Toymods » Tech & Conversions » 4agze knock sensor help
feral4mr2
Bundaberg, Qld.
icon5.gif  4agze knock sensor help Tue, 28 May 2002 03:46 Go to next message
anyone know about knock sensors? i just pulled my blower out so i could get to the knock sensor to replace it. the one i have on mine is a grey coloured plastic, the one i got off a later model ze has green plastic. i know all these are is a piezeo microphone so there shouldnt be any difference in them, but i thought i better ask in case there is. ( i wish they made enougth room to pull the blower straight out without having to remove the inlet or outlet pipe of it!!) anyway any ideas??
thankyou in advance.
[Updated on: Tue, 09 August 2005 08:58]
AE86_Sprinter
Perth, WA
Re: 4agze gurus pls help Tue, 28 May 2002 04:13 Go to previous messageGo to next message
will be fine.
If yours was a mr2 motor and was grey, that is interesting..
I have early model AE92, it is green,
mates late model AE92 was green, but i replaced it with a ae101 knock that was grey, and had a different plug.
Obviously works a treat as the car runs 10 times better with it fitted. The knock sensor is important as it runs in full ignition retard if its not connected as far as i can gather. Put the new sensor in, reset the ecu and enjoy the extra power.
Mike
feral4mr2
Bundaberg, Qld.
icon14.gif  Re: 4agze gurus pls help Tue, 28 May 2002 04:50 Go to previous messageGo to next message
cheers mate,
maybe it was replaced at some stage in japan before i got it?
it has the same plug as the green one. i'll put it all back together after lunch. Rolling
AE82TwinCam
Canberra, ACT
icon5.gif  Re: 4agze gurus pls help Wed, 29 May 2002 06:34 Go to previous messageGo to next message
Would the knock sensor not being connected generate a check engine error when on constant, rising boost like my ze does?
Any ideas why I may be getting this error, as the error doesn't come up at any other time and when I turn teh engine off and back on again the error disappears..
-Andrew
AE86_Sprinter
Perth, WA
Re: 4agze gurus pls help Wed, 29 May 2002 06:46 Go to previous messageGo to next message
Yes.
Only difference we had was as soon as it reved over 2000rpm, when driving it came on
Mike
AE82TwinCam
Canberra, ACT
icon7.gif  Re: 4agze gurus pls help Wed, 29 May 2002 07:09 Go to previous messageGo to next message
Hmmm, well I'll have to check it out then, can I just grab a replacement sensor from toyota?
Can it be from any 4age or does it have to be a ZE?
Cause I still have my old 88kw 4age sitting in the garage..
-Andrew
feral4mr2
Bundaberg, Qld.
icon6.gif  Re: 4agze gurus pls help Wed, 29 May 2002 08:43 Go to previous messageGo to next message
Andrew,
you'll have to get it from a ze as the ge doesnt have one. so i doubt you would be able to get one from toyota as the ze was not bought into aust? i would think that if it (the connector) wasnt connected to the k/s it would cause the check engine light to come on.
AE82TwinCam
Canberra, ACT
Re: 4agze gurus pls help Wed, 29 May 2002 09:58 Go to previous messageGo to next message
where does the the sensor sit? so I can check if its all connected properly...
-Andrew
feral4mr2
Bundaberg, Qld.
icon6.gif  Re: 4agze gurus pls help Wed, 29 May 2002 11:30 Go to previous messageGo to next message
Neutral it's a real bastard to get to. it is under the inlet manifold just above the starter motor, if you have the car up on ramps (cant get to it from the top) put your hand up pass the exhaust and feel the block just above the starter. you will be really impressed if you need to replace it. :- you have to pull the blower out.( well thats the only way i could get it out). good luck.
bayka
perth
Re: 4agze gurus pls help Fri, 05 August 2005 05:21 Go to previous messageGo to next message
hey ppl, i know this is an old post but its very relevant.
How interchangable are the 4agx series knock sensors?
Obviously they all thread in to the block, if you change the plugs over where necessary can you for instance use a 100kw knock sensor on an ae101ze?
Thanks in Advance
-daniel-
Mr Revhead
nelson, new zealand
Re: 4agze gurus pls help Fri, 05 August 2005 07:50 Go to previous messageGo to next message
prob wont work, knock sensors are made to put out certain signals
you have to use a gze one. not hard to find over here Cool
bayka
perth
Re: 4agze gurus pls help Fri, 05 August 2005 12:51 Go to previous messageGo to next message
ok thanks. So any gze knock sensor should work for a gze?
This is important because $216 for a brand new one sux :/
-daniel-
Mr Revhead
nelson, new zealand
Re: 4agze gurus pls help Fri, 05 August 2005 21:08 Go to previous messageGo to next message
faaaaaark that
i should be able to source you one for $100ish nz delivered....
drop me an email
warwick.parts@bowater.toyota.co.nz
sideshow
Re: 4agze gurus pls help Sat, 06 August 2005 07:55 Go to previous messageGo to next message
i have some knock sensors around from 20v and 4agzes
just get me the part number of the one u need and ill see
if it matches ones that i have
Mr Revhead
nelson, new zealand
Re: 4agze gurus pls help Sat, 06 August 2005 08:46 Go to previous messageGo to next message
aw11 and ae92 ze knock sensors are the same
ae101 ze is different
and n/a ones are different again
part number for ae92/aw11 ends in 17010 or something
others are a completly diff number
bayka
perth
Re: 4agze gurus pls help Mon, 08 August 2005 17:27 Go to previous messageGo to next message
Thanks heaps for the info,
Im going to try and it off this week and put up the part number.
Also whoever created this post : it would be a great idea to edit the title to include the words 'knock sensor' so this info could be more easily located when doing a search Smile
(i found it by accident)
-daniel-
drift86levin
brisvegas
Re: 4agze gurus pls help Mon, 08 August 2005 21:51 Go to previous messageGo to next message
when i replaced the head on mine i just ever so slightly tapped the knock sensor (dunno how cos it's in the gayest position) and i found that a 7MGTE one has the same plug, well at least the motor i pulled it off had the same one..only it had a full metal casing, with only a little bit of plastic..looked a little more robust..i couldn't care less if it was slightly different..the car ran fine with it..so i guess it worked ok?
feral4mr2
Bundaberg, Qld.
Re: 4agze gurus pls help Tue, 09 August 2005 09:01 Go to previous message
bayka wrote on Tue, 09 August 2005 03:27
-daniel-
thar ya go laddy.... Wink
Previous Topic:1J stock coil packs
Next Topic:wjich way does clutch go in
Current Time: Sat Oct 24 04:54:21 UTC 2026
Total time taken to generate the page: 0.0081298351287842 seconds
