Toymods » Tech & Conversions » How do you tell if you have a viscous LSD ? [4agze]
nick.parker
January 2005
How do you tell if you have a viscous LSD ? [4agze] Wed, 26 January 2005 14:03 Go to next message
Hello,
How could you tell if a 4AGZE gearbox had a viscous LSD one or not?
The test I have seen involves hoisting the car into the air, with it in gear, then manually turn one wheel back and forth, the other wheel should follow after an initial 'clunk' - I think this is a test for checking for a 'clutch type' LSD .
A viscous differential needs a speed differential to do any LSD work. Is the 'hand speed' test sufficient? Or would the viscous LSD equipped gearbox just seem like an open differential?
On a lone gearbox, of unknown origin, can you look down the gearboxes drive shaft hole and see anything that would give away a viscous LSD?
Regards, Nick Parker
AW11SC...want an LSD!
Miss MR2
Re: How do you tell if you have a viscous LSD ? [4agze] Wed, 26 January 2005 21:23 Go to previous messageGo to next message
turning the wheel forward should cause the opposite wheel to turn in the same direction if you have the lsd.
either that or a nice big smoke show will reveal rather quickly Razz
nick.parker
January 2005
Re: How do you tell if you have a viscous LSD ? [4agze] Thu, 27 January 2005 05:31 Go to previous messageGo to next message
Hmm,
Yes, Very Happy thats one way, but I'm really looking more along the lines of checking a gearbox thats not installed in a car. I'm hoping there's a way without pulling the gearbox apart!
Cheers, Nick
4agte
Toronto, Downtown
Re: How do you tell if you have a viscous LSD ? [4agze] Thu, 27 January 2005 06:09 Go to previous message
you can test a viscous lsd by turning one wheel and see if the other one turns or hold the other wheel and see if they both want to turn when you turn one of the wheels.
This works with a viscous lsd as thats how i test mine.
Previous Topic:retrimming the windscreen surrounds
Next Topic:ST162 / ST165 brakes
Current Time: Wed Oct 28 06:11:31 UTC 2026
Total time taken to generate the page: 0.028122186660767 seconds
