Toymods » Members Rides » Ed's MA-61 Supra
ed_ma61
Lost in the K hole
icon4.gif  Ed's MA-61 Supra Mon, 31 January 2005 12:37 Go to next message
Ed's 1984 Aust MA-61 Supra
i think this was the first time ive actually washed her since i originally painted her Rolling Eyes
http://img55.imageshack.us/img55/9161/suprafront8ah.jpg
http://img55.imageshack.us/img55/4071/supraoblique15wf.jpg
Current Engine
Mildly Modified Naturally Aspirated 7MGE 3.0L I6
engine on the stand before installation dec 2004
http://forums.toymods.org.au/index.php?t=getfile&id=9427
http://forums.toymods.org.au/index.php?t=getfile&id=9428
Makes about 250hp at the fly
Moves the supra 0-100kmh @ 5.8sec
ENGINE SPECS:
-7M-GE 3.0L 24v DOHC I6
-83.5mm bore 91.0mm stroke
-7M-GTE Block - oil squirters
-ported and polished port and chamber
-ported and matched manifolds
-custom upper manifold with cobra twin 57mm t/b
-FGK tuned mandrel exhaust manifold
-Custom machined pistons and block
-HKS 1.2mm metal head gasket
-10.7:1 static compression ratio
-bottom end: ground, balanced and polised and blueprinted
-ARP b/e fasteners
-MSD superconductor leads
-TRD clutch
-External RX7 oil cooler
Thanks to:
-Wilkins Performance Engines (Graham Wilkins)
-GT Tooling (Geoff O'Toole)
-Stuart Wilkins
-Phil Riles
-GK Tooling
-NAS Automotive
Current 'Builder' Engine
Highly Modified 2JZ-GE Naturally Aspirated 3.0L I6
Estimated fly: 340hp @ 8000rpm
2jz virgin engine on stand Dec 2004
http://forums.toymods.org.au/index.php?t=getfile&id=9430
note: the angle of the intake ports and demonstrated by the extension shaft if have set into one of them. this is the angle i will be building the ITB manifold to...
-6x 45mm GTR RB26DETT individual throttle bodies
-custom rpm tuned intake manifold
-highly ported in and ex ports w/ OS valves
-11:1 static compression ratio
-312(ish)deg cams (~246 @ 50thou) w/ 13mm lift
-1nzfe shimless 1 piece buckets
-greddy adjustable cam gears
-custom forged rods, 6mm longer rod/stroke ratio = 1.74:1
-custom short-skirt forged pistons
-custom tuned length exhaust manifold/extractors w/ 3" exhaust
-modified 7mgte cam angle sensor
-1jz/2jzgte coil-on-plug ignition coils
-balanced blueprinted crank
-modified front pulley system (no aircon or PS)
-custom lightweight cromo flywheel(6kg)
-some kind of computer system
-more shit i cant think of right now
Nissan RB26DETT R34 45mm individual throttle bodies dec 2004
http://forums.toymods.org.au/index.php?t=getfile&id=9432
milled manifold components to build ITB manifold Jan 2005
http://forums.toymods.org.au/index.php?t=getfile&id=9429
1jz/2jzgte coil-on-plug ignition coils, modified to fit the 2jzge plug gallery cover jan 2005
http://forums.toymods.org.au/index.php?t=getfile&id=9431
Current Gearbox
1997 jza80 mkiv supra w58 gearbox
-retrofitted shift yoke assembly
-custom steel yoke bush
-custom shift shift assembly: around 16-18mm longer lower pivot
In progress brakes/suspension/wheels
Front:
-326mm x 30mm WRX STI brembo rotors
-st205 gt4 4 piston calipers
-modified ms65 5 stud hubs
-ra60 struts (extra 2.5deg camber)
-BBS 17x7.5" deep dish rims
-235/45/17 tyres
-whiteline front swaybar
-kings low springs
-?shocks
Rear:
-308mm x 18mm JZZ30 toyota rear rotors
-R33 twin piston rear calipers
-custom 167mm handbrake drum assembly
-ms123 5 stud rear hub/shafts
-235/45/17 tyres
-whiteline rear swaybar
-kings low springs
-?shocks
Rear rotor mock assembly copared to stock equivalent dec 04
http://forums.toymods.org.au/index.php?t=getfile&id=9433
Rear rotor mock assembly, different view dec 04
http://forums.toymods.org.au/index.php?t=getfile&id=9434
lots more to come, give me time...
