Toymods » Tech & Conversions » help needed: crank pulley dia = boost?
feral4mr2
Bundaberg, Qld.
icon5.gif  help needed: crank pulley dia = boost? Fri, 25 October 2002 23:53 Go to next message
Freak ok, since i am not using my s/c, i am putting it on my mates VW buggy Twisted Evil , i only want to run 5 psi...
is there a formula or something that i can use to figure out what size crank pulley diameter is needed to only run it at 5 psi???
any help would be appreciated as he has someone ready to mill a crank pulley for him out of aluminium, which will have the standard VW crank and the one for the s/c in one piece...
thanks.........
Re: help needed: crank pulley dia = boost? Sat, 26 October 2002 14:18 Go to previous messageGo to next message
Hey, I put a 1g blower on my VW buggy Very Happy
Hard one to work out quite, which VW engine is it, whats done to it?
Blown86
Re: help needed: crank pulley dia = boost? Sun, 27 October 2002 09:29 Go to previous message
Roughly 145mm - 150mm diameter crank pulley will probably do.
I guess VW motor will be running around 5500rpm??
http://homepages.tig.com.au/~robs/4agze.htm
Explains a bit.
A mate builds various hot VW donks, latest one is 2.2 water cooled with an Eaton bolted straight on at 12 psi so far. Goes pretty well!! Very Happy
Previous Topic:1JZGTE into Corona
Next Topic:ajustable cam gears
Current Time: Fri Oct 30 12:19:35 UTC 2026
Total time taken to generate the page: 0.0038490295410156 seconds
