Toymods » Tech & Conversions » KE20 workd 4K Fuel Solutions
PMP020
January 2005
icon4.gif  KE20 workd 4K Fuel Solutions Wed, 02 February 2005 10:24 Go to next message
hey guys
ive recently put a 4k wita 3k head, stg 3 race cam, extreme clutch into my lil KE20.
was running a 32/36 weber but it was in shit cond. and jus not workin proper.
so im after some ideas for fuel
big weber? twin small webers?
stok carby big jets? stok carby off bigger engine?
im after good response through the whole rev range.
please help me out
cheers scott
Re: KE20 workd 4K Fuel Solutions Wed, 02 February 2005 10:45 Go to previous messageGo to next message
wtf is a stage 3 race cam?
you mean 3 stages above road? so it's around 310-320 deg?
how many stages does the cam grinder have? Wink
what is the duration (both advertised and at 50 thou lift) and what is the lift at the valve.
32/36 has a 26mm choke, and is a shit choice for a 1.3L.. good choice for a 2L Razz
what you need (without knowing anything more about your setup) is something with a small primary choke, sayy 21 (stock) to 24, and then a big secondary (say 27mm) and that wll be fine..
a weber 34DMS is good, as are a lot of other early 70's euro webers (fiat etc)
stock (not stok.. speeling is gud Wink ) carby runs rich with bigger airflow.
if you put on twin webers you would have to choke them way way down.
PMP020
January 2005
Re: KE20 workd 4K Fuel Solutions Thu, 03 February 2005 07:37 Go to previous messageGo to next message
hey dood
wel itsa stage 3 waggott regrind its 266 deg.
waggott regrinds hav 6 stages.
shit dood im tryin 2 read da print out dat came wit da cam and its not makin much sence 2 me i reali gota learn 2 understand dis stuff.
but cheers 4 ya help ill start callin da old euro places round adelaide see wat i can dig up.
even with stok carby should it run ok? coz atm it runs like crap wit stoka on der?
wat car is da weber 34DMS off of? fiat?
cheers scott
PMP020
January 2005
Re: KE20 workd 4K Fuel Solutions Thu, 03 February 2005 07:40 Go to previous messageGo to next message
Be gentle im new 2 da hole modified scene i usally stik wit my stock rollas and afta dis engine is finishd i thnk i mite go bak 2 my old ways. hahahah
Re: KE20 workd 4K Fuel Solutions Thu, 03 February 2005 08:12 Go to previous messageGo to next message
when you can translate that into english, i might be tempted to answer you.
gearb0x
Re: KE20 workd 4K Fuel Solutions Fri, 04 February 2005 01:45 Go to previous messageGo to next message
oldcorollas wrote on Thu, 03 February 2005 19:12
dis tlk iz not workn proper on dez forums
Jason
Re: KE20 workd 4K Fuel Solutions Fri, 04 February 2005 02:14 Go to previous messageGo to next message
Crap bub are you for real or are you just missing some strategic keys on your keyboard????????????????????????????? Confused
PMP020
January 2005
Re: KE20 workd 4K Fuel Solutions Fri, 04 February 2005 07:59 Go to previous messageGo to next message
well i did fail computing back in school maybe it all started there.
anyway just wondering if anyone else has tryed and succeeded with other webers that are a little more easier to find?
made a few calls based on oldcorollas help and people just kept saying goodluck.
i hope the spelling is up to everyones standards in this post.
thank you for listening haha.
Redwarf
February 2005
Re: KE20 workd 4K Fuel Solutions Fri, 04 February 2005 08:56 Go to previous messageGo to next message
I've got a pair of DCOE 40's on a biggish 3K, and they work very well. Aircleaner space is a BIG issue, and minor panel beating was required to fit 40mm thick filters.
Fuel economy is non existant.
I used to have twin 1-1/2 SU's on the same engine, and they were a good thing, too. (Webers are now better suited to what I require.) People shit can them, but I liked them. Good power and good economy.
I'm not a fan of down draft carbs. Each to their own. I know people who are quite happy with them, but the man above would know more about them than me. Smile
R
Re: KE20 workd 4K Fuel Solutions Fri, 04 February 2005 09:46 Go to previous messageGo to next message
i had my stock carby (with "high speed valve" removed) for a while, and it was not that bad. the weber had a lot more power, but chewed fuel like no tomorrow as it basically had no idle circuit, and i had to make it very rich since it ate one of the choke screws...
but think about this.
if you have a bigport.. intake goes from 30mm, down to 25mm (about that in ALL stock manifolds but some of the twin carb manifolds), then turns 90deg (and joins to 1x25mm runner for the early ones) then turns 90deg and opens into a large chamber below the carb..
this is not ideal..
EFI is always better and mine is running very well (7ke), but i think the 4KE setup could be made to work better in midrange.
as i keep telling ppl, the 32/36 is not ideal.. it has a primary choke that is suited to a 2L motor, not a 1.3.. 21-24mm is good.. just find any downdraught with that, and you are 3/4 the way there. downdraught is easy but far from ideal
for twins, SU's do sound like a good option.. webers are expensive, but good for top end. EFI is good for everywhere.
my ideal setup would be 35mm ITB's with EFI...
Redwarf
February 2005
Re: KE20 workd 4K Fuel Solutions Fri, 04 February 2005 11:25 Go to previous messageGo to next message
The hard part about SU's is getting hold of a manifold. They are seriously rare. I got mine out of Sydney. No, I won't sell it.
indigoid
Canberra, ACT
Re: KE20 workd 4K Fuel Solutions Sat, 05 February 2005 02:21 Go to previous messageGo to next message
There is a Lynx manifold for twin SUs on K heads. I've got one on the bench with a pair of HS4s on it. Someday it may find its way into my KE26... need to sort out linkages first.
http://images7.fotki.com/v114/photos/2/229297/1400723/p0003572-vi.jpg
Redwarf
February 2005
Re: KE20 workd 4K Fuel Solutions Sat, 05 February 2005 04:31 Go to previous messageGo to next message
Does this help at all?
http://www.rollaclub.com/board/index.php?act=Attac h&type=post&id=19529
http://www.rollaclub.com/board/index.php?act=Attac h&type=post&id=19628
R
PMP020
January 2005
Re: KE20 workd 4K Fuel Solutions Sat, 05 February 2005 05:16 Go to previous message
cheers people all your feedback is much appriciated.
oldcorollas? what do you reakon about re-jetting standard carby? would it make that much more difference?
because ive just got my car running pretty sweet today but shes lacking abit up top and im having alot of difficulty finding the webers that you suggested.
cheers scott
my spelling is getting much better thank you all Very Happy
Previous Topic:2tgeu v's 3tgteu cams
Next Topic:TA22 Vs RA23 front control arms the same?! URGENT!!
Current Time: Mon Oct 26 23:59:54 UTC 2026
Total time taken to generate the page: 0.006990909576416 seconds
