Toymods » Tech & Conversions » Conversion Queries
freakysoarer
Conversion Queries Fri, 28 January 2005 11:25 Go to next message
Guys,
Just need to clear some grey areas...
The car in question is a JZZ31 2JZ-GE Soarer.
Front-Cut will be from a JZA80 Supra 2JZ-GTE, manual or auto still undecided as I will have to look into the total cost in the two.
The mechanical side should not pose any major problems other than the gearbox fitting depending on the gearbox chosen.
As the car does not have the usual ABS, EMV, TRC... etc(only aircon), what hassles would present itself in the electrical side of things?
Can the donor ecu from the supra be able to hook up to everything, i.e the dash? (With wiring diagrams of course)
Or is an aftermarket system the only way to go?
Re: Conversion Queries Fri, 28 January 2005 16:56 Go to previous messageGo to next message
The wiring is actually quite easy once you've removed all the stuff you don't want (ABS, trac etc). There's only half a dozen wires you need to splice into the dash, and other stuff like power to the ECU, ignition relay, fuel pump relay etc, but the vast majority of the wiring is between the engine and the ECU which you don't need to touch. If you have the wiring diagrams for both cars it won't be a drama - it takes plenty of time and patience, but it's not rocket science. Smile
FWIW I put a 2JZ-GTE in an MA61 Supra (I've actually done it twice now) and obviously I didn't keep all the electronic extras... just the ECU itself and a few outputs for the dash is all that remains. Smile
freakysoarer
Re: Conversion Queries Sun, 30 January 2005 02:07 Go to previous messageGo to next message
Thats the answer I was looking for.
Thanks...
I guess to keep the overall costs down, I will opt out of the getrag and keep the auto, I do enjoy the laziness...
How does the supra/aristo auto differ from my auto?
Now to consolidate my funds and look for a auto GTE halfcut in Japan.
By the way, this may seem stupid but...
If I fit the 4 pods at the front from the halfcut, would the 2 pods I have now go at the back?
Sorry if its a stupid question.
[Updated on: Sun, 30 January 2005 02:09]
Re: Conversion Queries Sun, 30 January 2005 03:28 Go to previous messageGo to next message
The auto should be very similar, although I'm not sure if it attaches to the tailshaft in the same way. Does your box use a yoke or a flange?
And no, you can't put your front calipers on the back.
freakysoarer
Re: Conversion Queries Sun, 30 January 2005 08:07 Go to previous messageGo to next message
Ok. In that case, would a 4 pod front and a 1 pod back work(as in braking balance)? Or must I source a 2 pod rear from a supra?
about the auto, what i wana know is that would the halfcut A340E be stronger as its from a TT? and is it possible to use my old auto without worries.
Thanks for the valuable info so far Norbie.
[Updated on: Sun, 30 January 2005 08:13]
Re: Conversion Queries Sun, 30 January 2005 12:34 Go to previous message
There should be no problems upgrading only the front brakes. I just upgraded the single-piston front calipers in my Supra to 4-piston and left the stock rear calipers... no problems whatsoever.
Yes the TT box is definitely stronger than your NA box. I wouldn't recommend using an NA box behind a turbo engine.
Previous Topic:omfg... how frustrating [AE86]
Next Topic:leaking w58 box
Current Time: Sun Oct 25 22:55:19 UTC 2026
Total time taken to generate the page: 0.023698091506958 seconds