[Updated on: Sat, 01 October 2005 13:49]
ed_ma61
Lost in the K hole
Re: Ed's MA-61 Supra Mon, 31 January 2005 13:00 Go to previous messageGo to next message
Current Interior
-Sparco EVO fixed back drivers seat
-Momo Corse suede deep dish steering wheel
-Razo suede shift knob
-gutted rear seats and rear luggage areas
from infront the drivers seat nov 2004
http://forums.toymods.org.au/index.php?t=getfile&id=9435
note the rear sway bar mounted on the x-member
from behind the drivers seat looking forward nov 2004
http://forums.toymods.org.au/index.php?t=getfile&id=9436
Eventually looking to install:
-bolt in 4 point roll-over cage
-3 or 4 point harnesses D + P sides
-swap drivers seat to passenger side, and buy me a nice new EVO2 seat
-battery box relocation to behind passenger seat
rob_RA40
c'town, NSW
Re: Ed's MA-61 Supra Mon, 31 January 2005 22:33 Go to previous messageGo to next message
ed_ma61 wrote on Mon, 31 January 2005 23:37
Thanks to:
-Stuart Wilkins
-Phil Riles
-GK Tooling
-NAS Automotive
nathan No No No rob No No No
ed_ma61
Lost in the K hole
Re: Ed's MA-61 Supra Tue, 01 February 2005 00:09 Go to previous messageGo to next message
how can i leave out the folks who actually did the hard work Confused
i give to you:
ROB and NATHAN
http://www4.tpgi.com.au/users/loats/technical/ma61/images/conversion/100_0072.jpg
http://www4.tpgi.com.au/users/loats/technical/ma61/images/conversion/100_0084.jpg
http://www4.tpgi.com.au/users/loats/technical/ma61/images/conversion/100_0094.jpg
http://www4.tpgi.com.au/users/loats/technical/ma61/images/conversion/100_0104.jpg
Re: Ed's MA-61 Supra Tue, 01 February 2005 00:43 Go to previous messageGo to next message
would you look at that - its a total DONG FEST!! Laughing
Re: Ed's MA-61 Supra Tue, 01 February 2005 01:20 Go to previous messageGo to next message
FYI Ed, that 7MGE was on the stand in Dec 03, not Dec 04 !?!
Looking good though.
HyDrA
Adelaide, SA
Re: Ed's MA-61 Supra Tue, 01 February 2005 01:26 Go to previous messageGo to next message
Nice Very Happy
boxh34d
wangaratta
Re: Ed's MA-61 Supra Tue, 01 February 2005 01:42 Go to previous messageGo to next message
yaaaaaaay!!!!! Razz
i asked dr ed to keep us all posted about the progress, and he actually did Shocked
i just cant wait till this bitch gets into action with the new engine.
good luck with it all ed, its an inspiration to us all.
bbaacchhyy
Re: Ed's MA-61 Supra Tue, 01 February 2005 01:53 Go to previous messageGo to next message
About time.....
Keep up with the pics and some more of the front barkes please Very Happy
Jag7799
Re: Ed's MA-61 Supra Tue, 01 February 2005 02:03 Go to previous messageGo to next message
howcome you havent just gone and got a 1uz and tuned the crap out of?
Re: Ed's MA-61 Supra Tue, 01 February 2005 02:24 Go to previous messageGo to next message
Because 4 cams, and 32 ports, are a DICKLOAD more expensive than 2 cams, and 24 ports.
Jag7799
Re: Ed's MA-61 Supra Tue, 01 February 2005 02:33 Go to previous messageGo to next message
if your modding an n/a engine though which in turn should be a crap load more expensive than modding a turbo one, i would assume cash wouldnt be so much of an issue..
ed_ma61
Lost in the K hole
Re: Ed's MA-61 Supra Tue, 01 February 2005 03:34 Go to previous messageGo to next message
CrUZsida wrote on Tue, 01 February 2005 13:24
werd
dont forget to add 2x exhaust manifolds, a set of 8 rather than 6 throttle bodies, 32 vs 24 buckets, springs, retainers and valves... *shudders*
and also, im not sure a decent ITB setup would sit properly under the hood with decent airflow. would need a rather unko (and $$) intake system...
