Toymods » Tech & Conversions » Changing a TA22/23 to 4AGE or 4AGZE
79rollaboy
NSW Engadine
Changing a TA22/23 to 4AGE or 4AGZE Mon, 31 January 2005 05:41 Go to next message
It seems as though this conversion would be quite simple to perform using a 22 spline gearbox and diff... Why are there little or no 4AGE celica's around???
stradlater
Arthurs Creek, Victoria
Re: Changing a TA22/23 to 4AGE or 4AGZE Mon, 31 January 2005 05:44 Go to previous messageGo to next message
Because a 1g is equally easy, and buckets more fun.
79rollaboy
NSW Engadine
Re: Changing a TA22/23 to 4AGE or 4AGZE Mon, 31 January 2005 05:52 Go to previous messageGo to next message
Care to divulge further???
stradlater
Re: Changing a TA22/23 to 4AGE or 4AGZE Mon, 31 January 2005 05:55 Go to previous messageGo to next message
xactly what you wanna know?
Re: Changing a TA22/23 to 4AGE or 4AGZE Mon, 31 January 2005 05:59 Go to previous messageGo to next message
A 2T-GEU is cheaper, easier and 95% as good as a 4A-GE. Good 2T-GEU's are getting harder to find so 4A-GE conversions may become more popular, but it's still a lot of effort compared to the results (ie a 4A-GE in a TA22 isn't exactly a rocketship).
79rollaboy
NSW Engadine
Re: Changing a TA22/23 to 4AGE or 4AGZE Mon, 31 January 2005 06:02 Go to previous messageGo to next message
in a mechanical point of view, What has to be altered/changed???
What gearbox to use?
What gearbox and engine mounts to use?
What crossmember to use?
What diff to use?
What tailshaft to use?
79rollaboy
NSW Engadine
Re: Changing a TA22/23 to 4AGE or 4AGZE Mon, 31 January 2005 06:05 Go to previous messageGo to next message
Norbie wrote on Mon, 31 January 2005 16:59
SO you think a G series is the way to go also???
stradlater
Re: Changing a TA22/23 to 4AGE or 4AGZE Mon, 31 January 2005 06:08 Go to previous messageGo to next message
A) Get and RA23, they fit easier.
You need a W58 gearbox instead of a W50
The standard gearbox mount fits with a little modification (there's about a hundred docos out there on how to do it)
The cross member mounts don't need to be changed, you just need to make sure you get the right engine side mounts
You can use the standard tailshaft and diff, they all fit.
(until you break them like I do, but you have to be extreme).
79rollaboy
NSW Engadine
Re: Changing a TA22/23 to 4AGE or 4AGZE Mon, 31 January 2005 06:12 Go to previous messageGo to next message
THanks, its just a matter of deciding what I want out of the car... and the financial aspects...
stradlater
Re: Changing a TA22/23 to 4AGE or 4AGZE Mon, 31 January 2005 06:13 Go to previous messageGo to next message
True,
But let's face it, no engine conversion is cheap.
But a mate of mine did the 1g-gte conversion into an RA23, AND got it engineered for a quick reasonable price.
79rollaboy
NSW Engadine
Re: Changing a TA22/23 to 4AGE or 4AGZE Mon, 31 January 2005 06:19 Go to previous messageGo to next message
WHat about a 4AGZE??? wouldnt that be allright???
What do 22's 23's and 28's all weigh???
Re: Changing a TA22/23 to 4AGE or 4AGZE Mon, 31 January 2005 07:55 Go to previous messageGo to next message
4A-GZE will go "alright", but not great. 1G-GTE will go in with the same amount of effort and will perform much better.
TA22: approx 950kg
RA23/28: approx 1080kg
4agte
Toronto, Downtown
Re: Changing a TA22/23 to 4AGE or 4AGZE Mon, 31 January 2005 10:57 Go to previous message
if you like corners a 4agze would be better and good condition ones can make upwards of 200kw atw on standard internals.
Previous Topic:removing 5ME injectors
Next Topic:what ecu to get for 4agze
Current Time: Fri Nov 20 04:27:18 UTC 2026
Total time taken to generate the page: 0.0067908763885498 seconds
