Toymods » Tech & Conversions » Noise in R/H Front (MA70)
celicaboy_2000
Lismore, NSW
Noise in R/H Front (MA70) Sun, 30 January 2005 10:06 Go to next message
When ever I brake I get a clunk noise from the R/H front, I have checked the caliper and pads for movement and seems to be ok. Anyone have any idea's?
V8_MA61
Re: Noise in R/H Front (MA70) Sun, 30 January 2005 11:47 Go to previous messageGo to next message
nothing in th engine bay or anything?
mick
toowoomba qld
Re: Noise in R/H Front (MA70) Sun, 30 January 2005 11:55 Go to previous messageGo to next message
maybe somethings loose in the suspension?
snail
Re: Noise in R/H Front (MA70) Mon, 31 January 2005 07:55 Go to previous messageGo to next message
Ball joints?? Rack ends??
celicaboy_2000
Lismore, NSW
Re: Noise in R/H Front (MA70) Mon, 31 January 2005 08:05 Go to previous messageGo to next message
Ball joints & rack end are ok, might have to jack it up and check all the suspension bolts. Thought i'd better ask as it might of been a common problem.
More suggestions welcome. Ill let you know what I find when I fix it.
Flebbert
Wagga
Re: Noise in R/H Front (MA70) Mon, 31 January 2005 21:10 Go to previous messageGo to next message
hey,
i had a problem with my front left of my car with a bad metal on metal noise when braking hard or hitting bumps. I had mechanic check it and he tightened everything and regreased the front end. Noise gone and it is better than ever to drive. Hope that helps
phil
Azrael
Crapberra
Re: Noise in R/H Front (MA70) Tue, 01 February 2005 03:10 Go to previous messageGo to next message
I had a similar thing on my RA40, turned out the caliper had kicked off one of the anti-rattle shims. I didn't notice it at first untill I really looked at them, that's when I noticed it was missing... Might pay to check?
Az
HyDrA
Adelaide, SA
Re: Noise in R/H Front (MA70) Tue, 01 February 2005 03:42 Go to previous messageGo to next message
I have a similar problem with my GA61 atm... I suspect it's something to do with the strut or the hub, maybe the bolt that holds the bearing in place (and the hub) has undone itself a bit? Needless to say, I must fix it asap Smile
celicaboy_2000
Lismore, NSW
Re: Noise in R/H Front (MA70) Tue, 01 February 2005 07:54 Go to previous message
I checked and then double checked everything and could not find anything wrong. I removed the pads and smeared a little bit of graphite grease between the pad and caliper, seems to stopped the noise... Very Happy
Previous Topic:speedo cable on toyota!
Next Topic:Brake thickness.
Current Time: Sun Oct 18 00:15:51 UTC 2026
Total time taken to generate the page: 0.0058209896087646 seconds