so, the v8 is, as i prefer to say, a FUCKLOAD more exxy than a 6. that, and i can get 2jz bit without too much issue (and can source parts from other 6cyl engines)
on top of all that, though, i think 350hp is the upper limit of what id like to be putting through the box, diff and half shafts. if i went to 4L, we'd be looking at 450hp, and im not happy with that.
ed
PS - dont assume i have infite cash. youd be suprised the budget on which the 7m, and now the 2jz were/will be built
[Updated on: Tue, 01 February 2005 03:42]
HyDrA
Adelaide, SA
Re: Ed's MA-61 Supra Tue, 01 February 2005 03:35 Go to previous messageGo to next message
inline 6's sound better than v8's Evil or Very Mad
Re: Ed's MA-61 Supra Tue, 01 February 2005 03:37 Go to previous messageGo to next message
HyDrA wrote on Tue, 01 February 2005 11:35
Yeah, in the land of backwards Rolling Eyes
ed_ma61
Lost in the K hole
Re: Ed's MA-61 Supra Tue, 01 February 2005 03:45 Go to previous messageGo to next message
big v8's can sound damn good, and the hair stand up on my neck just as much, bu theres something smoothe and 'european' about an I6 on full noise
Re: Ed's MA-61 Supra Tue, 01 February 2005 03:55 Go to previous messageGo to next message
All I can say is it better be ready in Easter when Frank and I head over.
If I get a nice cash injection between then and now (which I highly highly doubt), then the 1uz will be all cammed up.
ed_ma61
Lost in the K hole
Re: Ed's MA-61 Supra Tue, 01 February 2005 04:04 Go to previous messageGo to next message
nup, wont be working by then...
but the car will be painted and put back together Nod
maybe the wheels and brakes will be working by then too...
engine will go in around aug/sept
Re: Ed's MA-61 Supra Tue, 01 February 2005 04:08 Go to previous messageGo to next message
Bah! is all I have to say now.
HyDrA
Adelaide, SA
Re: Ed's MA-61 Supra Tue, 01 February 2005 04:16 Go to previous messageGo to next message
CrUZsida wrote on Tue, 01 February 2005 14:07
Hey don't knock the land of backwards!!
I want a V12 Sad
Re: Ed's MA-61 Supra Tue, 01 February 2005 04:57 Go to previous messageGo to next message
Can comfortably say my V8 sounds better than my 6.
bbaacchhyy
Re: Ed's MA-61 Supra Tue, 01 February 2005 05:21 Go to previous messageGo to next message
ed_ma61 wrote on Tue, 01 February 2005 14:15
The same can be said for something like a BDA with 48mm Webers at about 9,500 rpm Nod Nod Nod Nod
ed_ma61
Lost in the K hole
Re: Ed's MA-61 Supra Tue, 01 February 2005 06:42 Go to previous messageGo to next message
gianttomato wrote on Tue, 01 February 2005 15:57
but your 6 iz teh soft az bro
ZZT231
melbourne.vic.au
Re: Ed's MA-61 Supra Tue, 01 February 2005 14:02 Go to previous messageGo to next message
Hurray! You updated your car details... that 7M looks mean with all those mods... and the 2JZ... Well it's going to be an animal...
chrisss
melb
Re: Ed's MA-61 Supra Thu, 03 February 2005 10:03 Go to previous messageGo to next message
hey ed, is this the same engine as you had a while ago or have you rebuilt it again??how is it different to before?
u using the stock cams still?? and you werent u having fuel/ignition probs with the factory ecu and your old setup?? have you opted for a programable ecu..or did u resolve the old issues??
u had it dynoed?
5.8 sounds quick....how quick u think it would be with a completely stock 7mge??
TheStitt
Membership Secretary
Re: Ed's MA-61 Supra Tue, 08 February 2005 21:57 Go to previous messageGo to next message
That thing was a weapon with the 7m in it, with that 2J its going to be fucking insane.
Good luck with it ed, and keep us posted
ed_ma61
Lost in the K hole
Re: Ed's MA-61 Supra Sun, 27 March 2005 15:45 Go to previous messageGo to next message
more pics:
http://www4.tpg.com.au/users/loats/images/Image0007.jpg
http://www4.tpg.com.au/users/loats/images/Image0008.jpg
Re: Ed's MA-61 Supra Mon, 28 March 2005 00:39 Go to previous messageGo to next message
Once again, the more times I see the pics, the more I think about how unhappy I am with what they've done. Ah well, looking good anyways mate.
