Toymods » Tech & Conversions » 2jz supra cluster into gz20 soarer dash? or ma70 dash?
Esselte
2jz supra cluster into gz20 soarer dash? or ma70 dash? Wed, 02 February 2005 13:54 Go to next message
I'm not sure of the size of the 2jz instrument cluster, they look fairly smallish in the supra dash, do you think it would be small enough, or roughly a similar enough shape, to fit and somehow mount into a gz20 dash? If anyone's had a look at both instrument clusters out of the dash you could probably tell.
Also, does an MA70 dash bolt straight into the gz20 soarer dash mounting points? I love the ma70 dash, but i think the air vents on the soarer doors stick out too much to fit the mz70 dash, if it fits at all, it looks much longer than the gz20 dash, but both chasises (chases? Smile are the same (at least the motor and gearbox xmember sections of the chasis).
celica_freak
newcastle
Re: 2jz supra cluster into gz20 soarer dash? or ma70 dash? Wed, 02 February 2005 14:50 Go to previous messageGo to next message
i have a 2jzgte out of an aristo which is a lexus gs 300,im squessing it into a lc torana and using as much of the aristo as possible including the dash how ever i can take mesurement and photos if u like just reply it may take a couple of days but u'll get the info for that dash
ps the hole harness is heavy guestament 50kg i lift that in wire rolls for work daily
Esselte
Re: 2jz supra cluster into gz20 soarer dash? or ma70 dash? Thu, 03 February 2005 08:31 Go to previous messageGo to next message
That would be awesome dude thanks, even just a measurement of the instrument cluster ouf of the dash, so i can tell if i can fit it into the standard soarer dash. Thanks heaps, Dan.
celica_freak
newcastle
Re: 2jz supra cluster into gz20 soarer dash? or ma70 dash? Sat, 05 February 2005 10:20 Go to previous message
OK hears a rough measurement
over all length 420mm
overall hight 190mm
depth at top 230mm
depth at bottom 120-130mm
om not sure how to add photos so give me some where to sent them to for all to see
Previous Topic:plenum design
Next Topic:Drift Suspension
Current Time: Mon Oct 26 00:52:20 UTC 2026
Total time taken to generate the page: 0.0048608779907227 seconds
