Toymods » Tech & Conversions » speedo cable on toyota!
HighRolla
speedo cable on toyota! Mon, 31 January 2005 13:43 Go to next message
The toyota townae van has had its speedo stop working. Im trying to locate the connection to the gearbox to check its screwed on properly- but I can't see it. Anyone know where it would be?
How much for a new cable?
Is it hard to replace - ie. get to the back of the dash etc?
HighRolla
Re: speedo cable on toyota! Tue, 01 February 2005 00:06 Go to previous messageGo to next message
bump
4agte
Toronto, Downtown
Re: speedo cable on toyota! Tue, 01 February 2005 00:19 Go to previous messageGo to next message
if it is a 4age then the spedo cable will run to the gearbox behind the thermostat you sould see the cable comming through the gromet in the firewall. And yes id imagine it to be a fiddly thing to replace.
Celica_John
Re: speedo cable on toyota! Tue, 01 February 2005 02:17 Go to previous messageGo to next message
you could also check the other side that goes into the speedo.
4agte
Toronto, Downtown
Re: speedo cable on toyota! Tue, 01 February 2005 02:36 Go to previous messageGo to next message
true true but start with the gearbox side its the easiest to get to then check the the other side. If its not the cable its the instrument cluster.
HighRolla
Re: speedo cable on toyota! Tue, 01 February 2005 06:43 Go to previous messageGo to next message
its in a van - not a 4age - an old tech motor. I'll have a look
THnaks
Re: speedo cable on toyota! Tue, 01 February 2005 08:15 Go to previous messageGo to next message
4agte wrote on Tue, 01 February 2005 10:19
if it is a 4age
What makes you think a Townace van has a 4A-GE?? Confused
4agte
Toronto, Downtown
Re: speedo cable on toyota! Tue, 01 February 2005 08:23 Go to previous message
my bad for skim reading
Previous Topic:fuel pump ??? how much do i need
Next Topic:Noise in R/H Front (MA70)
Current Time: Sun Oct 18 22:05:26 UTC 2026
Total time taken to generate the page: 0.030997037887573 seconds