Hows the 2JZ going?
Re: Ed's MA-61 Supra Mon, 28 March 2005 01:56 Go to previous messageGo to next message
Love it dude
Looks the goods.
Re: Ed's MA-61 Supra Mon, 28 March 2005 01:58 Go to previous messageGo to next message
Nice work! The little red CFA trailer gives away where you got your idea for color Very Happy . Flares?
I suppose I better finish off my 2JZ otherwise I'll have my ass handed to me on a plate. Razz
ed_ma61
Lost in the K hole
Re: Ed's MA-61 Supra Mon, 28 March 2005 04:41 Go to previous messageGo to next message
justcallmefrank wrote on Mon, 28 March 2005 10:39
Hows the 2JZ going?
nathan - theres PLENTY of sins in it dude, im just not showing them off Very Happy
but to be honest, for "dodgy bros painting services", im pretty happy, so i can live with the mistakes... except one - i need to respray under the bump strip on the passenger side with clear.
i used some stone guard, and on the passenger side, it came out WAT too coarse, and looks like SHITE - need to fill in the low points with gobs of clear paint to try and smoothe it out a little
2jz? just about to head out and buy a plenum right now Nod
ed
Re: Ed's MA-61 Supra Mon, 28 March 2005 06:04 Go to previous messageGo to next message
Hehe, I'm kinda pissed, because obviously mine cost a little more by not doing it myself Laughing Not happy at all, there is a big shit-fight brewing when I get them to fix it all. Plenty of little dents I can deal with though, thats my fault, but the plainly obvious stuff, nah-uh Smile
Goodie, I actually need a ride in this, I never got to go for a spin with ze 7M Crying or Very Sad
TheStitt
Re: Ed's MA-61 Supra Mon, 28 March 2005 06:21 Go to previous messageGo to next message
That looks good ed
Are the decals still going on it???
RA65 Sleeka
Re: Ed's MA-61 Supra Mon, 28 March 2005 10:42 Go to previous messageGo to next message
is it me or is there 2 reds i see on the bonnet??
ed_ma61
Lost in the K hole
decals? perhaps Rolling Eyes
ill see how i feel after a few weeks of looking at it. currently i'd say not... though i am prone to changing my mind.
ill go take pics of this plenum now Nod Very Happy
ed_ma61
Lost in the K hole
Re: Ed's MA-61 Supra Mon, 28 March 2005 10:43 Go to previous messageGo to next message
RA65 Sleeka wrote on Mon, 28 March 2005 20:42
correct Nod
RA65 Sleeka
Re: Ed's MA-61 Supra Mon, 28 March 2005 10:45 Go to previous messageGo to next message
whys that??
ed_ma61
Lost in the K hole
Re: Ed's MA-61 Supra Mon, 28 March 2005 11:16 Go to previous messageGo to next message
i call it the 1985 win percy stripe:
http://www4.tpg.com.au/users/loats/images/Image0018.jpg
ed_ma61
Lost in the K hole
Re: Ed's MA-61 Supra Mon, 28 March 2005 11:31 Go to previous messageGo to next message
the new plenum
almost big enough to have come fitted on some small commercial aircraft
matches up eerily well to the rb26 throttle bodies Rolling Eyes
it needs a bit of work to re-orient the inlet downwards (due to swapping the intake side over R to L) but that shouldnt prove too much of a hassle.
note the beautiful internal ribbing. the bell into each runner is also beautiful. a bit of work with the dremel and a flap wheel, and this will be schmicko!
http://www4.tpg.com.au/users/loats/images/Image0016a.jpg
http://www4.tpg.com.au/users/loats/images/Image0019a.jpg
http://www4.tpg.com.au/users/loats/images/Image0022a.jpg
http://www4.tpg.com.au/users/loats/images/Image0025a.jpg
http://www4.tpg.com.au/users/loats/images/Image0005a.jpg
[Updated on: Mon, 28 March 2005 11:36]
BlackSupra
Re: Ed's MA-61 Supra Mon, 28 March 2005 12:06 Go to previous messageGo to next message
sponsored by loctite?
