Toymods » Tech & Conversions » Changing Gear Box Oil
troyboy
Colyton, NSW
Changing Gear Box Oil Thu, 24 October 2002 21:55 Go to next message
Please help...
tell me...
how do i change my gearbox oil?
Spanks
Ribbo
Northern Beaches
Re: Changing Gear Box Oil Fri, 25 October 2002 00:19 Go to previous messageGo to next message
ummm there should be a plug somewhere to empy it, and a plug up higher to fill it up.
u can use something like a soap pump action bottle, fill it up with gearbox oil and pump it in.
I used one of the hand pumps with 2 ends and bobly thing to pump, one goes in gearbox oil and one into gearbox and start pumping.
ur gonna love the smell of the oil, aaaaahhhhh can remeber it now Shocked
ra23celicachick
Mornington Peninsula
Re: Changing Gear Box Oil Fri, 25 October 2002 01:05 Go to previous messageGo to next message
That oil stinks! When the tac welds from a cover that goes over the universal joint on my tail shaft broke we had to drop the tail shaft out to fix it and it was disgusting. ARGH
Sprocket
The Central Coast
Re: Changing Gear Box Oil Fri, 25 October 2002 02:11 Go to previous messageGo to next message
Ribbo is right, there will be a plug at the bottom of the gearbox where all the oil can drain out. Make sure the car is warm when you do it (cause it runs quicker and wont take so long, obviously with the engine off).
Then put the plug back in and you should find a plug half way up, undo that, it should be a pretty big one. Some top up oil bottles have a neck funnel to make it easy to squirt the oil in. Buy one of those and a 3 or 4 litre bottle, just keep filling up the little one when it runs out.
Fill it up as far as it'll go until it comes streeming out the hole, then do the plug back up. DON'T OVERFILL IT, you'll blow an oil seal if you do. As long as it's on flat ground and you fill it as far as it'll go to that hole, you'll have no worries!
Shouldn't take you longer than 30mins!
Good luck! Wink
ed_ma61
Lost in the K hole
Re: Changing Gear Box Oil Fri, 25 October 2002 09:17 Go to previous messageGo to next message
**WARNING**
sounds dumb, but undo the filler plug first. the last thing you want to do is undo the drain plug, dump all your old oil, then find you cant get the filler plug undone.
ed
Rolla Boy
Club Member
Sydney, NSW
Re: Changing Gear Box Oil Fri, 25 October 2002 17:06 Go to previous messageGo to next message
OMFG Troy... You're not serious???
That's an excellent point Ed... That's the way that we do it at work...
Sproket, 30 mins?!?!?! Why would it take that long???
troyboy
Colyton, NSW
Re: Changing Gear Box Oil Fri, 25 October 2002 20:20 Go to previous messageGo to next message
Rolla Boy wrote on Sat, 26 October 2002 03:06
I apologise Ben ...
Very sorry that I have never done a gear box oil change and asked for some help ...
But thats OK young Tadpole.. When your about to loose ur virginity and need to know where to find the right hole ... gimmie a call and I'll give you a few pointers ... Shocked Shocked Shocked Shocked Shocked
Thanx to all those who replied!
Cheers!
[Updated on: Fri, 25 October 2002 20:21]
Rolla Boy
Club Member
Sydney, NSW
Re: Changing Gear Box Oil Fri, 25 October 2002 22:22 Go to previous messageGo to next message
Awww shocks... That's okay Troy... I was just in a state of shock at the title of the thread and I spose it's good that you asked someone before un-doing the wrong thing...
Re: Changing Gear Box Oil Sat, 26 October 2002 00:19 Go to previous messageGo to next message
Hey man, until a few months ago, I'd never even changed my engine oil. Not everyone knows everything Smile
jasonp1977
Re: Changing Gear Box Oil Sat, 26 October 2002 00:24 Go to previous messageGo to next message
http://users.bigpond.com/jasonpurcell/gearoil.jpg
That is the drain hole, and the filler hole is on the radiator side of the box, which you can see just above the bumper support stay on the left side of the pic, its the large rusty looking plug...
Jason
[Updated on: Sat, 26 October 2002 00:25]
troyboy
Colyton, NSW
Re: Changing Gear Box Oil Sat, 26 October 2002 08:42 Go to previous message
thankis you soo much guys..
thanx heaps Jason for that pic...
now i know what i am looking for!
Smile Smile Smile
Previous Topic:1ggte head gaskets
Next Topic:second times a charm
Current Time: Sat Nov 21 06:02:00 UTC 2026
Total time taken to generate the page: 0.0077099800109863 seconds
