Toymods » Tech & Conversions » swapping 1g injector plugs to fit 7m injectors?
Pube
Camden
swapping 1g injector plugs to fit 7m injectors? Thu, 27 January 2005 12:59 Go to next message
I recently bought some 7mgte injectors and have a gen 3 1ggte from a GX81. I read that the 7mgte injectors should plug in but some found that they dont on some 1ggte's as toyota changed things for some unknown reason.
Well it was my lucky day, i have the 1ggte that the 7mgte injectors dont plug in. Well they nearly do but one of the tabs that the injector plug clicks into is on the opposite side.
So how do i get around this problem?? Can i get the plugs of another 1ggte, cut my plugs off and solder the correct ones on??
dcving
newcastle nsw
Re: swapping 1g injector plugs to fit 7m injectors? Thu, 27 January 2005 21:11 Go to previous messageGo to next message
get some 7m plugs and solder them on Cool
MR 1JZ
Re: swapping 1g injector plugs to fit 7m injectors? Thu, 27 January 2005 22:18 Go to previous messageGo to next message
ill be doing the same thing very soon also Smile
do any 7M plugs fit? i.e. 7MGE?
ddeane
PNG
Re: swapping 1g injector plugs to fit 7m injectors? Thu, 27 January 2005 23:00 Go to previous messageGo to next message
Gen 2 plugs will do the trick. One would question why you are fitting 440cc injectors unless you are going to an aftermarket computer as the gen 3 will over-fuel as it is even with increased boost.
Fattony
Re: swapping 1g injector plugs to fit 7m injectors? Thu, 27 January 2005 23:04 Go to previous messageGo to next message
Gen 1 also fit. But if you dont want to hack at your injector loom, you could also just remove the locator tabs on the side of the injectors, becuase these are in a different location to the gen 3 plugs thats wats causing your problem. That all depends on if you want to hack at your injectors. I would just source some plugs that fit the 7ms. ie gen 1,2 1g of 7m plugs.
Cheers Adam
MR 1JZ
Re: swapping 1g injector plugs to fit 7m injectors? Fri, 28 January 2005 00:06 Go to previous messageGo to next message
ddeane wrote on Fri, 28 January 2005 09:30
mumuhahahaha
emanage is my friend Very Happy
along with injector and ignition harness of course
stradlater
Arthurs Creek, Victoria
Re: swapping 1g injector plugs to fit 7m injectors? Fri, 28 January 2005 00:08 Go to previous messageGo to next message
Honestly Fattony, you should know better, LPG is the only way to go, no injector problems then. Wink
Fattony
Re: swapping 1g injector plugs to fit 7m injectors? Fri, 28 January 2005 02:04 Go to previous messageGo to next message
LOL Strad only when the o-rings on the injectors your using to plug the holes give way lol
stradlater
Re: swapping 1g injector plugs to fit 7m injectors? Fri, 28 January 2005 03:08 Go to previous message
This is true..... Very true. hrm.. Lousy House PLANT!
Previous Topic:81 Hilux 1ggte conversion
Next Topic:1JZGTE budget upgrade path
Current Time: Sat Oct 31 13:35:01 UTC 2026
Total time taken to generate the page: 0.097949028015137 seconds
