Toymods » Tech & Conversions » 18RG hose
Petes76celica
18RG hose Wed, 26 January 2005 13:17 Go to next message
hi i looking 4 the hose that seems to go up between the carbys and has 2 90 degree bends and goes in to the rocket cover does this hose come out of the side the engine. if so where abouts could i get 1 i was thinking i tryin toyota but they useually charge heaps.
Pete
enigma
Re: 18RG hose Thu, 27 January 2005 03:11 Go to previous message
I'm not sure what the exact setup should be but the guys that put my engine in used rubber tubing, about the thickness of vacuum tubing. And just used a couple of tee pieces. Make sure you have a breathing outlet otherwise the pressure will blow your dipstick out. My breather goes to the atmosphere, some people have it go to the aircleaner, and some have a oil catch can with a breather filter.
Also make sure it is fastened on to the oil return on the side of the engine as mine has sprayed a little out and made an oily mess.
I will see about taking some photo for you.
Another idea to make it tidier would be to talk to someone like
pirtek or another professional hose company, but I am not sure about that I haven't looked into it.
If you investigate pirtek please share what you find.
Previous Topic:267 Deg Cams for my 4AGE, Wade Cams, Regarding ECU
Next Topic:Non Return Valve
Current Time: Sun Sep 20 16:30:54 UTC 2026
Total time taken to generate the page: 0.0058629512786865 seconds
