Toymods » Tech & Conversions » ok monitor light?
cooter
perth
ok monitor light? Fri, 28 January 2005 14:03 Go to next message
hey this may sound really dumb to yous but ive got a te71 levin and its got a little light on the dash thats alwas on. it says ok monitor on it. is it to obvious to think that it goes off when somethings not ok? please help its been annoying me since i got the car cause i dont know what it does
craig
Lambolica
Northwestern Sydney
Re: ok monitor light? Sat, 29 January 2005 01:15 Go to previous messageGo to next message
OK, I'm not an expert on this monitor however i am looking for the parts at the moment. The OK (or ESP) computer basically monitors several areas of the car an alerts you if somthing is out of place. (I would assume that if the light is on that there is somthing wrong) The OK computer can monitor (depending on car) things like radiator fluid levels - brake fluid levels - brake pad wear - oil pressure - washer water level - Condition of CAT and things like that. Speaking to people that have them it seems that they never work and that is possibly due to somthing aftermarket being put in ( like an exhaust system) that doesn't work with the monitor thus it is always on.
Not much help but this is the information I can offer.
TA22 GT
Re: ok monitor light? Sat, 29 January 2005 12:27 Go to previous messageGo to next message
I have an ok monitor in my TA22 GT. It has 6 warning lights for things similar to above.
I've never seen an ok monitor light on the dash, maybe the ok monitor itself was removed from your car and hence your warning light is on.
You could just take the globe out and forget about it,...
Simon
Lambolica
Northwestern Sydney
Re: ok monitor light? Sun, 30 January 2005 04:07 Go to previous messageGo to next message
Simon,
The RA28 onwards have a single light in the dash just below the stereo as opposed to the roof mount setup that RA25 TA22/27 came with (not 100% about RA23's)
There also appears to be a rotary knob in some schematic I have that ( I would say ) select the area the you want to monitor.
Give me a few months to collect the parts and I'll tell you but otherwise get hold of someone in the US where the RA29 GT's have them.
deeps
Re: ok monitor light? Thu, 05 May 2005 12:44 Go to previous message
had one on my old 78model corona import.
it not only had a light, had a dot matrix type display, which said wat the problem was
it could check all lights around the car, battery fluid, brakes, and radiator fluid.
for some reason the battery one was always the biggest problem, even though there was always fluid in the battery.
oh, check if your battery has a wire going itno it via one of those holes in it. if not, look around for a wire, that's the wire that tells it how much fluid it has in it.
or just short it out.
Previous Topic:HELP PLZ:AE86 4AGE Air filter
Next Topic:injectors 4age
Current Time: Fri Oct 23 03:02:17 UTC 2026
Total time taken to generate the page: 0.0047109127044678 seconds
