Toymods » Tech & Conversions » EOI.. 7a limits
mrf_ool
Taree (4 hrs north of syd...
EOI.. 7a limits Sat, 29 January 2005 08:50 Go to next message
read ones going to 1.9.just thinking if i every win lotto .thought about building a 2litre 7ag . maybe with a 20v head in n/a form. nothing to extreme that it would blow up 2 months done the track . its good to dream.i'm guessing maybe 10 grand after buying the block and head stuff. but we'll see what experts have to say . because im not one if i was i wouldn't be asking Very Happy
Re: EOI.. 7a limits Sat, 29 January 2005 09:58 Go to previous messageGo to next message
i dont know if you could actually get the 7a out to 2L - that would be a LOT of stroking, as the 7A block has no room left to bore it out any real amount.
I'll just put the notion forward that i dont think it will happen.
mrf_ool
Re: EOI.. 7a limits Sat, 29 January 2005 10:30 Go to previous messageGo to next message
o no my dreams are crushed.... if thats true . i have seen a rb26 with a thick spacer to make it a 3L as they didnt get many rb30 if not any in the holy land. would this be possible.guess they would have shimed it or something.
[Updated on: Sat, 29 January 2005 10:34]
jasonp1977
Re: EOI.. 7a limits Sat, 29 January 2005 12:04 Go to previous messageGo to next message
http://www.speedracersportscars.com.au/stroker.htm
mrf_ool
Re: EOI.. 7a limits Sat, 29 January 2005 12:18 Go to previous messageGo to next message
been there seen the site
tin can
Re: EOI.. 7a limits Sat, 29 January 2005 13:08 Go to previous messageGo to next message
im still trying to find rods that well fit and that are long and fat for the jobb
any ideas i knoe liteace rods are the same and thats a 7k motor i woulder what would be same as those but stronger with out going custom
HyDrA
Adelaide, SA
Re: EOI.. 7a limits Sat, 29 January 2005 13:16 Go to previous messageGo to next message
I know it's one of those "i'll do it because I can" things, but wouldn't you be better off starting with a 3s-g(t)e?
Re: EOI.. 7a limits Sat, 29 January 2005 13:26 Go to previous messageGo to next message
tin can wrote on Sun, 30 January 2005 00:08
7K has same rods as 7A? hmmmmm.... thats very interesting!!!
wonder how much longer they are than 4K rods, along the lines of using them with a lower pin height piston in a 4K..
Re: EOI.. 7a limits Sat, 29 January 2005 13:27 Go to previous messageGo to next message
mrf_ool wrote on Sat, 29 January 2005 19:50
for 10 grand? buy a beams 3SGE. it's 2L already and abotu as much as you could get from a 2L NS anyway...
tin can
Re: EOI.. 7a limits Sat, 29 January 2005 13:39 Go to previous messageGo to next message
its jess from toyota man i got that ae86 tank gasket for u
and the rods are the same as a 7ke motor out of the lite ace townace i looked uop at work
so now all i have to do is call up toyota and tel them to find me rods that are wider than 7a but have the same crake bearing size and same size as gudeon pin (pistons from a 4a soounds good)
Re: EOI.. 7a limits Sat, 29 January 2005 13:45 Go to previous messageGo to next message
tin can wrote on Sun, 30 January 2005 00:39
yar, recognised your nick Smile
hmmmm, i know i should look this up, but whats the length of a 7K rod?
hmm, 7KE is 80.5mm bore (same as 5K) and 87.5mm stroke, which is 11.5mm more than 4K/5K stroke...
maybe it's same length as a 4K rod?? hmmmmmmmmmmmmm
oh, want me to drop around sometime with my injected KE15? Wink runs nicely now.. just need to sort out programmable ignition Very Happy
tin can
Re: EOI.. 7a limits Sat, 29 January 2005 13:53 Go to previous messageGo to next message
well if it 11.5mm long its not going to work up if u can bolt up a 4k head to a 7k block whats stoping u
are u running injectoin in the ke15 if u are i can help u out with that i no some one that does comp halteck and all that if u want drop around tomrrow at about 12.30
Re: EOI.. 7a limits Sat, 29 January 2005 13:57 Go to previous messageGo to next message
heh heh, well.. lack of a 7K block.. not wanting to have to get engineered for a K series motor Wink and basically, because i'm just playing with the 4K until i go OS..
i have a Megasquirt running the fuel atm, and i have a few spark options, including the new MS2 processor Wink
all i need is either a VR "zero crossing detector", or a toyota VAST ignitor, to go with my new 4KE elec dizzy...
after that it should be easy Very Happy
or i could put an EDIS4 on and have waste spark...
but we have digressed off topic somewhat Wink
hmm, tomorrow i'm sorting out 4 cars i have to be removed Sad
tin can
Re: EOI.. 7a limits Sat, 29 January 2005 14:07 Go to previous messageGo to next message
what cars are going man any that are usable
whats ur msn addy
mrf_ool
Re: EOI.. 7a limits Sun, 30 January 2005 03:54 Go to previous messageGo to next message
o.k .. now we are talking about a 7k .. back to the 7a so 1.9 is the biggest it will go.? well o.k dont want to go a 3s as its just a dream. what would be the weight difference between the 3s and a 4a ?
