Toymods » General Car Talk » 4agze specs
kdogg
leumeah NSW
4agze specs Thu, 03 February 2005 02:14 Go to next message
im after 4agze specs and a rough price for a decent one in sydney
bigg willie style
melbourne
Re: 4agze specs Thu, 03 February 2005 02:15 Go to previous messageGo to next message
you should be able to find this information and more in a forums search (you'll find the button in the top right hand corner)
dimmy77_03
Potts Point, Sydney
Re: 4agze specs Thu, 03 February 2005 02:53 Go to previous messageGo to next message
there would be heaps on this site, search it or check out tech documents Very Happy
4agte
Toronto, Downtown
Re: 4agze specs Thu, 03 February 2005 03:19 Go to previous messageGo to next message
depends which gen of 4agze the mr2 ones have ceramic coated semi forged pistons larger conrods 8.0:1 compression the supercharger runs 8psi of boost and makes 107kw. The map sensored versions which were in the levins run 10psi and higher comp 8.9:1 if i remeber correctly they also make more power accordingly somewhere arround the 117kw mark. Also later verions had oil squirters to cool the pistons.
A good place to start is any wrecker like SSS automotive which is where i got my half cut which was low kays and had good compression. If at all possible get a compression test on the engine and on 8.0:1comp should be what 160-170psi mark i think from memory?
I would think it would be somewhere arround the $1000-1200 mark for the engine alone maybe. again depends on the generation and condition.
Re: 4agze specs Thu, 03 February 2005 03:48 Go to previous messageGo to next message
front cut prices are now up around the $3000 mark in sydney in some importers.
AW11 = AFM type. dissy. 8.0:1. bigport.
AE92 (pre 06/89) = AFM type. DLI. 8.0:1, bigport.
AE92 (post 06/89) = MAP type. DLI. 8.9:1. smallport
AE101 = same
The map sensor versions also run more boost thanks to a smaller supercharger pulley, and are generally a much more powerful motor to begin with.
Typical power at wheels from MAP gze in AE92 (stock gze) = 85-95kW.
afm gze's are pretty poor from stock.
[Updated on: Thu, 03 February 2005 03:54]
4agte
Toronto, Downtown
Re: 4agze specs Thu, 03 February 2005 06:14 Go to previous message
afm gze comp ratio is better for big boost
Previous Topic:Echo gold colour
Next Topic:Tyre Choice?
Current Time: Tue Oct 27 12:40:41 UTC 2026
Total time taken to generate the page: 0.0061140060424805 seconds
