Toymods » Tech & Conversions » custom pipe work
93soarerTT
custom pipe work Wed, 02 February 2005 04:21 Go to next message
do you think there would be much advantage of doing custom pipe work turbo side of the 1JZ-GTE, the stock setup seems really restricting. if so what sorta budget should i set
Re: custom pipe work Wed, 02 February 2005 09:20 Go to previous messageGo to next message
Unless you've upgraded your turbos, don't bother.
YelloRolla
On your mum!
Re: custom pipe work Wed, 02 February 2005 09:50 Go to previous messageGo to next message
I guess it depends on which pipes? If you are thinking about making some twin dump pipes instead of the abomination that Toyota blessed them with then there is no bad time to do it.
Re: custom pipe work Wed, 02 February 2005 13:11 Go to previous messageGo to next message
I thought he was talking about inlet side... but if we're talking exhaust (dump pipe) then yes, it's definitely beneficial. Twin dump pipes are available commercially these days - do a search and you'll find all the info you need.
Re: custom pipe work Wed, 02 February 2005 13:22 Go to previous messageGo to next message
If you have the ability to do much of the work yourself, then replace the lot. Otherwise, I suppose it could end up kind of pricey, and you may/may not get a worthwhile gain from it.
HyDrA
Adelaide, SA
Re: custom pipe work Wed, 02 February 2005 23:56 Go to previous messageGo to next message
The price depends on who you talk to Wink
ChuckLandwehr
Re: custom pipe work Thu, 03 February 2005 05:14 Go to previous messageGo to next message
Visit the Planet Soarer website. There are a numbner of Aussies making 1JZ-GTe twin dump pipes, and at reasonable cost.
regards Chuck.
Celia-Sue
Re: custom pipe work Thu, 03 February 2005 05:23 Go to previous message
Given the restrictions in the 'bendy bits' around the tuebo (where intake splits to 2 and then re-joins to one), I would be surprised if simply puting hard pipes from turbo-IC-TB would make a significant difference. Though you might want to do it as a prelude to a turbo upgrade.
I think this would make more sense if I used pictures. Rolling Eyes
Previous Topic:Getting Springs rewound lower AND stiffer
Next Topic:15" 4x114.3 steel wheels
Current Time: Sat Nov 21 05:19:10 UTC 2026
Total time taken to generate the page: 0.0046579837799072 seconds
