Toymods » Tech & Conversions » What to do
badboybubby
On Probation
What to do Wed, 02 February 2005 00:51 Go to next message
Ok got my motor what should I do to it? replace the timing chain(anyone know the part number for the 1GGTE ) do a full service etc ?
ke382TG
Re: What to do Wed, 02 February 2005 01:02 Go to previous messageGo to next message
1GGTE = timing belt
New spark plugs, new leads, change oil and filter, flush out all old coolant grunge. Check for any other obvious problems that may need correcting.
Check rear main seal for any oil leakage that may be evident i.e. massive oil build up around it. Easier to replace this whilst out of car if it needs to be done (hopefully it's fine though).
SOme 1G owners may have some specifics that need attention on these engines??
Re: What to do Wed, 02 February 2005 01:26 Go to previous messageGo to next message
When you do the timing belt, may as well do the front main and oil pump seal too.
Re: What to do Wed, 02 February 2005 02:12 Go to previous messageGo to next message
check turbos for shaft play (hehe, shaft), water pump.
If you plan to re-do the loom (not splice into it near the firewall) it's a hell of a lot easier to do that when it's out of the car and you have room to reach into all the annoying little places.
badboybubby
On Probation
Re: What to do Wed, 02 February 2005 02:30 Go to previous messageGo to next message
Cool thanks for the tips guys btw what does a 1GGTE weigh?
Re: What to do Wed, 02 February 2005 02:37 Go to previous messageGo to next message
I think its 20kg heavier than a 1uz, so about 200kg.
badboybubby
On Probation
Re: What to do Wed, 02 February 2005 03:28 Go to previous messageGo to next message
Does anyone remember/know where I can get the part numbers for this stuff?
Everyone I talk to says has a malfunction when they find out its an import Mad (yes I live in the bush) Shocked
matt_84
Ipswich
Re: What to do Wed, 02 February 2005 04:02 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=46695&rid=3896&S=7c1a4e3a8847ea9142ee112 a31714467&pl_view=&start=0#msg_426679msg_4 26679
badboybubby
On Probation
Re: What to do Thu, 03 February 2005 02:20 Go to previous messageGo to next message
How about a part number for the thrust bearing Mad ,btw what model do the G's come out off gen 3
Re: What to do Thu, 03 February 2005 02:22 Go to previous messageGo to next message
badboybubby wrote on Thu, 03 February 2005 10:20
Thrsut bearing is part of the gbox.
All W58 thrust bearings should be the same number.
badboybubby
On Probation
Re: What to do Mon, 14 March 2005 07:16 Go to previous message
Its a one piece self centering bearing and every time I order a bearing its just a flat bearing that turns up
Evil or Very Mad FFS does anyone have a carrier or part number ???
Previous Topic:2t dieseling on.
Next Topic:Car not cranking
Current Time: Thu Nov 19 00:24:07 UTC 2026
Total time taken to generate the page: 0.0054831504821777 seconds
