Toymods » General Car Talk » Injector question.
wumpagrande1992
Warrnambool, Victoria
Injector question. Thu, 03 February 2005 03:36 Go to next message
Hi, are the 7M-GE and 3S-GE injectors the same?
Re: Injector question. Thu, 03 February 2005 05:35 Go to previous messageGo to next message
Same flow yes (295cc), but 3SGE is hi-impedance.
http://www.toysport.com/webpages/Techinfo/Referenc es/injectors.htm
wumpagrande1992
Re: Injector question. Thu, 03 February 2005 14:22 Go to previous messageGo to next message
MMM so they wont be interchangeable? Bugger.
fade-e
Re: Injector question. Thu, 03 February 2005 14:26 Go to previous messageGo to next message
wumpagrande1992 wrote on Fri, 04 February 2005 01:22
why not? from the list there are 2 types and the second ones are exactly the same... the 315cc ones
Re: Injector question. Thu, 03 February 2005 14:29 Go to previous messageGo to next message
But if he has lo-impedance ones, the 3S-GE ones are useless for the factory ecu.
wumpagrande1992
Re: Injector question. Thu, 03 February 2005 14:36 Go to previous messageGo to next message
That's what I thought, will find out which I have (7M ones are 300k away) and then I will know. I want to put my 7M ones in my Celica as I know they are in better condition. Thanks and thankyou to Peewee.
[Updated on: Thu, 03 February 2005 14:43]
bathurst-91
Re: Injector question. Thu, 03 February 2005 21:21 Go to previous messageGo to next message
What ranges classify 'low' and 'high' impedence respectively?
[Updated on: Thu, 03 February 2005 22:08]
Re: Injector question. Fri, 04 February 2005 00:54 Go to previous messageGo to next message
bathurst-91 wrote on Fri, 04 February 2005 05:21
The resistance of the coil in the injector.
Low impedance = 2ohms.
High impedance = 13ohms.
@ 12volts a low impedance injector drain 6A, where as a high impedance injector drain 1A.
Put the wrong one in, and you can fry the ECU
Re: Injector question. Fri, 04 February 2005 01:13 Go to previous messageGo to next message
but if you have aftermarket management, I've been led to believe that it doesn't matter... do you have to tell the ecu whether you're running hi or low impedence injectors, or does it "figure it out"??
Re: Injector question. Fri, 04 February 2005 01:21 Go to previous messageGo to next message
I dunno hey.
Coz changing high impedance injectors for low impendace ones will run 6 times the current through the earth switch on the ecu.
It may well be designed to cope with this.
It may well not!
st184 sillycar
Re: Injector question. Fri, 04 February 2005 01:25 Go to previous messageGo to next message
You could put a resistor or an induction coil inline with the Low-impedance Injector to get the power-drain right, if the injector would still function with the lower current . . . .
Alternatively, you can use big paired transistors as ultra-high speed relay switches, using low/zero current from the ECU to switch the big current into the injectors, or coils, or anything really. the switching lag would be a few milliseconds at most, so It won't stuff your injection timing if you've got sequential injection.
is that any help?
Re: Injector question. Fri, 04 February 2005 02:37 Go to previous message
your the second suggestion would make things worse rather than better - ECU's with formal time resolution will be working in units of 0.1m/s, some (particularly aftermarket units trying to get large-culume injectors to idle) will work down to a 10th of that.
if your ECU is designed to see high Z and you only have low Z injectors, you could put a resistor pack (from a car that uses those same injectors) inline between injectors and the power source
many ECU's can be configured to run high or low Z injectors - but will not autoconfigure
an induction coil will not help you
Previous Topic:MA61 in Targa Tas
Next Topic:My New Toy
Current Time: Fri Oct 23 10:22:00 UTC 2026
Total time taken to generate the page: 0.0055811405181885 seconds
