Toymods » Tech & Conversions » gt amps/oil guage - NEED HELP !
Classique71
Colac, Victoria
gt amps/oil guage - NEED HELP ! Fri, 25 October 2002 09:04 Go to next message
heys
just got a ta22 gt amps/oil pressure guage - and i want to swap it into my car , but no wiring to go with it - and its different at the back than the standard lights setup
I have the existing idiot light setup in it for oil and power , ..
What do i need to get it all up and running , ie analogue oil pressure sender from what ? and do i need anything fancy to get the battery hooked up with the guage without frying it ??
Any assistance pleeze
kerr
Re: gt amps/oil guage - NEED HELP ! Fri, 25 October 2002 10:43 Go to previous messageGo to next message
Try this thread.
http://www.toymods.org.au/msgboard/index.php?t=msg &th=5579&rid=305&S=7587880123727df5b94 9406cafdd9e58
Classique71
Colac, Victoria
Re: gt amps/oil guage - NEED HELP ! Sat, 26 October 2002 10:52 Go to previous messageGo to next message
thanks Smile
seems the wirings pretty straight forward for a car sparky ( need a few other things done as well to dash so ill get it installed then ) buuuuut - does it work with the standard 2t oil pressure sender - or do i need to source another - AAND - is there any specific wiry things i need to hook amps side of things up to the battery - i dont want the thing to go zap - if fuses / resistors are needed also - im not trhat cluey with electronics
Re: gt amps/oil guage - NEED HELP ! Sat, 26 October 2002 11:10 Go to previous messageGo to next message
The standard 2t oil pressure sender wont do the job! The standard item is just a simple on/off job so it wont work!
Sorry thats all I can tell you!
Classique71
Colac, Victoria
Re: gt amps/oil guage - NEED HELP ! Sat, 26 October 2002 11:12 Go to previous messageGo to next message
didnt think it did - hence ask - i believe a 3sge celica sender works though ???
luckily i believe they have the same thread - and the wiring wouldwirtually be the same ( one wire in ) unless im wrong
Re: gt amps/oil guage - NEED HELP ! Sat, 26 October 2002 11:19 Go to previous messageGo to next message
Its only a resistance setup so any analogue gauge sender will work! But you will need one that is calibrated for that gauge!
Classique71
Colac, Victoria
Re: gt amps/oil guage - NEED HELP ! Sat, 26 October 2002 11:34 Go to previous messageGo to next message
can you get one off another car to calibrate ?? - or am i barking up the wrong tree ?
Re: gt amps/oil guage - NEED HELP ! Sat, 26 October 2002 14:10 Go to previous messageGo to next message
The senders that I have seen I dont think can be calibrated! Although thinking about it I reckon it would be possible by just adding a resistor, but you would nee something to calibrate it to! Another gauge that doesn't use a sender would be a good start! Would just be a matter of using a T peice and fitting the the other gauge!
I hope you understand what I mean cause its a little late/early, whatever Rolling Eyes
juzzo84
Hornsby, N.S.W
icon12.gif  Re: gt amps/oil guage - NEED HELP ! Sun, 27 October 2002 01:29 Go to previous message
YO classique, im after a oil pressure sender still, so if you find one, please let me know, and i will get my hands on one also.
THANKS MAN
JUZZO
0413461518
Previous Topic:half cut vs engine parts, and 2jz vs 1jz
Next Topic:7M-GE Cam Seals Leaky
Current Time: Sat Oct 31 19:06:35 UTC 2026
Total time taken to generate the page: 0.016822099685669 seconds
