Toymods » Tech & Conversions » Why is my head knocking?
Leighp
NY
Why is my head knocking? Wed, 26 January 2005 02:22 Go to next message
Well it sounds like it is comong from the head...... I have a 20v silver top, there is this remote knocking noise in the head (or so it seems) around the 2-3000 rpm mark.
Has anyone had this prob, if so what was it, could it be the VVt pully or a loose/bent/sticking valve?
PLEASE help me here i am pulling my hair out trying to sus this one out.
Mr DOHC
Re: Why is my head knocking? Wed, 26 January 2005 02:37 Go to previous messageGo to next message
does it run rough or differently to normal
Leighp
NY
Re: Why is my head knocking? Wed, 26 January 2005 03:09 Go to previous messageGo to next message
feels like it is losing compression, i can drive it but the output is alot less
OldSchoolRolla
January 2005
Re: Why is my head knocking? Wed, 26 January 2005 07:31 Go to previous messageGo to next message
Maybe oil problem???? u got good oil pressure?
Leighp
NY
Re: Why is my head knocking? Wed, 26 January 2005 10:34 Go to previous messageGo to next message
not sure at this point, i am assuming a valve at the moment
is there any way that i can check valve probs??
Re: Why is my head knocking? Wed, 26 January 2005 11:30 Go to previous messageGo to next message
lemme see....
remove rocker cover and turn over the motor and see what happens..
i also vaguely remember a number of threads froma few years ago saying that the VVT actuator caused similar noises and lack of power.. might be worth a google..
Leighp
NY
Re: Why is my head knocking? Wed, 26 January 2005 14:55 Go to previous messageGo to next message
turn the motor over with the rocker cover off???? the motor wont crank, or am i just out to see what happens? do i do this with the spark plug leds connected??
Re: Why is my head knocking? Wed, 26 January 2005 22:19 Go to previous messageGo to next message
take off rocker cover, turn motor over with.. a spanner, ie BY HAND... so you can turn it little by little and verify that the valves and cams are ok..
Fattony
Re: Why is my head knocking? Wed, 26 January 2005 23:18 Go to previous messageGo to next message
How frequent is the knocking? Does it do it when you start the car for a moment?
I have heard similar things, it sounds like its comming from the head, but its turned out the be the bottom end bearings.
When i have heard this at idle car sounds normal, and about 3000rpm you can start to hear the knocking and when the motor is trying to start.
Cheers Adam
Leighp
NY
Re: Why is my head knocking? Thu, 27 January 2005 00:39 Go to previous messageGo to next message
ok well i will try what you suggested 'oldrolla', thanks for that one.
Fattony: the noise starts when i hit the gas and at about 2500- 3300 (or so) then it is not so bad. how do i tell if it is bottom end bearings? If it is how do i replace them ones, isn't it a case of matching pairs to the block?? that will be a fun one right?
thanks for all the help peoples.
Leighp
NY
Re: Why is my head knocking? Thu, 27 January 2005 00:42 Go to previous messageGo to next message
Leighp
NY
icon13.gif  Re: Why is my head knocking? Thu, 27 January 2005 01:10 Go to previous messageGo to next message
Soz bout the triple post, network probs
[Updated on: Thu, 27 January 2005 02:18]
YelloRolla
On your mum!
Re: Why is my head knocking? Thu, 27 January 2005 02:22 Go to previous messageGo to next message
Like Fattony has said - It may well be that a big end bearing has carked it. If this has happened the piston can hit the cylinder head.
How do you find it? Drain the oil and pour it through a sieve. If there is any coppery white metal things then it is stuf-fed.
Solution = motor rebuild or another import.
Leighp
NY
Re: Why is my head knocking? Thu, 27 January 2005 02:43 Go to previous messageGo to next message
we replaced the bottom end bearings with ones out of another 20v block, they were all good so that may be it, but i still doubt it.
i know about draining the sump part, the last 2 motors were bottom enders and they were totally f*$%ed
Fattony
Re: Why is my head knocking? Thu, 27 January 2005 23:11 Go to previous messageGo to next message
U can take of the sump and pull the lower part of the bearing and inspect it from there.
PS have fun, if it is your better of just getting another motor cause it would prob cost just about as much.
Cheers Adam
Leighp
NY
Re: Why is my head knocking? Sun, 30 January 2005 14:33 Go to previous messageGo to next message
that is what i am thinking eh mate, but yeah, looks like a slow rebuider eh
ST162GT-R
QLD, Gold Coast
Re: Why is my head knocking? Mon, 31 January 2005 00:12 Go to previous messageGo to next message
Thats exactly what happened to mine as well, bearings come off and my cylinders startered to knock and yep, engine rebuild, and yeah slow rebuild, about 4 months to date.
stradlater
Arthurs Creek, Victoria
Re: Why is my head knocking? Mon, 31 January 2005 04:52 Go to previous messageGo to next message
If your heads knocking, why don't you just answer it?? Wink
jesseT18
Castle Hill, Sydney
Re: Why is my head knocking? Mon, 31 January 2005 07:28 Go to previous messageGo to next message
who's there?
i've seen the same thing on a few cars, a tick tick at idle that gets faster with the revs. never thought it would be something as serious as a bearing!
better do the oil drain test!
jesseT18
Castle Hill, Sydney
Re: Why is my head knocking? Mon, 31 January 2005 07:29 Go to previous messageGo to next message
who's there?
i've seen the same thing on a friends car, i couldnt figure out what it was, a tick tick at idle that gets faster with the revs. never thought it would be something as serious as a bearing!
his car would only do it sometimes though, fine one day, ticky the next, better tell him to drain his oil and puit it through a sieve
stradlater
Re: Why is my head knocking? Mon, 31 January 2005 08:34 Go to previous message
AH, no the tick tick that comes from a head that increases with idle, but doesn't sound that bad is the valves. Either not getting enough oil, or having a big of slap in them.
Common in e* falcons
Previous Topic:how much are arp conrod bolts for 2tg
Next Topic:2ZZ-GE importers?
Current Time: Fri Nov 20 03:30:27 UTC 2026
Total time taken to generate the page: 0.015491008758545 seconds
