Toymods » Tech & Conversions » ST190 corona idle problem
deeps
ST190 corona idle problem Thu, 03 February 2005 04:10 Go to next message
i have a toyota corona 92 model, and just recently, i've had problems with the idling of the car..its rougher than usual, and is worse when the a/c is on. it doesn't have a problem in park. when i put the a/c on, it drops to very low revs, and then goes up again, but is still rough.
i've just recently changed the spark plugs and leads.
when i put the car from drive to neutral, when i'm stopped at a light, the revs drop and the car idles really roughly for a second or two, then it picks up and goes to normal (normal being slightly rough)..
i thought perhaps i have to change the idle timings, but i simply cannot find the idle screw.
any ideas what's wrong with it?
deeps
Re: ST190 corona idle problem Wed, 16 March 2005 07:16 Go to previous messageGo to next message
never mind...take a look at that......
http://members.iinet.net.au/~bmanat/
[Updated on: Wed, 16 March 2005 07:16]
turbocaldina
Tumut
Re: ST190 corona idle problem Wed, 16 March 2005 10:57 Go to previous messageGo to next message
put the old leads back on and see if that fixes it
deeps
Re: ST190 corona idle problem Wed, 16 March 2005 11:47 Go to previous messageGo to next message
the old leads were screwed, arcing and stuff
I've noticed, when the car is in drive, it is fine... but if the car is in drive, and the fan is on (no a/c) it shakes, and even worse with a/c..
It sort of "searches" for the idle speed, it dips below 500 and then it goes close to 900 and then it settles at around 650, a bit less.. and is still kinda rough
i had the problem before i changed the leads though...
deeps
Re: ST190 corona idle problem Wed, 16 March 2005 11:49 Go to previous messageGo to next message
but yeh, take a look of those pics, i gotta wait and see if they will fix it,before i do any work on it.....
turbocaldina
Tumut
Re: ST190 corona idle problem Thu, 17 March 2005 06:47 Go to previous messageGo to next message
i had the same problem with mine and it ended up bein the wires for the water temp sender bein to brittle and not getting good enough current through it
deeps
Re: ST190 corona idle problem Thu, 17 March 2005 13:29 Go to previous messageGo to next message
turbocaldina wrote on Thu, 17 March 2005 17:47
the water temp sender? is that the thermostat? where is the water temp sender and what does it look like?
turbocaldina
Tumut
Re: ST190 corona idle problem Fri, 18 March 2005 10:24 Go to previous message
its at the back of the motor where the top radiator hose comes out
Previous Topic:Sprinter Paint
Next Topic:Urgent help needed ST184 Headlights
Current Time: Tue Oct 20 01:07:01 UTC 2026
Total time taken to generate the page: 0.0047011375427246 seconds
