Toymods » Tech & Conversions » Timming a 3tgte
ta2272
Timming a 3tgte Mon, 31 January 2005 10:30 Go to next message
Just wondering which of the two spark plugs on cylinder one you connect the timming lighjt two, and what degrees should it be time too.
Jason
TA22 GT
Re: Timming a 3tgte Mon, 31 January 2005 12:21 Go to previous messageGo to next message
Either plug is fine as they fire at the same time on the stock ECU. Timing is 12BTDC. Disconnect the vacuum hose as usual when checking the timing.
Simon
fade-e
Re: Timming a 3tgte Mon, 31 January 2005 14:16 Go to previous messageGo to next message
jsut to add to simon, on the front of the block just above the crank pulley you should see 2 pins sticking out. the top most (or one to the right) is TDC and the lower (one to the left) is where it should be set
EDIT: if i can jsut hijack for a sec... can anyone tell me the dizzy sequence for the plugs? is it 11-33-44-22 or what?
[Updated on: Mon, 31 January 2005 14:17]
TA22 GT
Re: Timming a 3tgte Mon, 31 January 2005 22:42 Go to previous messageGo to next message
Yep, thats the dizzy sequence
Simon
styler
Re: Timming a 3tgte Tue, 01 February 2005 02:01 Go to previous messageGo to next message
i dont have a 3tgte, but why do u dissconnect
the vacumn hose? does it affect the advance at
idle or something?
fade-e
Re: Timming a 3tgte Tue, 01 February 2005 02:52 Go to previous messageGo to next message
styler wrote on Tue, 01 February 2005 13:01
idle or something?
yes... cause even at idle there is pressure being fed to the advance, although minor it does make a degree deifference and depending how you want to set it up in respect to how much advace you want and when you want it makes all the difference
ta2272
Re: Timming a 3tgte Tue, 01 February 2005 05:53 Go to previous messageGo to next message
yeh Fade e i was looking at thhe front of the motor and can only see one pin sticking out, also on the crank there are two little cutout which cut out do i put whiteout on?
TA22 GT
Re: Timming a 3tgte Tue, 01 February 2005 12:07 Go to previous messageGo to next message
Yep, theres one pin and 2 cut outs on the pulley. Line one pin with 1 cut out to get TDC and the other one is the mark for 12 BTDC.
Simon
fade-e
Re: Timming a 3tgte Tue, 01 February 2005 12:10 Go to previous messageGo to next message
OOOPS sorry mate your right! i said it the wrong way... one pin and 2 cuts so as TA22 GT said... you will find that the left cut is TDC and the right one is 12BTDC
TA22 GT
Re: Timming a 3tgte Tue, 01 February 2005 13:11 Go to previous messageGo to next message
Fadee,
BTW, the dizzy sequence is for a 3T GTE using a stock ECU. Aftermarket could get fancy and fire each plug individually.
Either way it will be 1342. If there are offset it would only be slightly, so it would still be 11 33 44 22.
the idea of twin plugs is to gain reliability and to ensure all fuel is burnt. Not real sure if it makes alot of difference as most engines are single spark and work fine.
Simon
ta2272
Re: Timming a 3tgte Wed, 02 February 2005 12:59 Go to previous messageGo to next message
Yeh i understood it as being a way to beat amision standards it helps burn it of alot better, the difference in performance is niel or next to nothing,
So two cut outs and one pin how do i know which cut out is 12dtdc.???
Also unsrue of wha it is but the car will run like shit after a fair workout (foot to the floor alot) and is quite hard to start, it has an ems computer, wondering if it could be plugs or injectors.
Jason
Sorry about my grammar was in a hurry
fade-e
Re: Timming a 3tgte Wed, 02 February 2005 13:14 Go to previous messageGo to next message
fade-e wrote on Tue, 01 February 2005 23:10
thats how... as for it going like crap after foot to floor alot you have to unde5rstand that under those conditions everything will be DAMN hot in there
ta2272
Re: Timming a 3tgte Wed, 02 February 2005 23:54 Go to previous messageGo to next message
so when the right but is 12 this is when im looking at the car from the front as as i would be in the driver seat.
Im guessing front lol.
Jason
YelloRolla
On your mum!
Re: Timming a 3tgte Thu, 03 February 2005 02:15 Go to previous messageGo to next message
yes when you face the pulley from the front of the car the one on the left is TDC and the one on the right 12deg BTDC.
As for the twin spark making no difference to performance? I would not be too quick to jump to that conclusion - the more efficient that the burn is the more torque you stand to gain - small amounts sure but non-existent? definitely not.
The way the leads are arranged is not 11 33 44 22 (although that is the firing order) they have small pads on the distributor cap next to the posts teling you whether they are 1F (1 front) or 1R (rear) etc. It goes something like 1F, 3R, 4F etc. Also to make it dead easy the factory leads are labelled too as are all of the wire dividers (to get the factory neat "no wires touching" layout).
Jase
ta2272
Re: Timming a 3tgte Fri, 04 February 2005 03:35 Go to previous messageGo to next message
ok i timed it this morning it was only about 1 to 2 mm from 12btdc, ill have to wait till tommorrow to see what sorta start it does, another question im thinking of changing spark plugs as it about to get tuned and i dont know how long they have been there for what would you guys go for. ???
Jason
YelloRolla
On your mum!
Re: Timming a 3tgte Fri, 04 February 2005 03:38 Go to previous messageGo to next message
NGK BPR5EY would be 1 recommendation.
gussyboy2
Oxenford/gold coast
Re: Timming a 3tgte Fri, 04 February 2005 06:36 Go to previous messageGo to next message
as for poor power after "foot-to-floor" - the air temp from turbo will increase so the computer will increase the fuel and u'll prob notice black smoke from exhaust. hot air is the main cause for lack of power
ta2272
Re: Timming a 3tgte Sat, 05 February 2005 01:22 Go to previous message
Yeh that was not an issue i still had power after foot to the floor just wouldnt idle nicely,\
thanks anyway
Previous Topic:ACL reference number for 4age with TVIS
Next Topic:SAFC II + AVCR + FCD HELP!
Current Time: Fri Oct 23 19:09:47 UTC 2026
Total time taken to generate the page: 0.0073299407958984 seconds
