Toymods » Tech & Conversions » Non Return Valve
Flebbert
Wagga
Non Return Valve Wed, 26 January 2005 08:04 Go to next message
Just wondering where it is located in the Mk3 87 Supra. If it is part of the fuel pump or not as mine i think is dead as is not holding fuel pressure after u turn car off
also how much
RA28
Re: Non Return Valve Wed, 26 January 2005 08:14 Go to previous messageGo to next message
I didn't think they were supposed to hold perssure, That's why most ecu's prime the system as soon as you turn the key to ON.
Tim.
Flebbert
Wagga
Re: Non Return Valve Wed, 26 January 2005 08:21 Go to previous messageGo to next message
i didnt think it pumped fuel untill the care cranked over
Re: Non Return Valve Wed, 26 January 2005 08:34 Go to previous messageGo to next message
Yes, they should hold residual pressure between the pump and reg, if this pressure is being lost, then one of the above is crook.
Flebbert
Wagga
Re: Non Return Valve Wed, 26 January 2005 13:09 Go to previous messageGo to next message
i have tested the pressure and the fuel pump is dead on what it is ment to be at. Where is the reg located at. Is the reg also known as the fuel pressure valve.
[Updated on: Wed, 26 January 2005 21:44]
Dylo
Re: Non Return Valve Thu, 27 January 2005 02:54 Go to previous messageGo to next message
Ahh this could be what i need on mine.
The 1G doesnt prime the pumps, and when i start the car it starts off really slow and lumpy till the pressure builds up and then she's fine. What are these valves? Where can i get one and do they just sit in the fuel line somewhere?
Re: Non Return Valve Thu, 27 January 2005 03:08 Go to previous messageGo to next message
The fuel pressure regulator is located at the return end of the fuel rail, and it should prevent any pressure being released when the engine is switched off. AFAIK the fuel pump contains a valve which prevents fuel flowing backwards but I'm not sure about that one?
Flebbert
Wagga
Re: Non Return Valve Thu, 27 January 2005 03:09 Go to previous message
from my understanding there is one at the pump and one at fuel rail that stops the fuel from running out that end. So between the two stops the lines from loosing pressure which means that the engine doesnt have to prime everytime engine starts.
My car is slow to start and lumpy as well for 40 seconds or so.
think it is called a non return valve
Previous Topic:18RG hose
Next Topic:SC14 Supercharger onto GZE
Current Time: Wed Nov 18 17:12:46 UTC 2026
Total time taken to generate the page: 0.0069060325622559 seconds
