Toymods » Tech & Conversions » 2T ignition advance
greenta22
Dandenong Ranges, VIC
2T ignition advance Wed, 02 February 2005 06:28 Go to next message
im trying to screw a few more hp out of the 2T, can anyone recomend a good primary ignition advance setting? im on about 15 before at the moment and was thinking of going to 20 or 25 BTDC. will the motor ping and die before i get out of the driveway? the vacuum advance im pretty sure isnt working.
specs are: 2T (OHV) solex downdraught carb, K&N air filter, 272 degree cam, pacemakers and a 2" straight through. i run BP Ultimate all the time.
also, some air/fuel settings. besides overheating, poor idle etc, what are the symptoms of a too lean mixture?
floppy
Ipswich
Re: 2T ignition advance Thu, 03 February 2005 03:07 Go to previous messageGo to next message
Hey,
Yeah I too would like a bit more info on this. I am running 15 degrees as well, and was wondering how far to go before it screws things up.
I tested the vacuum advance on mine with one of those little testers and its still working nicely (surprisingly)
There is a place up the coast here (qld) that does replacement vacuum advance pieces. If you are interested I can dig up there details.
Floppy
YelloRolla
On your mum!
Re: 2T ignition advance Thu, 03 February 2005 07:29 Go to previous messageGo to next message
greenta22 wrote on Wed, 02 February 2005 17:28
advance = suck it and see (best done on a dyno)
A/F - if it is too lean the car will cough and pop out of the exhaust )one of the symptoms).
greenta22
Re: 2T ignition advance Thu, 03 February 2005 08:49 Go to previous messageGo to next message
i leaned it out about a full turn on the mixture screw, then adjusted the idle back to normal.
the idle speed moves around a bit, ie. from 800rpm-1200rpm but it seems to be a bit more responsive, but that could just be in my head.
YelloRolla, i presume you mean popping under load is a symptom, it pops and backfires on the over-run (backing off) all the time, but nothing abnormal, just due to the overlap on the cam i thought. never hesitates under WOT, but has a few little misses at part throttle low revs.
i'll play with the advance tomorrow, mabe start at 20 degrees. i dont have the means to access to a dyno unfortunately.
YelloRolla
On your mum!
Re: 2T ignition advance Thu, 03 February 2005 23:04 Go to previous messageGo to next message
popping on overrun may be caused by a couple of different issues, one of them being lean, but who cares if it is lean on the overrun?.
But yes primarily if it popped under normal load or high load then that is very bad.
Re: 2T ignition advance Fri, 04 February 2005 09:55 Go to previous messageGo to next message
fwiw, i have tried advance between about 15 and 35 base advance... basically, you will find a point beyond which power will drop off and the motor will make more noise but less go. past that you may ping, but mine doesn't tend to.. just loses power.
you will probably find that different base advance will be better at diferent rev ranges. just try by advancing maybe 2deg at a time and go for a drive..
Celica73
Re: 2T ignition advance Mon, 07 February 2005 09:07 Go to previous messageGo to next message
Hi
Sorry to steal the thread but was wondering what advance people have found best for a 2TG i know 16 degrees is the factory setting for my engine but was wondering how far can i advance it to gain a little more out of it. Just a ball park figure would do
Jason
fangsport
timaru NZ
Re: 2T ignition advance Mon, 07 February 2005 10:11 Go to previous message
blank off the vacuum advance and run it at 24-30 depending on cam. vacumm advance isn't necessary and may cause it to over-advance and send a leg out of bed.
Previous Topic:best ecu for GZ
Next Topic:1UZ comp
Current Time: Fri Oct 23 02:59:14 UTC 2026
Total time taken to generate the page: 0.0061028003692627 seconds
