Toymods » Tech & Conversions » HELP! sprinter box f**d
xplict_[de.coop]
liverpool
January 2005
HELP! sprinter box f**d Wed, 26 January 2005 11:53 Go to next message
hey guys i have a ke20 with a 4agze and the sprinter 5speed is f***d,i just got a new clutch put in and now you have to smach it into reverse or or first, goin up gears is kool but goin down is almost impossible,would it be that i have to adjust the clutch cable or something?
xplict_[de.coop]
liverpool
January 2005
Re: HELP! sprinter box f**d Wed, 26 January 2005 22:57 Go to previous messageGo to next message
help?
please?
anyone>?
Re: HELP! sprinter box f**d Wed, 26 January 2005 23:10 Go to previous messageGo to next message
do you have a clutch cable? or is it hydraulic? check, and then adjust to suit. if that doesn't help (and you are sure it was all put together correctly, then maybe you have an internal box problem. time to pull it, disassemble and fix.
FKN16V
NSW, East Coast
Re: HELP! sprinter box f**d Thu, 27 January 2005 05:12 Go to previous messageGo to next message
Personally id take it back too where you got it from, if it was fine before but now isnt working properly, id start there.
But it sounds like the clutch isnt engaging properly or the syncro's are on the way out?
Steve
xplict_[de.coop]
liverpool
January 2005
Re: HELP! sprinter box f**d Fri, 28 January 2005 00:20 Go to previous messageGo to next message
its hydraulic,thanks for the help
what do i do if its hydraulic?> its adjusted all the way
i jus need a lil more clutch to make the shift normal
:S anyone?
IRA11Y
Club Member
Re: HELP! sprinter box f**d Fri, 28 January 2005 05:32 Go to previous message
bleed the clutch line and if that doesent work adjust the clutch pedal
Previous Topic:tyre choices for ae86?
Next Topic:81 Hilux 1ggte conversion
Current Time: Fri Oct 30 06:20:24 UTC 2026
Total time taken to generate the page: 0.033529996871948 seconds
