Toymods » Tech & Conversions » setting up 4k
oldskulwagon
san jose, kali
icon5.gif  setting up 4k Sat, 29 January 2005 10:39 Go to next message
sorry if this was posted b4. I tried the search function but have had no luck.
I read somewhere that someone set up a 4k using Daihatsu pistons.
Can I get details on which engine the piston came from and what size they used.
Thanks in advance for any help.
Re: setting up 4k Sat, 29 January 2005 13:22 Go to previous messageGo to next message
hmm. you're clutching at straws...
afaik, it's not common knowledge, but i would like to know Smile
try looking thru the ACL catalogue..
problem i see is that you really need a pistons with lower pin height to make it worth it. and for that you need longer rods...
Re: setting up 4k Sat, 29 January 2005 13:23 Go to previous messageGo to next message
doesn't the daihatsu charmant have a 4K motor anyway?
Toycrash
Finland
Re: setting up 4k Sat, 29 January 2005 18:05 Go to previous messageGo to next message
oldcorollas wrote on Sun, 30 January 2005 00:23
Yes. 4K and T40/50 tranny Wink
oldskulwagon
san jose, kali
Re: setting up 4k Sun, 30 January 2005 07:15 Go to previous messageGo to next message
That is what we are trying to figure out. We did that before in my 3k, we used Mitsu pistons and 4k rods but this time my bud used a 4k block and wanted to see if he can use 7k rods.
The motor was set up with 5k pistons and the block cracked, he was thinking of sleeving the bores so we wanted to try a different piston, just to be safe.
Thanks for the replies. Is there an online catalog for ACL?
Re: setting up 4k Sun, 30 January 2005 07:22 Go to previous messageGo to next message
yes there is.. well you haev to download it...
4K can only safely be bored maybe 2mm.. the 3K blocks can go 3 or even 4mm at a pinch (the old tosco pistons were 78/79mm).
5K block is a bored 4K anyway, so why bother with the 4K block?
what about 5K block with 4AG pistons?
oldskulwagon
san jose, kali
Re: setting up 4k Sun, 30 January 2005 07:31 Go to previous messageGo to next message
Hehehe, I am on vac here in the Philippines. Surplus engines are too expensive now. We have to make do with what we have plus a 5k block kills our chances at the night races.
Yeah 79mm is where my buddy wants to stay. IIRC 5k pistons are 80.5mm
BTW what cams do you guys use for drag?
Re: setting up 4k Sun, 30 January 2005 07:34 Go to previous messageGo to next message
3K block, 4K crank (have to gring out things a bit), 79mm pistons, shorter rods (or same rods but lower pin height pistons).
the 4K blocks have thinner walls than 3K, so can't be bored out as much.
for drag? my cam seems to be really good between 6000 and 8000 atm.. it's a camtech 609, ie 275/284, 231/235@50thou, 435thou lift.
any more duration and you move power band too high.
oldskulwagon
san jose, kali
Re: setting up 4k Mon, 31 January 2005 10:28 Go to previous messageGo to next message
Do they regrind stock cams or they grind it from new billets? Do you have an email addy for them?
thanks again for the help.
Re: setting up 4k Tue, 01 February 2005 10:53 Go to previous messageGo to next message
i prefer to get cams made with a smaller base circle, so that with the increased lift, machined rocker towers, everything seems to line up nicely..
ummmm
Camtech Australia Pty Ltd
(Camshaft Sales) Unit 15/ 20 Alfred Rd Chipping Norton 2170 (02) 9755 3101
Fax (02) 9755 3144
Redwarf
February 2005
Re: setting up 4k Tue, 01 February 2005 11:54 Go to previous message
I have Charade pistons in my 3K, for one reason or another that I won't go into at the moment. They are a bit of screwing around to make them fit. Not a bolt in job, and not immediately compatible to K rods of any type.
R
Previous Topic:ta22 tacho question
Next Topic:help guys1 my Turbo is on its way out
Current Time: Fri Oct 23 23:58:30 UTC 2026
Total time taken to generate the page: 0.006274938583374 seconds
