Toymods » Tech & Conversions » factory low pressure electric fuel pumps?
chrisss
melb
factory low pressure electric fuel pumps? Mon, 27 May 2002 14:14 Go to next message
does anyone know of any cars(carby) that came standard with an electric fuel pump. im using an aftermarket "facet" fuel pump which is too damn noisy, and I dont want to spend a fortune on a pump that is capable of 7lt/min (holley) when all I need is 1.5lt/min. I figure something cheap from the wreckers should do the job?
Re: factory low pressure electric fuel pumps? Mon, 27 May 2002 23:33 Go to previous messageGo to next message
A lot of early Mazdas (early-mid 70's) have electric pumps, generally they are located in the rear (rather than the engine bay), usually in the space behind the rear wheel and the boot. Either way, just follow the fuel line out of the tank and you'll stumble across it.
chrisss
melb
Re: factory low pressure electric fuel pumps? Tue, 28 May 2002 03:54 Go to previous message
cheers, I try and get an early rx7 pump then.
Previous Topic:Tuning for 98ron
Next Topic:Changing comp/exhast wheels & balancing?
Current Time: Thu Oct 22 14:52:31 UTC 2026
Total time taken to generate the page: 0.0042059421539307 seconds
