Toymods » Tech & Conversions » Legalities: spacer behind brake pad
boudan
Legalities: spacer behind brake pad Mon, 31 January 2005 10:22 Go to next message
Looking to add spacer behind brake pads. 4 piston caliper designed for 20mm disc spaced to suit 12mm disc.
Looking for a general yes / no before further investigation.
Thanks.
[Updated on: Mon, 31 January 2005 10:22]
styler
Re: Legalities: spacer behind brake pad Mon, 31 January 2005 10:31 Go to previous messageGo to next message
yeah interesting one...
i reckon it would need to be permanantly modified,
you wouldnt be able to use a loose spacer in case
it fell out, not that you would be doing that lol
and it probably would also have to accept standard
brake pads for the caliper, so modifying the pad -
having a spacer attached wouldnt be allowed.
the caliper would have to be modified to
suit everthing else.
hang on <goes to look for qld engineers manual>
bbaacchhyy
Re: Legalities: spacer behind brake pad Mon, 31 January 2005 10:33 Go to previous messageGo to next message
boudan wrote on Mon, 31 January 2005 20:52
Thanks.
That 4mm per side and starting to stretch it a bit. I doubt and engineer would pass it if they knew about it.
Can't you get a bnetter disc to suit and do it properly ?
Re: Legalities: spacer behind brake pad Mon, 31 January 2005 10:40 Go to previous messageGo to next message
Depending on the caliper you are using its easy.
Take the RX7 calipers for example. All you have to do is trace out the pad backing plate on some 4mm steel plate, drill some holes in it and fit it like a standard pad. Simple and has been done a billion times.
But as I said it depends on the caliper.
styler
Re: Legalities: spacer behind brake pad Mon, 31 January 2005 10:45 Go to previous messageGo to next message
brake system substitution ( design ) LG1
caliper brackets :
shall be designed to take all forces imposed
during braking - bending, mounting
mounted using original backing plate/mounting points
tapped holes must have an depth at least equal to
width
brake system substitution ( modification ) LG2
proper workmanship
welding good
fasteners correct
well thats a rough idea of it all, it does go into
more detail and a few checklist forms for the mods
so meh i dunno
[Updated on: Mon, 31 January 2005 10:48]
boudan
Re: Legalities: spacer behind brake pad Mon, 31 January 2005 11:28 Go to previous messageGo to next message
What about piston travel issue's...
by adding the spacer your effectively asking the piston to travel a distance further than original, correct?
Im not sure on distance the piston travels *scratches chin*
Re: Legalities: spacer behind brake pad Mon, 31 January 2005 11:36 Go to previous messageGo to next message
No. By adding the spacer, your making the piston travel the same as it would when using the standard rotor. Think about it.
TA-022
Glenmore Park, NSW
Re: Legalities: spacer behind brake pad Mon, 31 January 2005 11:37 Go to previous messageGo to next message
***EDIT*** due to not knowing what
the hell im going on about ***EDIT*** Very Happy
Nathan
[Updated on: Mon, 31 January 2005 12:06]
Re: Legalities: spacer behind brake pad Mon, 31 January 2005 11:45 Go to previous messageGo to next message
that's total travel of piston not travel used in a normal braking event
hydraulic piston in brakes will only retract to point where pads are not forced against disc
Re: Legalities: spacer behind brake pad Mon, 31 January 2005 13:49 Go to previous messageGo to next message
What rotor are you using?
There is usually a vented version of your solid disc.
Plus, your solid disc is gonna heat up VERY quickly with 4spot brakes when you stand on it.
Get a better disc.
toof
Re: Legalities: spacer behind brake pad Tue, 01 February 2005 08:56 Go to previous messageGo to next message
heating would be my biggest concern a 12mm disc is tiny. any half 4spot caliper will cook it in no time. surely you can find a better rotor. even if it is too larger diameter wise and get it milled down ?
boudan
Re: Legalities: spacer behind brake pad Tue, 01 February 2005 10:04 Go to previous messageGo to next message
T'was just a theorectical - gotta learn somehow.
I am actually using a 20mm vented and slotted disc
Thanks for the help Smile !
YelloRolla
On your mum!
Re: Legalities: spacer behind brake pad Tue, 01 February 2005 10:49 Go to previous messageGo to next message
cool 1 is dead correct with this. The engineer didn't even bat an eyelid at the spacers on mine. I would rather a spacer pad than to have the pistons pop out when the brake pad is worn.
I did mine with pieces of 3mm mild steel sheet (1 each side) for my HiLux 4 spotters (using 22mm disc instead of the 28mm rotors) and as stated above I copied the anti-squeal plate and made them complete with tabs that assist with the location on the back of the pad.
styler
Re: Legalities: spacer behind brake pad Tue, 01 February 2005 12:57 Go to previous messageGo to next message
a secure spacer seems like the easiest and
simplest mod to make it all work...
see what anyone else has to say?
rsdeo
Burlington, On. Canada
Re: Legalities: spacer behind brake pad Wed, 02 February 2005 23:46 Go to previous message
I made these "shims" to try out a 22mm disc in a Z32 front caliper.
http://www.ilkt.com/celicasupra/shims.jpg
Previous Topic:RA28 Front swaybar issues
Next Topic:Drive line set ups 4 ae86
Current Time: Sat Nov 21 03:09:49 UTC 2026
Total time taken to generate the page: 0.0063388347625732 seconds
