Toymods » Tech & Conversions » Brake upgrade for FWD corolla
yolk
Brake upgrade for FWD corolla Sun, 30 January 2005 02:06 Go to next message
Just wondering which brake setup would be more efficient/effective for normal road use/track usage and spirited driving.
1. Levin single pot with
- rotor size 255mm x 22mm
- aftermarket brake pads (endless, ebc and the likes)
- aftermarket rotor 22mm thickness (dba slotted rotor)
- steel braided brake hoses (goodridge)
- 5.1 brake oil
Levin twin pot with original twinpot rotor skimmed to 255mm (diameter)
- rotor size 255mm x 25mm
- 5.1 brake oil
The twin pot is basically of the superstrut levin ae101 modified to fit mcpherson. Any ideas ?
[Updated on: Sun, 30 January 2005 02:46]
Lucid
Toymods Club Secretary
Re: Brake upgrade for FWD corolla Sun, 30 January 2005 04:34 Go to previous messageGo to next message
They look like basically the same setup aside from the different calipers (which if I'm not mistaken are the same volume anyway) and the slightly thicker discs..
This article (if you haven't already seen it) might give you some good ideas. Of particular note is the fact that you may not need to machine the discs (in your second option) down quite as far if you're going to be running 15" or larger wheels..
Your second option is basically what I PLAN on doing when I finally get around to it, although I'd be wanting to try and keep the discs as large a diameter as possible.
[Updated on: Sun, 30 January 2005 04:36]
yolk
Re: Brake upgrade for FWD corolla Sun, 30 January 2005 08:38 Go to previous messageGo to next message
sorry my bad actually the disc currently is machined down to about 260mm and the article suggests 262mm so i don't think 2mm is going to make that big of a difference. Also the reason I am asking this is basically is it better to get higher temp rotors to be used with high temp brakes pads or is the stock rotor sufficient enough even though stock rotor temperature rating will be lower than those of say the DBA rotors.
towe_001
Somewhere on a dirt bowl ...
Re: Brake upgrade for FWD corolla Sun, 30 January 2005 12:31 Go to previous messageGo to next message
Question - Where did you get this rotor temp rating thing from ?
The temp rating is normally to do with the pads more then anything.
yolk
Re: Brake upgrade for FWD corolla Mon, 31 January 2005 01:39 Go to previous message
If you head over to DBA website and read about the thermo-graphic temperature monitoring feature you can see that their rotor have higher temp rating but that is applicapble for the 4000 & 5000 series rotors. Haven't found the exact rating for the DBA slotted yet but a friend told me it should be around the 500deg range.
DBA - thermo-graphic temperature monitoring
[Updated on: Mon, 31 January 2005 01:41]
Previous Topic:WHAT gearbox IS this!>>!
Next Topic:t-50 gearstick spring
Current Time: Tue Oct 20 22:56:10 UTC 2026
Total time taken to generate the page: 0.0041167736053467 seconds
