Toymods » Tech & Conversions » ke20 front suspension in ke10
bassy
ke20 front suspension in ke10 Sun, 30 January 2005 07:24 Go to next message
hey, would anyone know if the whole front suspension from a ke20 would fit into a ke10? im talking the whole thing, crossmember, suspension arms, stabilizer bar, strut bars etc..
thanx
Re: ke20 front suspension in ke10 Sun, 30 January 2005 07:32 Go to previous message
bassy wrote on Sun, 30 January 2005 18:24
thanx
yes but...
crossmember bolts are same width (ie chassis rails) but are 1" further apart on the same rail.
you will need to make up radius rod mounts at the front, but you might be able to bolt on KE70 mounts (with a fair bit of welding.. different shape chassis rails) struts will fit (spring wise) but strut tops are likely to be different..
steering arms are slightly longer, which may cause issues to bump steer etc. (although KE20 steering column fits also Wink )
it has been done (and also same but with RX7 struts), and i think it is worthwhile, but there is a bit of fabricating involved.
Previous Topic:Oil smells like gasoline
Next Topic:where in brisbane to buy 2tg hybrid parts
Current Time: Sat Oct 24 06:24:22 UTC 2026
Total time taken to generate the page: 0.0049080848693848 seconds
