Toymods » Tech & Conversions » Turbosmart bleed valve incabin?
Turbosmart bleed valve incabin? Wed, 02 February 2005 23:14 Go to next message
Hello, wanted to check if anyone knows is it ok to run a bleed valve inside the cabin? Or would the extra long piping cause problems? I recall hearing it needs to be as close to the wastegate as possible?
Joel
ke382TG
Re: Turbosmart bleed valve incabin? Wed, 02 February 2005 23:26 Go to previous messageGo to next message
Thats right, it needs to be close to the wastegate for stable boost control. Having it as far away as the cabin would cause boost spikes and unstable boost control, not ideal.
I use a turbosmart bleed valve in conjunction with a setup I made myself so I can control high/low boost from inside the cabin (electric control of solenoid via switch), it works very well and has the best boost control of anyhting I have tried so far.
I can PM you details if interested and show you the setup at WSID.
Cheers.
Re: Turbosmart bleed valve incabin? Wed, 02 February 2005 23:42 Go to previous messageGo to next message
That'd be great to send the details through to me Smile
Re: Turbosmart bleed valve incabin? Thu, 03 February 2005 02:43 Go to previous messageGo to next message
its also illegal Smile
ke382TG
Re: Turbosmart bleed valve incabin? Thu, 03 February 2005 02:54 Go to previous messageGo to next message
I sent you an email with a word doc attached Joel. Any Q's let me know.
Quote:
its also illegal
Yes it is.
Celia-Sue
Re: Turbosmart bleed valve incabin? Thu, 03 February 2005 08:25 Go to previous messageGo to next message
THE WITZL wrote on Thu, 03 February 2005 13:43
OK, I'll bite . This may be my dumbest question, yet - but why? I just can't see it being any harm to the occupants or other motorists.
EVOSTi
cambo
      no
Re: Turbosmart bleed valve incabin? Thu, 03 February 2005 10:09 Go to previous messageGo to next message
because pressurised air is in the cabin i spose? and it a seal went in the turbo oil could come through the hose.
i dont think its SUCH a bad thing to have it in the car, i mean a boost spike isnt too bad. it will just spike as it comes on boost, because the presure has to build up in a longer volume of hose. its relatively safe, as the spike will be at low revs when there will be adequate fuel pressure. my friend has his in his car and it does have a small spike, but i havent noticed the control to be bad, seems pretty smooth to me.
having said all that its very easy to run a solenoid and have a switch inside the car.
Celia-Sue
Re: Turbosmart bleed valve incabin? Thu, 03 February 2005 10:23 Go to previous messageGo to next message
Jeez, I can understand it being a bad idea performance wise, but saftey? I mean, a boost guage introduces pressurised air to the cabin, though I haven't heard of any fireballs indiced by them. Evil or Very Mad
EVOSTi
cambo
      no
Re: Turbosmart bleed valve incabin? Thu, 03 February 2005 10:47 Go to previous messageGo to next message
i dunno if thats it, im just guessing.
Re: Turbosmart bleed valve incabin? Thu, 03 February 2005 11:26 Go to previous messageGo to next message
I used to use one of those turbosmart 'in cabin' bleeds under the bonnet of my car (only because I got it cheap!), and found it actually worked pretty darned well. I think it's really only full sikness factor that would give most people the desire to run it inside the car. Plus, because mine used to be connected to the manifold AFTER the LPG carb, I suppose it was full of flammable vapour.
Hunty
Re: Turbosmart bleed valve incabin? Fri, 04 February 2005 00:07 Go to previous messageGo to next message
what are those turbo smart bleed valves like? i assume we all talking about the same ~$100 ones that look like this
http://i23.ebayimg.com/03/i/03/56/cf/9c_1_b.JPG
i'm lookin at gettin one to run a little ie 2-3psi more boost in my mr2. would this be suitable or do they tend to spike a lot, or is that spiking because of the lenth of hose you use when plumbing it in?
i see no point in gettin electronic boost control or a dual stage controller as im not running mega boost.
ke382TG
Re: Turbosmart bleed valve incabin? Fri, 04 February 2005 03:18 Go to previous message
They work well and are priced well, as far as spiking goes. They spike on some cars and not others. Keep the line from compressor housing (best spot to run from or directly after the compressor housing) to the bleed valve to the waste gate actuator as short as practically possible.
If you like to tinker like I do, you can use different gate springs in the bleed valve to control the gate response and to some degree the amount of spike you see Very Happy
Previous Topic:Suspension mods in SA - Who?
Next Topic:Truck Radiator
Current Time: Thu Nov 19 09:37:03 UTC 2026
Total time taken to generate the page: 0.0099520683288574 seconds