Plenum looks awesome, rb26 plenum im guessing?
Should be sweet once it is together
bbaacchhyy
Re: Ed's MA-61 Supra Mon, 28 March 2005 21:46 Go to previous messageGo to next message
Looking pretty schmick there Ed.
Can't wait to see it in 5 stud glory !!! Still interested in the old 7M manifold once you are done !!!!
Michael B
Re: Ed's MA-61 Supra Tue, 29 March 2005 00:41 Go to previous messageGo to next message
You grown some tits ed?
Some experiment at work go wrong? Razz
ed_ma61 wrote on Mon, 28 March 2005 19:31
[Updated on: Tue, 29 March 2005 00:42]
ed_ma61
Lost in the K hole
Re: Ed's MA-61 Supra Tue, 29 March 2005 00:58 Go to previous messageGo to next message
i was waiting for some wise arse to mention the boobs
micheal, manifold is all yours when it comes apart.
as for the brakes - rang my machinist yesterday, he assured me all was going well, but needed to ring me back to discuss something Rolling Eyes
its been a while, i hope it all just hasnt rusted away into nothing
bbaacchhyy
Re: Ed's MA-61 Supra Tue, 29 March 2005 05:27 Go to previous messageGo to next message
ed_ma61 wrote on Tue, 29 March 2005 10:28
I'll be there with boots on when you are ready Ed.
I know what it is like when a 'mate' does the work for next to nothing, but it takes sooooo bllloooodddddyyyyy llllooonnnngggg Sad Hopefully the rad will be done soon along with the IC
Michael B
Allan
Re: Ed's MA-61 Supra Wed, 30 March 2005 10:22 Go to previous messageGo to next message
oi eyes off that 7m its MINE!!! i have been waiting for a few years now while its bounced from victoria to newsouth Smile
mine mine mine mine mine!!!!!!!!!!!
moooohahhahahahhaha!!!!!!
Allan
ed_ma61
Lost in the K hole
Re: Ed's MA-61 Supra Mon, 04 April 2005 14:41 Go to previous messageGo to next message
some pics of the rear rotors/hubs and handbrake drums as machined up by Mr Jason 'bubbles' Myers himself - thanks !! Nod
rotor is jzz30 308mm x 18mm
internal handbrake drum is ms112 with the rotor machined off, seen neatly sitting inside the jzz30 rotor drum
hub is ms123, central spigot machined down a few mm, then a larger hub centric wheel collar has been pressed on. rotor and drum centre holes have been machined open to fit (4thou clearance)
longer studs are from a hilux at PNPL for $0ea (8mm longer than stock)
http://iamfrank.ath.cx/brakes/images/29122004%20003.jpg
good links for studs are here:
http://forums.toymods.org.au/index.php?t=msg&t h=60067&prevloaded=1&rid=92&S=27ae3290 af05a5aa40370c72e8457f23&rev=&reveal=& start=0&count=20
http://forums.toymods.org.au/index.php?t=msg&t h=44988&rid=162&S=49ad7a55ebf0085e26568551 53deb526&pl_view=&start=0#msg_407417
offset due to the fiting of the internal drum is increased about 7-8mm or so. this allows good clearance of the jzz30 rotor which happens to be deeper than stock by about 7-8mm - good planning!!
combined with +0 offset rims, brings total track increase up to around 15-16mm per side
http://forums.toymods.org.au/index.php?t=getfile&id=10922
http://forums.toymods.org.au/index.php?t=getfile&id=10923
http://forums.toymods.org.au/index.php?t=getfile&id=10924
will be making brackets for the r33 calipers some time in the next few weeks...
ed
bbaacchhyy
Re: Ed's MA-61 Supra Mon, 04 April 2005 21:18 Go to previous messageGo to next message
Looking good there Ed.
The MS112 drum fits in there quite nicely. Good plan.
I have another set of Rays 17x8" +10 offset rims as a spare set !!!
Can't wait to see yours all up in its new paint job.
