Toymods » Tech & Conversions » w57 speedo sensor
jcmunga
adelaide
w57 speedo sensor Tue, 25 January 2005 10:57 Go to next message
i have a 1g out of a gz so it has the digital speedo sensor.
so what im wanting to know is, will the speedo sensor out of my auto behind the 18r-c fit it??
RA28
Re: w57 speedo sensor Tue, 25 January 2005 11:33 Go to previous messageGo to next message
If it's a W57 or W58 then it should have the hole for the speedo cable, I thought they all did anyway.
I don't think the 18R ever had any type of speed sensor.
Tim.
jcmunga
adelaide
Re: w57 speedo sensor Tue, 25 January 2005 11:35 Go to previous messageGo to next message
yeah its still got the digital plug thing in it and i have the cable that went into the box in the 18r and was hoping it would fit in
Re: w57 speedo sensor Tue, 25 January 2005 14:23 Go to previous messageGo to next message
If you get the speedo cable gear from an earlier W57/58, that will work. I don't think a W50 one will fit, but it's worth a try.
Re: w57 speedo sensor Tue, 25 January 2005 16:11 Go to previous messageGo to next message
W50 one will be different, but any W55/57/58 one should be fine.
jcmunga
adelaide
Re: w57 speedo sensor Wed, 26 January 2005 00:31 Go to previous messageGo to next message
how hard are they tp find? where can i get one from? i just thought the w50 one might interchange since the tailshaft yolk is the same.
Re: w57 speedo sensor Wed, 26 January 2005 00:33 Go to previous messageGo to next message
Should be a piece of cake to find. Just make sure you get one to match your diff.
jcmunga
adelaide
Re: w57 speedo sensor Wed, 26 January 2005 00:34 Go to previous messageGo to next message
yeah thats the hard part.
Re: w57 speedo sensor Wed, 26 January 2005 00:36 Go to previous messageGo to next message
Not really. You know what ratio your diff is, when you go to a wreckers just check the plate which tells you what the diff code is. If it matches yours, you should be close enough.
jcmunga
adelaide
Re: w57 speedo sensor Wed, 26 January 2005 00:40 Go to previous message
cool, cheers
Previous Topic:4age 20v silver
Next Topic:Problem with coil lines (??)
Current Time: Thu Oct 15 11:04:13 UTC 2026
Total time taken to generate the page: 0.0075719356536865 seconds
