Toymods » General Car Talk » Wheels vs Tyre Pressure Question
tuz76
Wheels vs Tyre Pressure Question Wed, 02 February 2005 08:17 Go to next message
Hi Guys,
When you have your standard wheels on your car (eg SX) on the door is a placard talking about tyre pressures in PSI for your reference.
I now have 16's by 6.5's and am unsure if I should still follow this same placard or if I go by the recommended PSIS on the tyre?
The thing is the tyre is USA and CANADA rated and mentions know more than 40PSI is recommended. Is this too high?
What do you guys refer to or fill your tyres up to?
Thanks peeps.
[Updated on: Wed, 02 February 2005 08:18]
river
Land of Oz
Re: Wheels vs Tyre Pressure Question Wed, 02 February 2005 10:49 Go to previous messageGo to next message
If you change the tyres from the brand that came with the vehicle, then use the value recommended for the new tyres.
seeyuzz
river
st184 sillycar
Re: Wheels vs Tyre Pressure Question Thu, 03 February 2005 00:41 Go to previous messageGo to next message
How heavy is your car? what size/profile are you tyres? how hard do you drive?
Anywhere between 32-40 psi for road car tyres is acceptable, but optimum depends on the answers to the questions asked above.
Ignore manufacturer recommendations for tyre pressures below 30psi, as they're for bowls-hat wearing Camry drivers who value ride comfort and . . . NOTHING ELSE ! ! !
-Remember the Ford Exploder experience with under-specc'd tyre pressures and radical de-lamination? Confused
finney
Re: Wheels vs Tyre Pressure Question Thu, 03 February 2005 00:47 Go to previous messageGo to next message
i just got a set of 16x7's with 195/45-15 rubber and have been told standard psi for the would be about 32 although some people keep em up at 40 Confused
i'm just going to split the difference and keep em at around 35
tuz76
Re: Wheels vs Tyre Pressure Question Thu, 03 February 2005 10:52 Go to previous messageGo to next message
OK
I got a ae92 corolla sx
Tyres are 205/40s Falken Ziex ZE-512's
On 16 x 6.5inch rims.
It says something on the tyre
not to exceed more than 40psi
THen it says somewhere else that tyre seed beads not to exceed 50psi??? WTF are they?
Anyways does anyone have a similar setup to that? SHould I just go for something like 36psi on all 4 wheels?
geoffrey118
Malta
Re: Wheels vs Tyre Pressure Question Thu, 03 February 2005 11:02 Go to previous messageGo to next message
I got 14"/185/60 M+S tyres - car curb weight is 980kgs.
What tyre pressure should I set them to?!?!
st184 sillycar
Re: Wheels vs Tyre Pressure Question Thu, 03 February 2005 23:09 Go to previous message
Tuz & Geoff, I'd say 34-36psi. for you'ze both.
Tuz - your sidewalls should be stiff enough to happily run around 30psi if you crave a cushier ride, but I'd keep 'em at 34-36psi to keep the tyre wear even. Tyres also clear more water with higher pressure, as well as giving better fuel economy and giving more grip, as they distort less and keep a more consistant contact patch.
I have seen LOTS of tyres that've been run @ 26-28 psi around ~10km of corners, and the outer tread shoulder is completely gone, and some of the sidewall has been scrubbed off - yet the centre-inside of the tyre is pristine. - So I'm not messin' when I say not to run ANY passenger car tyres @28psi ! ! !
-I run all my car tyres at 38psi b.t.w. - primarily to get good feel for the contact patch through the steering and . . . MY ARSE !
Previous Topic:LC vs LX Front Indicators
Next Topic:Tyre Recommendations on 14" 185/60's
Current Time: Fri Oct 23 17:46:23 UTC 2026
Total time taken to generate the page: 0.0064020156860352 seconds
