Toymods » Tech & Conversions » 4AGZE bypass valve lock out
Mullett
4AGZE bypass valve lock out Wed, 02 February 2005 08:44 Go to next message
Can anyone give me an accurate description (pics would be great) of how to remove or bypass the standard wastegate valve on the AW11? Need to run more boost Very Happy
Cheers, RM
irishtwincam
Ireland
Re: 4AGZE bypass valve lock out Wed, 02 February 2005 10:00 Go to previous messageGo to next message
google the term "ABV MOD"
4agte
Toronto, Downtown
Re: 4AGZE bypass valve lock out Wed, 02 February 2005 10:42 Go to previous messageGo to next message
http://homepages.tig.com.au/~robs/intake.htm
actually robs page is full of great stuff worth reading all if it
Clown
Ballarat, Vic.
Re: 4AGZE bypass valve lock out Thu, 03 February 2005 01:57 Go to previous messageGo to next message
http://www.mr2oc.com/index.php?s=
all you ever need to know is there. If its not there ask and you'll find out the answer. Also check the "Aw11 anon" thread...... or just ask Feral etc. on here Very Happy
feral4mr2
Bundaberg, Qld.
Re: 4AGZE bypass valve lock out Fri, 04 February 2005 10:32 Go to previous messageGo to next message
yea, pull it off and use it as a door stop. make a aluminium plate that'll bolt to the TB and i used some dowl to block the outlet hose from the s/c.
remove the blue vsv unit and cap the vacum source thats below the TB.
selk
Re: 4AGZE bypass valve lock out Sat, 05 February 2005 05:45 Go to previous messageGo to next message
is it possible 2 replace tha by pass valve wit a blow off valve ?
Spanktown
Inside a giant turbo (syd...
Re: 4AGZE bypass valve lock out Sat, 05 February 2005 06:23 Go to previous messageGo to next message
*giggles*
feral4mr2
Bundaberg, Qld.
Re: 4AGZE bypass valve lock out Sat, 05 February 2005 12:36 Go to previous messageGo to next message
do a search on that question and you will find the answer prity fast...
Clown
Ballarat, Vic.
Re: 4AGZE bypass valve lock out Sat, 05 February 2005 12:58 Go to previous message
arrrrrrrrrrgh!!!
i get a few comments on the mr2. "you should put a BOV on it" errrrrrrrr no thanks!
Previous Topic:What Oil You Use? 4AGE
Next Topic:high energy ignition kit
Current Time: Mon Oct 26 04:32:34 UTC 2026
Total time taken to generate the page: 0.0042819976806641 seconds