[Updated on: Sun, 30 January 2005 03:57]
Re: EOI.. 7a limits Sun, 30 January 2005 07:28 Go to previous messageGo to next message
fool, the point was that 7K and 7A rods are the same. 7K is 1.8L, 7A is 1.8L.
3S is significantly heavier (is it 50kg?)
if this is just a dream, move it to general car talk Razz heh heh
mrf_ool
Re: EOI.. 7a limits Sun, 30 January 2005 08:23 Go to previous messageGo to next message
o.k this still a tech section.well how about all custom stuff still only gets us a 1.9 doesnt it.read some where a billet crank was 3 grand?..
slydar
Re: EOI.. 7a limits Sun, 30 January 2005 09:56 Go to previous messageGo to next message
ive heard it mentioned on a u.s forum that there is a particular BMW rod that will work.
as far as going to 2l with a 7a, i have no idea... but whats the point? stroking an engine too far reduces the rod ratio, which cost you power, you might find 1800ccs and a few more revs will make more power than going for a big stretch.
i would say go as far as you can with the standard crank, maybe even ofset grind it a little to suit a differant OE conrod.
anyway, much more knowlegeable people have commented in this thread, just thought i'd mention the bmw rods..
mrf_ool
Re: EOI.. 7a limits Sun, 30 January 2005 10:45 Go to previous messageGo to next message
o.k . how about a worked 7a N/A ofcourse with the offset grind. with a 20v head then. what r we looking at aftermarket computer injecters to suit and maybe custom intake or maybe the quads.this could happen.
tin can
Re: EOI.. 7a limits Sun, 30 January 2005 12:30 Go to previous messageGo to next message
pls tell why are u using a 20v head thay dont flow more thw a bigg port 16v
if u have a 20v setting there then use it but imo i would use a 16v head im using one on mine and plus u could go bigger cams to i have yet to find aftermaket 20v cams
custom intake mani why ur using a 20v head have a set of trumpets with sock on em
another thing slydar ufound somewhere that there using bmw rods in a 7a could u pls find the site a post it up thanks
well thats my 2c
thanks jess
mrf_ool
Re: EOI.. 7a limits Sun, 30 January 2005 12:43 Go to previous messageGo to next message
o.k then . i dont have a 20v head but have a big port that dont thinks going to last another yr.well yeah i could add cams to my list too.
tin can
Re: EOI.. 7a limits Sun, 30 January 2005 12:54 Go to previous messageGo to next message
why isnt ur bigg portt head going to last a nother year wgat wrong with it
mrf_ool
Re: EOI.. 7a limits Sun, 30 January 2005 13:09 Go to previous messageGo to next message
i ment my whole motor as its starting to leak.. that stuff from texas. ( oil).
tin can
Re: EOI.. 7a limits Mon, 31 January 2005 04:08 Go to previous messageGo to next message
then what i would do is get the head fixed and use the 7a bottom end
mrf_ool
Re: EOI.. 7a limits Mon, 31 January 2005 10:27 Go to previous messageGo to next message
heads o.k its head gasket i think and cam seals.looks like i bought half the business where i work so it might be happening
tin can
Re: EOI.. 7a limits Mon, 31 January 2005 10:47 Go to previous messageGo to next message
are u planning to go turbo or n/a if turbo gota get rods and if n/a deck the head and deck the block up the comp son get some cams somthing like 272 or a lil smaller gze injectors even a stocker 4age headgasket 1.6 mm and i think that would get u going another thing this is all going in the a sprinter right how the hell is it going to fit the hieght of the moto is quiet (spelling)high i think the inlet many wellhit the bonnet
mrf_ool
Re: EOI.. 7a limits Mon, 31 January 2005 11:00 Go to previous messageGo to next message
its going n/a and ill have to get a custom intake than wont i am using a modded fwd anyway.
tin can
Re: EOI.. 7a limits Mon, 31 January 2005 11:11 Go to previous messageGo to next message
did u want to sell ur modded fwd mani
mayby measure the hole moto and raise the bonnet
mrf_ool
Re: EOI.. 7a limits Mon, 31 January 2005 11:24 Go to previous messageGo to next message
still using the intake maybe after could always cut big hole and make a big bulge on the bonnet
tin can
Re: EOI.. 7a limits Mon, 31 January 2005 11:34 Go to previous messageGo to next message
man if thats ur sprinter in the pick PLS PLS PLS dont do it ull reck it just raise the bonnet
mrf_ool
Re: EOI.. 7a limits Mon, 31 January 2005 11:53 Go to previous message
o.k . i wont do it.
Previous Topic:fuel pump location ST162
Next Topic:leaking solex's
Current Time: Fri Nov 20 06:14:46 UTC 2026
Total time taken to generate the page: 0.0083889961242676 seconds
