Toymods » Tech & Conversions » 2tgeu v's 3tgteu cams
Syc02T
Lake Macquarie
2tgeu v's 3tgteu cams Wed, 02 February 2005 05:33 Go to next message
who understands cams.
It is hard to get good info on what works and what dont.
I have some nitrided 3tgteu cams i would like to put in the 2tg't'eu, the car runs fine now, but i would like to know if it would be a worthwhile exercise to put the 3tg cams is.
Are there any performance gains/losses expected?
How will it affect the torque curve etc.
jesseT18
Castle Hill, Sydney
Re: 2tgeu v's 3tgteu cams Wed, 02 February 2005 08:26 Go to previous messageGo to next message
2tg cams have a longer duration than 3tgte cams
so i certainly wouldnt want to put 3tgte cams in a 2tg unless you want to reduce power, revability
YelloRolla
On your mum!
Re: 2tgeu v's 3tgteu cams Wed, 02 February 2005 09:58 Go to previous messageGo to next message
I am running the stock 3T GTE cams at the moment - I have not yet measured the duration and timing differences to see how they compare. I say suck it and see and then tell us the results (ideally you would do back to back power runs and overlay the graphs to see where gains/losses are made).
Jesse - what is the exact duration of the 3T GTE cams and the 2T G cams? I am pretty sure that the 2T G has had about 3 x different factory cam grinds during it's evolution.
greenta22
Dandenong Ranges, VIC
Re: 2tgeu v's 3tgteu cams Wed, 02 February 2005 11:33 Go to previous messageGo to next message
88220 - 248 degrees duration, 9.82mm lift
88222 - 256 degrees duration, 10.27mm lift
88260 - height 46.4mm (?) carbied
88262 - 256 or 244 degrees (for 8.4:1), 240 degrees (for 9:1)
http://www.geocities.com/Colosseum/4883/2tg-info.h tml
4T-GTE mmmmmmm....
YelloRolla
On your mum!
Re: 2tgeu v's 3tgteu cams Wed, 02 February 2005 23:28 Go to previous messageGo to next message
Thank you for that greenta22 Smile
I only need to chase down the 280 (3T GTE) specs.
YelloRolla
On your mum!
Re: 2tgeu v's 3tgteu cams Thu, 03 February 2005 02:20 Go to previous messageGo to next message
BTW - the 46.4 = about 9.4mm lift if I remember rightly.
The longer duration (of the 262) is more likely for the 9.0:1 and 240 for the 8.4 (just a thought).
Syc02T
Lake Macquarie
Re: 2tgeu v's 3tgteu cams Sat, 05 February 2005 07:56 Go to previous message
Bugger the head i got is the only one this isn't on that list or the link, i have the 261 cams.
I will put these in one day, i am not sure how good the comparison will be because i got these 3tgteu cams nitrided and cryo'd, so there will be a difference straight up.
Previous Topic:Drift Suspension
Next Topic:KE20 workd 4K Fuel Solutions
Current Time: Mon Oct 26 20:22:12 UTC 2026
Total time taken to generate the page: 0.0042212009429932 seconds
