Toymods » Tech & Conversions » Speed sensor 3tgte
TheNav
Speed sensor 3tgte Thu, 27 January 2005 01:16 Go to next message
Hi, i have a 3tgte with a w55 gearbox and want to connect my turbo-timer. The only thing is, i'm not sure if the computer or gearbox has a speed sensor to connect my turbo timer to. Does anyone know where i can connect the turbo timer? I have it set up at the moment, but can only set the turbo timer manually, I'm assuming that i need to connect the speed sensor wire from the turbo timer somewhere, just dont know where, or if it can actually be done.
Any help would be great
Re: Speed sensor 3tgte Thu, 27 January 2005 01:20 Go to previous messageGo to next message
The W55 behind my 3tgte had a mechanical speedo cable. Assuming yours is the same (unless you have a digital dash or something?) you wont be able to connect the speed sensor feature of the turbo timer.
TheNav
Re: Speed sensor 3tgte Thu, 27 January 2005 01:28 Go to previous messageGo to next message
Damn it!! i was hopeing that wouldn't be the answer. Ah well. Is there anything i can get so that i can use the speed sensor of the turbo timer, apart from buying a new computer?
Re: Speed sensor 3tgte Thu, 27 January 2005 01:36 Go to previous messageGo to next message
Its not the computer thats the problem. Its the sender in the gearbox. Its just a cable.
You could get a electronic sender probably. But then you will need a new speedo as well.. Maybe look at the VDO electronic speedos thats what I plan to put in mine.
I'm sure some of the W series boxes would have had electronic speedo senders that you could fit to your W55.
Joel
But on another note.. Just use the turbo timer manual function Smile I'm sure it has a couple of pre-set values?
YelloRolla
On your mum!
Re: Speed sensor 3tgte Thu, 27 January 2005 01:50 Go to previous messageGo to next message
I believe that the electronic sender from the 6 spd Altezza fits - that'll only set you back about $500 or so.
Re: Speed sensor 3tgte Thu, 27 January 2005 01:57 Go to previous messageGo to next message
$500 well spent if you ask me ! Rolling Eyes
TheNav
Re: Speed sensor 3tgte Thu, 27 January 2005 02:10 Go to previous messageGo to next message
Thanks heaps for the info bro. Any idea on how much the electronic speedo senders would cost? If i did get a new computer for the car though, obviously depending on which computer i get, would they have a feature that would be able to determine the speed and there-fore be able to connect up the turbo timer?
I have the turbo timer pre-set to 3mins, leave it longer if i've been hammering it a bit
Thanks again
TheNav
Re: Speed sensor 3tgte Thu, 27 January 2005 02:15 Go to previous messageGo to next message
Thanks again. Seeing the price, i think that i'll just continue to set the turbo timer manually Rolling Eyes
Re: Speed sensor 3tgte Thu, 27 January 2005 03:27 Go to previous messageGo to next message
No computer that I know of will determine the speed.. That has to come from the gearbox sender.
TheNav
Re: Speed sensor 3tgte Thu, 27 January 2005 03:41 Go to previous messageGo to next message
Thanks heaps once again.
Does anyone know of another type of sender that will fit but not cost $500??
sideshow
Re: Speed sensor 3tgte Thu, 27 January 2005 08:22 Go to previous messageGo to next message
i sell speedo sensors that will screw onto where yr cable goes now
then the cables screws into the back of the sensor
so u can have electronic signal to ecu and also run yr cable for yr speedo
[Updated on: Thu, 27 January 2005 08:22]
fade-e
Re: Speed sensor 3tgte Thu, 27 January 2005 08:28 Go to previous messageGo to next message
sideshow wrote on Thu, 27 January 2005 19:22
tell em the price son! the price son!
sideshow
Re: Speed sensor 3tgte Thu, 27 January 2005 08:32 Go to previous messageGo to next message
110 plus postage
YelloRolla
On your mum!
Re: Speed sensor 3tgte Thu, 27 January 2005 08:40 Go to previous message
$110 - now that's worth noting!
Incidentally 3 mins is a fair cool down time - more than necessary if you are driving normally (whatever that means)
Previous Topic:easiest brake upgrade ke30
Next Topic:RWC Question
Current Time: Tue Oct 27 06:27:45 UTC 2026
Total time taken to generate the page: 0.0090029239654541 seconds