Michael B
gold28
Madrid - Spain
Re: Ed's MA-61 Supra Mon, 04 April 2005 23:10 Go to previous messageGo to next message
So let me get this straight, are you are using a MS112 handbrake set up or does the caliper have an intgral handbrake?
bbaacchhyy
Re: Ed's MA-61 Supra Mon, 04 April 2005 23:17 Go to previous messageGo to next message
gold28 wrote on Tue, 05 April 2005 08:40
He has machined off the disc of the MS112 disc so that he can use the MA61 handbarke (unmodified) and slipped the JZA80 rear disc on top (the JZA80 handbrake drum ID is 190mm vs MA61 169mm)
Rear caliper is the std R33/Z32 twin piston caliper.
gold28
Madrid - Spain
Re: Ed's MA-61 Supra Tue, 05 April 2005 00:38 Go to previous messageGo to next message
Ed aint as silly as he pretends to be Razz
[Updated on: Tue, 05 April 2005 00:49]
ed_ma61
Lost in the K hole
Re: Ed's MA-61 Supra Tue, 05 April 2005 01:12 Go to previous messageGo to next message
gold28 wrote on Tue, 05 April 2005 10:38
shucks, thanks Embarassed
it seems really simple looking at it now, but it took almost an entire day, with much conversation between myself and baaacchhhyyyy to actually figure it out...
...but damn it works well. and no need for any handbrake modifications. no scratching, squealing, zero clearance issues. it all just goes together. and 308mm on the back is nothing to complain about Smile
ed
Re: Ed's MA-61 Supra Tue, 05 April 2005 01:21 Go to previous messageGo to next message
Me thinks I'll be finding myself some JZZ30 rotors now...
bbaacchhyy
Re: Ed's MA-61 Supra Tue, 05 April 2005 01:22 Go to previous messageGo to next message
It also eliminates the need for the rear calipers to be spaced to fit the rotor width.
In hindsight, this would have also been my preferred option, but my conversion was already done.
Hopefully my handbrake works well enough .....
ed_ma61
Lost in the K hole
Re: Ed's MA-61 Supra Tue, 05 April 2005 01:27 Go to previous messageGo to next message
it ALSO keeps the handbrake drum dust lip interface in the correct position... so no more dusty asbestos rims from my foooly hekitk handbrake dorrifto actions
gold28
Madrid - Spain
Re: Ed's MA-61 Supra Tue, 05 April 2005 01:33 Go to previous messageGo to next message
How does the disc go being spaced out further on the studs, I guess the disc doesn't normally sit tight on the studs anyway. Have you spoken to an engineer about it, I guess on one hand you have put the studs in bending but on the other you have more studs to take load.
Good work ED/bbaacchhyy. Nice to see people thinking outside the square.
ed_ma61
Lost in the K hole
Re: Ed's MA-61 Supra Tue, 05 April 2005 01:42 Go to previous messageGo to next message
the rotor now sits 8mm further out, but think about it... when braking - where is the braking torque transfered?: from the rotor, into the stud, into the wheel... then from the centreline of the wheel, back into the hub/chasis
there is no change in the relationship of the rotor to the wheel, thus the bending forces/shear on the studs is the same.
the problem lies in the distance of the wheel from the hub, but i think with 5 studs, good support around the studs between the wheel and the hub, and the hub centric ring, one would incounter minimal problems
gold28
Madrid - Spain
Re: Ed's MA-61 Supra Tue, 05 April 2005 02:03 Go to previous messageGo to next message
So your now using a solid disc? or are they just misleading photos. The photos up the top of the page shows ventilated discs.
Re: Ed's MA-61 Supra Tue, 05 April 2005 02:12 Go to previous messageGo to next message
gold28 wrote on Tue, 05 April 2005 10:03
Misleading photos
ed_ma61
Lost in the K hole
Re: Ed's MA-61 Supra Tue, 05 April 2005 02:42 Go to previous messageGo to next message
same rotors as in pic below... just cant see the vents, well you can *just* see them in the top pic above...
Allan
Re: Ed's MA-61 Supra Tue, 05 April 2005 10:49 Go to previous messageGo to previous message
ed_ma61 wrote on Tue, 29 March 2005 10:58
lose the penis, testicals, adams apple and some plastics work you will be every car nuts dream ed-ith Wink
come to melb again soon i promise you a ride in something more interesting then an RT81... unless someone fits a v12 to it Razz
Previous Topic:My 1JZ MX83 GLX Cressida
Next Topic:Bill's st185 (new rims and lowered rear springs!)
Current Time: Sun Nov 1 11:52:21 UTC 2026
Total time taken to generate the page: 0.010790109634399 seconds
