Toymods » Tech & Conversions » Additional Electric Temp Sensor Location (5M-E)?
ZZT231
melbourne.vic.au
icon5.gif  Additional Electric Temp Sensor Location (5M-E)? Wed, 02 February 2005 00:13 Go to next message
Hey All,
I am thinking of adding an electric temp sensor to the block, does any one have a clue where i can put the sensor in the block for a 5M-E?
Cheers.
Re: Additional Electric Temp Sensor Location (5M-E)? Wed, 02 February 2005 00:59 Go to previous messageGo to next message
Having never worked on a 5m-e I might not be able to help, but I'll try.
The 5m-ge had an extra spot on the thermostat housing.
Just unscrew the blanking plate, and screw it in there.
Failing that, my MX73 has a draincock in the bottom of the radiator.
Maybe you can put it there?
boxh34d
wangaratta
Re: Additional Electric Temp Sensor Location (5M-E)? Wed, 02 February 2005 05:53 Go to previous messageGo to next message
if you look on the front of the thermostat housing, there is a little plastic tree with 2 vacuum lines on it, which is screwed into the thermo housing.
go to your local brass fitting shop, and buy a T adapter and a nipple. the nipple should fit in the thermo housing, which you screw the vacuum tree into. the temp sender for thermo's etc should screw into it also.
can send you an email with a paint picture explaining it better if you like??
ZZT231
melbourne.vic.au
Re: Additional Electric Temp Sensor Location (5M-E)? Wed, 02 February 2005 06:17 Go to previous messageGo to next message
Please do, you got my email address...
Cheers.
boxh34d
wangaratta
Re: Additional Electric Temp Sensor Location (5M-E)? Thu, 03 February 2005 02:48 Go to previous messageGo to next message
i'll get my GF's digi cam tonight, and take some pictures of it for you.
it's pissing down rain here, and it will be dark, but i'll do my best.
Allan
Re: Additional Electric Temp Sensor Location (5M-E)? Thu, 03 February 2005 02:58 Go to previous messageGo to next message
there is a drain cock on the block but its in a pig of a pozie.
if you get some radiator hose sized tube and a nut with the threed the same as the sensor ill make something up for you if you want.
Allan
boxh34d
wangaratta
Re: Additional Electric Temp Sensor Location (5M-E)? Thu, 03 February 2005 11:42 Go to previous message
yeah, not the best time to be taking photos, its pissing down axehandles. . . . .
i'll try tomorrow for you.
Previous Topic:removing supercharger SC12
Next Topic:Acid Dipping??
Current Time: Fri Oct 23 12:44:09 UTC 2026
Total time taken to generate the page: 0.0039918422698975 seconds
