Toymods » Tech & Conversions » Oil Temperatures
IRA11Y
Club Member
Oil Temperatures Sat, 26 October 2002 23:46 Go to next message
Guys I was looking at installing an oil cooler for someone the other day but the room available was few and far between except for behind the radiator where it would become an oil warmer very quickly Smile
But I though about running a independant fan full time on the cooler but this has popped a question in to my head to which I cant find an answer, maybe John K or Bill can answer it for me.
for those running a 4AGE or 3SGE with an oil cooler what is the average temp of your oil? has anyone measured the difference in temp with and without the cooler attached? the reason I need an answer is that if I run a fan full time Im worried the oil temp will get so low as to damage the piston with the heat difference when it comes out the squirters as well as affecting engine wear.
anybody got some answers?
hiaaa
Re: Oil Temperatures Sun, 27 October 2002 00:07 Go to previous messageGo to next message
My 4AGE oil temp is about 100-110c (that's with a thick aluminium radiator), after install an oil cooler it drop to about 80-90c, and the oilcooler is before the radiator. I think 90c isn't too low, right?
Leon
[Updated on: Sun, 27 October 2002 00:12]
IRA11Y
Club Member
Re: Oil Temperatures Sun, 27 October 2002 00:22 Go to previous messageGo to next message
hmm thats a fair bit of cooling , where do you have it mounted exactly? does it get a constant flow of cold air? and what about when youre really pushing the car like at a track, what sort of temps do you get then?
hiaaa
Re: Oil Temperatures Sun, 27 October 2002 00:41 Go to previous messageGo to next message
yeah the cooler is a big one-190mmX240mm (13 row), I mount it at the right hand side of the car & in front of the radiator, and the hoses go through the hole behind the headlight. I had driven the car hard for 20 minutes at a bloody hot day(34c) and the oil temp stay at 90c (without the oilcooler it will be 110c).
Leon
[Updated on: Sun, 27 October 2002 00:52]
rollaboy
Coffs
Re: Oil Temperatures Sun, 27 October 2002 02:52 Go to previous messageGo to next message
This is were my oil cooler is ...Sorry i know its a crap photo.
http://www.plusoneinteractive.com/rollaboy/oil%20cooler_2.jpg
Blown86
Re: Oil Temperatures Sun, 27 October 2002 08:38 Go to previous messageGo to next message
Oil temperature about the same as engine coolant temperature is good.
Don't worry about oil squirters shock cooling the pistons unless you plan on running a large esky with heaps of ice as a cooler.
IRA11Y
Club Member
Re: Oil Temperatures Mon, 28 October 2002 00:18 Go to previous messageGo to next message
Blown86, why shouldnt I worry about cold oil hitting a hot piston? 4AGE pistons are pretty thin, if I get the cooled oil temp down to 50-60c then thats a large difference from 110c and could IMHO crack a piston running at extremes. Have you done some testing in this area? Id like to know more if you have Smile
Bill Sherwood
Brisbane / Gold Coast
Re: Oil Temperatures Mon, 28 October 2002 01:59 Go to previous messageGo to next message
Use a water-to-oil intercooler, then the oil will never run too hot or cold. It'll also warm up faster.
Something like the gadget on the side of the gen 3 & later 3SGE's are good.
Blown86
Re: Oil Temperatures Mon, 28 October 2002 07:35 Go to previous messageGo to next message
IRa11Y:
Got a fair understanding of thermodynamics and metallurgy from my studies as a mechanical engineer.
If you use an overly large oil cooler you MUST use a thermostat.
It is not good for the whole engine to run with oil cooled too low. About engine operating temperature is the best temperature.
The oil squirters spray at the bottom of the piston crown to keep the crown cooler. Imagine what happens if you start the engine from cold on a cold day. The piston crown within seconds will reach a temperature of around 400C plus but the oil will take minutes to reach operating temperature. The oil is still sprayed at the bottom of the crown. No damage results.
The volume of oil at any given instant is not enough to quench the piston to the point of piston failure. Once the oil has reached operating temperature, ideally the system is in a degree of equilibrium ie: heat removed from the crown = heat absorbed by the piston crown for given revs.
I've got a water/oil cooler, much less hassle. Oil temperature is regulated by coolant temperature and as Bill said it warms up faster. Used a cooler off a 2.2 turbo Mazda donk and remote mounted it.
IRA11Y
Club Member
Re: Oil Temperatures Tue, 29 October 2002 05:15 Go to previous messageGo to next message
so basically any auto transmission radiator with the oil cooler at the bottom for the trans fluid would do the trick, in the case of a 4AGE that would mean the oil would be stabilising around 86 or so degrees C , which is probhably cool enough to keep internal temps down so long as you didnt overheat and then the oil would be heating quicker as well with the water boiling which would not be a good look Smile
Bill have you got a pick of one of those gen 3 coolers?
Bill Sherwood
Re: Oil Temperatures Tue, 29 October 2002 12:23 Go to previous messageGo to next message
I don't have a pic, sorry, but all they are is a small cylinder a little bigger diameter than an oil filter and about 40mm thick. There's two pipes coming out of it, one for water in & the other for water out. Check around and you should be able to find one. The only hassle with using one is that you'll have to use a remote filter.
Sprocket
The Central Coast
Re: Oil Temperatures Mon, 16 December 2002 04:45 Go to previous messageGo to next message
Sorry to come back to such an old topic, but would it be okay to use a large oil cooler like an rx7 or rx3 style oil cooler that mounts below the radiator?
Sprocket
The Central Coast
Re: Oil Temperatures Mon, 16 December 2002 04:48 Go to previous message
Is it also possible to install oil squirters in a big port red & black top motor?
I was going to upgrade to the 100kW pistons, I thought it might be good to somehow install oil squirters if the block has the machining done.
Previous Topic:diff conversion
Next Topic:16v to 20v
Current Time: Sun Nov 1 05:01:31 UTC 2026
Total time taken to generate the page: 0.0061709880828857 seconds
