Toymods » Tech & Conversions » Question about the 5M-E ECU.
ZZT231
melbourne.vic.au
Question about the 5M-E ECU. Sat, 29 January 2005 02:02 Go to next message
Hey All,
On the side of the old ECU's (in my case 5M-E) there are 2 screw holes with gum covered over it, does anyone know what the 2 adjustments do for the ECU?
Cheers.
wilbo666
Re: Question about the 5M-E ECU. Sat, 29 January 2005 03:11 Go to previous messageGo to next message
Can you take a pic of what ur talking about? lol
I can't be stuffed getting an ecu out to take apart Smile
ZZT231
melbourne.vic.au
Re: Question about the 5M-E ECU. Sat, 29 January 2005 03:22 Go to previous messageGo to next message
http://img.photobucket.com/albums/v466/CelicaSupra/DSC00806.jpg
on the right side of the ECU (seen as a thingy attached to the side wall of the ECU), there is 2 small holes gummed up with silicon/putty where you can put a small phillips head screw driver and adjust something...
Does any have a clue what it does?
Cheers.
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: Question about the 5M-E ECU. Sat, 29 January 2005 04:01 Go to previous messageGo to next message
Those screws are not for adjustment, they are clamping an output transistor (injectors most likely) to the casing for heat dissapation.
From what I can see on that board, there is no adjustability.
EDIT: Plz take a side shot, just so I can confirm.
[Updated on: Sat, 29 January 2005 04:03]
wilbo666
Re: Question about the 5M-E ECU. Sat, 29 January 2005 04:06 Go to previous messageGo to next message
yep, as said above, it is used to clamp the driving FET to the case to cool it Smile
ZZT231
melbourne.vic.au
Re: Question about the 5M-E ECU. Sat, 29 January 2005 04:11 Go to previous messageGo to next message
Sorry Viper, can't take a photo at the moment as my Digital Camera is 6000kms away from where I am (overseas on duty Very Happy)
But it will arrive tomorrow and i'll take more happy snaps of the ECU...
Cheers.
Re: Question about the 5M-E ECU. Sat, 29 January 2005 06:26 Go to previous messageGo to next message
i wouldn't bother keeping open your ECU and photgraphing it - there is nothing adjustable. zip. nadda.
ZZT231
melbourne.vic.au
Re: Question about the 5M-E ECU. Sat, 29 January 2005 10:04 Go to previous messageGo to next message
No problems Embarassed
Does anyone know if the USA grade of petrol is similar to Australia or that they are different by a bit... Using the USA ECU the 5M-E runs laggy and slow.
Cheers.
Re: Question about the 5M-E ECU. Sat, 29 January 2005 11:02 Go to previous messageGo to next message
i thought "slow and laggy" was a factory-built feature of the engine? Laughing
you could try to increase the static ignition advance as well (and disconnect any emissions-control vacuum-advance control)... i did this without major harm to the engine - so the only vacuum line to the dizzi is from the plenum.
USA runs similar petrol to us - i can't see this being an issue?
[Updated on: Sat, 29 January 2005 11:02]
ZZT231
melbourne.vic.au
Re: Question about the 5M-E ECU. Sat, 29 January 2005 11:26 Go to previous messageGo to next message
I am running 16D TDC because of the premium unleaded... It runs great with the Aussie ECU in it but when I just plug in the USA ECU, it goes like crap and when you push it. It lags big time. I just have to wake up tomorrow early and try again...
Cheers.
ZZT231
melbourne.vic.au
Re: Question about the 5M-E ECU. Sat, 29 January 2005 11:28 Go to previous messageGo to next message
thechuckster wrote on Sat, 29 January 2005 22:02
i thought "slow and laggy" was a factory-built feature of the engine? Laughing...
Oh and I forgot... Remember that it's (very) inefficient Laughing
boxh34d
wangaratta
Re: Question about the 5M-E ECU. Sat, 29 January 2005 11:30 Go to previous messageGo to next message
i was under the impression that the USA ECU had worse tuning than ours.
the info i have seen points towards their 5ME's having even less power ( thats right, there is such a thing Razz ) than ours. . .
can anyone confirm this??
ZZT231
melbourne.vic.au
Re: Question about the 5M-E ECU. Sat, 29 January 2005 11:52 Go to previous messageGo to next message
I thought it was based on the quality of the fuel... Tomorrow I am going to retard the timing back to 8D TDC (on premium) and see how it will drive... Would it be detrimental to my motor if I do that?
Cheers.
Re: Question about the 5M-E ECU. Sat, 29 January 2005 12:24 Go to previous messageGo to next message
mine runs much higher - around 15 degrees BTDC at idle i think.
there's not much rotation left on the clamp on the side of the dizzi.
you'll improve things slightly (at the expence of harder cold starting and increased risk of pining/detonation) if you up the timing advance, not retard it.
ZZT231
melbourne.vic.au
Re: Question about the 5M-E ECU. Sat, 29 January 2005 12:50 Go to previous message
thechuckster wrote on Sat, 29 January 2005 23:24
If you have a 5M-E Remember to disconnect the 2 vaccum pipes and plug them up when you are tuning the car...
I'll retard to 8D BTDC the car tomorrow...
Cheers.
Previous Topic:1g or 1jz
Next Topic:ke20 tyres
Current Time: Mon Oct 19 15:48:55 UTC 2026
Total time taken to generate the page: 0.0064949989318848 seconds
