Toymods » Tech & Conversions » Wiring Foglights. Simple question
RobST162
Wiring Foglights. Simple question Mon, 31 January 2005 13:03 Go to next message
hey guys
Well I have the 165 foglights now to wire up. I will have a switch in the cabin, which I want to run independantly of the lighting circuit.
This is how I think I will do it and I need to know if it's ok.
1) Wire from battery to relay
2) Wire from relay to switch
3) Wire from switch to relay
4) Wire from relay to lights
5) Earth from lights
Is this right? Thanks guys.. I suck at this kinda stuff
Rob Wink
Stefan
Hobart, Tas
Re: Wiring Foglights. Simple question Mon, 31 January 2005 14:37 Go to previous messageGo to next message
Seems to be, though someone else more knowledgeable will chime in.
You also need a wire from relay to earth.
fade-e
Re: Wiring Foglights. Simple question Mon, 31 January 2005 16:48 Go to previous message
when i put fogs on the TA22 how i did it was FOG1 negative to FOG2 positive, FOG1 positive to ignition, ignition to switch, switch to FOG2 negative... and put a fuse between FOG1 positive and ignition (close to ignition for easy access)
that way it only works when car is on and has the switch on top
Previous Topic:Wiring in Brisbane (South) - AE90 - silvertop
Next Topic:cam timing experts please
Current Time: Fri Nov 20 09:43:40 UTC 2026
Total time taken to generate the page: 0.0042669773101807 seconds
