Toymods » Tech & Conversions » KE20 Master cyl??
schmick_ke
KE20 Master cyl?? Thu, 03 February 2005 12:09 Go to next message
hey im currently doing up a 73 ke20 ive got the front brake conversion done (magna disks and early commodore calipers) and i was now wondering on you guys advice on which brake master cylinder to use and or booster to use? its a bit hard on braking even though its a massive overkill.
any help appreciated. cheers
-simon
Re: KE20 Master cyl?? Thu, 03 February 2005 12:42 Go to previous messageGo to next message
boosted or unboosted.
if unboosted, then use the master cylinder size of the KE20, multiplied by the increase in the caliper piston size. that way you have same pedal travel (slightly smaller as rears are not bigger are they?), and same feel.. just better braking...
or if boosted, go with whatever size the commondore had.
schmick_ke
Re: KE20 Master cyl?? Fri, 04 February 2005 05:55 Go to previous messageGo to next message
yeah rear brakes are stock, i probably will go without the booster as there aint much room. cheers for your opinion mate.
-simon
Celica_John
Re: KE20 Master cyl?? Fri, 04 February 2005 06:24 Go to previous messageGo to next message
probably no help to you but my mate used a master cylinder from a 180sx on his ke35. direct bolt on.
(just gotta be lucky sometimes)
YelloRolla
On your mum!
Re: KE20 Master cyl?? Fri, 04 February 2005 06:51 Go to previous messageGo to next message
I use a PBR VH44 remote booster - front brakes only are assisted.
schmick_ke
Re: KE20 Master cyl?? Tue, 08 February 2005 12:43 Go to previous message
cheers guys for the replies Smile
Previous Topic:20V silver Aftermarket Vs standard ECU
Next Topic:2tg electronic ignition
Current Time: Sat Nov 21 00:47:05 UTC 2026
Total time taken to generate the page: 0.0043079853057861 seconds
