: What colour are 1JZGTE Chaser injectors?? Thu, 24 October 2002 23:04 Go to previous messageGo to next message
Chocolate brown injectors are hi impedence, top feed, 315cc/min out of a non VVTi 2JZGE. The VVTi 2JZGE ones are turquoise/light blue - can anyone tell me what size they are?
Pete
gold coast
Re: What colour are 1JZGTE Chaser injectors?? Fri, 25 October 2002 00:31 Go to previous messageGo to next message
Why the hell do 2JZGE's have top feed injectors???
Dave, If you had side feeds i could hook you up with some 390's, these shoud be ample for your NA application.
Looks like i will get them flow tested next week or the week after.
The motor had the Loom cut at the fire wall, the only weird thing is the injectors.
Re: What colour are 1JZGTE Chaser injectors?? Fri, 25 October 2002 00:52 Go to previous messageGo to next message
Pete, are the lower half GTE and GE intake manifolds the same? If they are you could use the GE manifold (and top feed injectors)....I understand you are refabbing the plenum anyway. I have 2 spares, so if you need/want one, let me know.
Pete
gold coast
Re: What colour are 1JZGTE Chaser injectors?? Fri, 25 October 2002 11:26 Go to previous message
I maybe in luck, the engine was running an aftermarket computer.
I pulled the loom out, the engine had the 1st Cam position sensor disconnected.
The injectors are Not Nippon Denso??
P/N: 23250-16140 2627
They may be Hitachi.. That is what the symbol looks like.
Dave, dunno about the 2JZGE VS 1JZGTE inlet manifolds, no worries anyway you will see from some photos I am fabbing a custom plenum.
I will take photo's tomorrow....maybe(Depends on scoring my mates camera)
Previous Topic:3SGTE Info
Next Topic:ST185 GT4 Celica rear diff
Current Time: Sat Nov 21 06:15:58 UTC 2026
Total time taken to generate the page: 0.053696870803833 seconds
