Toymods » Tech & Conversions » Maintenace Q's (Batt, Fuel Filter ect) OH and brakes!
ReQuieM
Maintenace Q's (Batt, Fuel Filter ect) OH and brakes! Sun, 30 January 2005 06:22 Go to next message
Sorry this is quite a bit non toy stuff but i thought what the hey some one here will prolly know!
My girlfriend just got her Daewoo Lanos serviced and the toolies down the work shop were gonna charge her 56 for a new fuel filter, 96 for a battery and 380 for 2 new rotors and pads for the front brakes. So me being a bit car handy (or wanting to be! Razz ) told her stuff that i could do most of that (minus the brake with out a bit more know how any hoo). thats where it starts, i cant seam to find a fuel filter to suit theres jack all about daewoos full stop realy! SO can any one tell me:
What type of fuel fiter will i need? (or a url that deals with it) and also the possi of it? (i havent bothered to look yet as i only found out yesterday.
AND what battery can i get away with? the only one listed seams to be 90 odd any way which seams stupid seing as i got one for 50-60 for the crown i used to have!
OH and while i'm at is any one know of a good melb brake joint? cheap is better for her i think! Smile
Thanx
and sorry for any/all stupid Q's and no toyota content! Evil or Very Mad
alex_ta22
Newcastle, Hunter Valley
Re: Maintenace Q's (Batt, Fuel Filter ect) OH and brakes! Sun, 30 January 2005 06:41 Go to previous messageGo to next message
Being that new (guessing its a mid 90' model), the rotors probably dont need to be replaced (unless warped or grooved) they might just need to be machined which is $30 a disc. This is quite easy to do. Just unbolt the wheels and the calipers, and the disks should come off (unless there is a nut in the centre holding them to the hub)
u can probably get away with anything that will fit, dont get those cheapo ones though
just look in a parts book near the fuel filters in supercheap auto, it should be listed. to locate it just look for the fuel lines in the engine bay and follow them
ReQuieM
Re: Maintenace Q's (Batt, Fuel Filter ect) OH and brakes! Sun, 30 January 2005 06:53 Go to previous messageGo to next message
Tried 3 joints today looking in their books an all they list is an oil filter!
The mech recons the disc are worn back to under size, so i might have to replace em. I don't know how to confirm or call it BS so i'll have to go with them! Confused so disk and pad change is easy enough?
Its a 98 with 120k on it so it doesn't suprise me too much.
DJR_
Re: Maintenace Q's (Batt, Fuel Filter ect) OH and brakes! Mon, 31 January 2005 01:34 Go to previous messageGo to next message
www.rycofilters.com.au for fuel filter gives z621 for the 1.5L engine, and z479 for the 1.6L engine. About $20 or so.
The battery is more expensive than the old one because the car needs more cranking amps because of EFI. So $90 is about right. A cheap one will just die prematurely because it won't keep charge.
www.dba.com.au for the rotors gives DBA896 for the SE model and DBA891 for the SX model. They are $140 each or so at gimmecarparts.com.au so that makes about $280 plus about $50 for pads so $380 isn't too much more. Pads are DP1368/DB1368 for the 1.5L and DB1347 for the 1.6L. If you are not too mechanically minded, get someone else to put them all on for you as it's not something to go experimenting with, you'll need a torque wrench at the very least.
Try repco for your parts, their computer search is pretty good.
Re: Maintenace Q's (Batt, Fuel Filter ect) OH and brakes! Mon, 31 January 2005 08:16 Go to previous message
Do those prices above include fitting?
If so, its seems pretty fair prices too me.
Replacing a fuel filter can sometimes be a bitch.
Just make sure if they do go ahead with the work, that they don't do any more work without your authorisation.
Also, try RDA brakes, they are usually a shiteload cheaper than DBA.
Previous Topic:2ZZ-GE importers?
Next Topic:18" rims on a AE92.... how?
Current Time: Fri Nov 20 04:32:08 UTC 2026
Total time taken to generate the page: 0.02091908454895 seconds
